Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Simulated load engine test stand...
Old Jun 19, 2004 | 12:30 AM
dennis6's Avatar
Car: 1991 Camaro RS
Would it be possible to hook some form of dummy load (ie generator) to an engine on a test stand for tuning purposes?
Old Jun 19, 2004 | 02:04 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Using a generator wouldn't put any load on the engine unless you could provide the generator with some kind of electrical load. A water column or something similar would probably be better.
Old Jun 19, 2004 | 06:44 AM
oil pan 4's Avatar
Car: 89 Firebird
To put 100hp worth of an eletrical load your going to need about a 72kw generator and a load with a .8 power factor (needed a load rated at 58Kva).
It's going to take a big generator.
If you shorted the generator together that would make about a .95 power factor and wouldn't take nearly as much hp to make 72kw.
The load would have to be transformers, moters, lights and not just a big resistor.
Easyest way to get a generator like that is to find a used 60 or 400Hz 3-phase generator.
It would take a 1 ton (about the size of a 55 gallon drum) 60Hz generator spining at about 2400 rpms (you could gear it down) or a smaller 150-170lb 400hz generator spining 6000 rpms.
That's how big they would have to be.
Like a little koler 7kw wouldn't do any thing as far as a load.
Old Jun 19, 2004 | 02:01 PM
dennis6's Avatar
Car: 1991 Camaro RS
I was thinking of one of the big ones. It would certainly be cheaper than buying a dyno.
Old Jun 19, 2004 | 02:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Essentially you're building your own dyno. Do a search on the net, lots of people have built their own engine dynos, some big, some small.
Old Jun 20, 2004 | 02:54 AM
dennis6's Avatar
Car: 1991 Camaro RS
After some searching, I found alot of motorcycle, ATV, R/C car, and a few inertia automotive dynos. Nothing appicable or inexpensive. All I am looking for is a load, I don't need to data log or even get power outputs.
Old Jun 21, 2004 | 09:35 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
have any reasonably big bodies of water around?
it takes a good amount of energy to push water around.... you can try running a prop or impeller or somthing like that....
Old Jun 22, 2004 | 01:49 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I heard of someone making one with a retarder from an allison automatic transmission, needed lots of cooling. There's not a lot of things that you could dump a few hundred horsepower into in a controlled manner. A big pump, a big tank of water and a way to keep the water cool would be the best bet.
Old Jun 22, 2004 | 02:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Let the water warm up even, if you have enough water it's going to take a really long time for it to heat up to any appreciable degree.
Old Jun 24, 2004 | 08:35 PM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks, I do have a swimming pool available...
Old Jun 25, 2004 | 09:22 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Rig up a few disc brakes, and get some Autozone lifetime rotors and brake pads!
Old Jun 25, 2004 | 10:03 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol and watercool them....
Old Jun 25, 2004 | 09:30 PM
dennis6's Avatar
Car: 1991 Camaro RS
I don't feel like being the sole reason autozone removes its lifetime warranties.
I was thinking of a rather large pump to pull water out of the pool and replace it. It would take a long long time to heat that much water up.
Old Jun 26, 2004 | 12:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Doesn't everyone want a heated pool, anyway?
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
