Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Torque plate for honing
Old Apr 15, 2004 | 05:30 AM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
OK, you could say why the hell do I have to worry about borrowing or fabricating one; that's because SBC isn't to common in eastern Europe and it's hard to find a shop equipped with tq plates.
I've got access to the shop specializing in waterjet technology - they can cut almost any shape in metals with very thin stream of pressurized water with addition of abbrasives, the thickness of steel material can be up to 2 in. They could fabricate a nice torque plate for $50 if I deliver material and AutoCad project, so the price is tempting.
I know that the big bores diameter should be 4.060 + .040", bore spacing is 4 1/2", but how should I locate bolt holes? I've a feeling that the head gasket is not to good as a template; perhaps it wold be ok to retrieve dimensions from a head - like put it on a scanner, LOL... I could also use long drill trough old head, but it's more "technical" to produce whole plate on a single machine, properly programmed. Tried searching the net for a drawing of deck or head surface but no results yet. Does anyone of you have a drawing like this or knows where to find it?
edit: bore centerlines are 4.4; not 4.5 in. from each other...
Old Apr 15, 2004 | 07:41 AM
ede's Avatar
ede
i'd buy a head gasket and use it as a template or to copy into a cadd file. i'd make the holes way over size, like 4.25, if it doesn't interfer with a bolt hole. water jet would be a fast clean way to make one.
Old Apr 22, 2004 | 04:05 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
torque plate bolt holes
I dont know if you have pulled your motor out yet. but i would pull the motor out and get it on an engine stand. remove bothe your heads and clean the mating service of your block and get a thin sheet of clear 1/8 clear lexan (plexi glass) and mount it to the top of your block with the head pins as if it were a head gasket then mark your holes with a permanent marker and then remove them drill them out the same size as the holes in the heads and take your already cut water jetted peices to a machine shop and have them match your pieces and drill to size.
That should work considering that you are just simulating the torqued stress of a cylinder head.
If all else fails contact a speed shop here in texas and see if they can give you the dimensions because it seems that maybe you wanted the bolts holes water jetted as well...
Old Apr 29, 2004 | 01:45 PM
z_power's Avatar
Car: '89 GTA
I've made a simple .dwg file and printed it on transparent foil; it fits 100% to the block if anybody is interested in web-hosting then I'll send it to him via e-mail...
edit:
Old Apr 29, 2004 | 01:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
edit:
i have a ton of free webspace.... send me a copy and i'll toss it up for ya...
MrDude_1@excite.com theres a "_" between Dude and 1 that you somtimes cant see.....
Old Apr 29, 2004 | 03:17 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
link:
http://josh.swoca.net/board/mrdude/tplate.dwg
Old May 11, 2004 | 05:27 AM
z_power's Avatar
Car: '89 GTA
here it is with big bores cut; need to drill bolt holes now:
Old May 11, 2004 | 05:30 AM
z_power's Avatar
Car: '89 GTA
surface after cutting with waterjet; not to clear, but I've just bought an electric die-grinder
Old May 11, 2004 | 05:56 AM
ede's Avatar
ede
for a water jet that looks a bit rough. most of the metal i have cut comes out very clean, but my metal is a lot thiner, and not steel.
Old May 11, 2004 | 06:38 AM
z_power's Avatar
Car: '89 GTA
I've been expecting smoother cut, too... It's caused probably by material with structural problems - you can see where harder grains changed the direction of cutting stream. Also don't know if the movement of cutting head wasn't to fast, but overall I'm satisfied.
Old May 11, 2004 | 08:18 AM
ede's Avatar
ede
i use it for tantalumn cutting. very dense but not too hard metal. takes forever to saw or machine.
Old May 12, 2004 | 11:23 AM
robsgta's Avatar
Torque plate
Chevy small Block "Its whats for dinner!"
Could they have flipped it over and made the same cut from the other side for a smoother finish cut? Well you got it done and it does look decent.
grngryoutmyway
Oct 18, 2016 05:48 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
ndndndnd
Sep 28, 2015 08:00 AM
GTAman
Sep 26, 2015 02:01 PM
dbrochard
Sep 25, 2015 04:56 PM
