Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
A/C clutch waterpump drive
Old Aug 7, 2004 | 11:06 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Just wondering if anyone here has ever considered modding an A/C electric clutch to fit the front of a water pump so it could be disengaged with a switch from the cockpit, for those times when a person might want to eliminate that extra drag?
Or possibly mount the electric clutch to the crank pulley, to temporarily delete all the belt driven accessories?
Old Aug 9, 2004 | 01:08 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
You don't want to stop the water pump for any reason. You will build up steam pockets in a matter of seconds. Get an electric if you are concerned.
Old Aug 10, 2004 | 08:07 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
those clutches arent designed the handle that kind of abuse.....your vastly underestimating the drag on a waterpump at RPM.
Old Aug 11, 2004 | 12:23 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Ive seen them used on a supercharger before, centrafugal type.
Old Aug 11, 2004 | 08:37 PM
Car: '85 IROC
Engine: LB9
I'll take your word for that.
But It's kind of odd that I've actually seen one in use, but it was on an Italian engine.
As far as the drag on the water pump is concerned, I was assuming that the load on a AC compressor is greater than a waterpump.
Maybe not tho.
I wonder how it might work if it were adapted to the crank pulley and used to drive the PS pump and alt? Then those accessories could be disengaged separately if needed.
Old Aug 13, 2004 | 12:17 AM
onebinky's Avatar
One of the german manufacturers did that OE for a while. And didn't they do that in one of the Madmax movies too?
Old Aug 13, 2004 | 12:25 AM
onebinky's Avatar
EDIT: Double post.
Is everyone else's computer lagging *** on this website lately too? Everything is taking a LONG time to load here...
Old Aug 13, 2004 | 09:37 AM
Car: 1971 Corvette
Axle/Gears: 3.36
It's probably from the novel of sig you have. A little more concise would be better.
Old Aug 13, 2004 | 12:26 PM
onebinky's Avatar
It's all text, except for the tiny pic at the bottom. Text doesn't take any time at all to load. I probably should find a way to shorten it though...
Old Aug 13, 2004 | 02:08 PM
Car: '91 Camaro RS
well ya, and it was on a roots blower........an enging with a roots blower wont run if the blowers not turning, unless it has a bypass valve, but it still wont run right
Old Aug 13, 2004 | 04:15 PM
Car: '85 IROC
Engine: LB9
Anything you see in the movies is hardly worth discussing. Because in truth, most if the stuff there is so far fetched it wouldn't even make it off the drawing board in the real world.
I did see a clutched WP drive on an Italian car. Maybe the engine was German, it was an Abarth.
It had dual Weber sidedrafts.
Actually the engine belonged to me. A guy took it out of his Alfa and gave it to me cause he owed me $$
Old Aug 13, 2004 | 07:57 PM
83 Crossfire TA's Avatar
The madmax blower was fake, it housed a carb…
Old Aug 13, 2004 | 09:31 PM
onebinky's Avatar
The movie reference was just a joke, I haven't even seen that movie in probably 10+ years
I know that I have seen them on some german cars though.
Old Aug 13, 2004 | 10:24 PM
Car: '85 IROC
Engine: LB9
I caught the joke.
I was getting concerned that this thread might start moving in that direction.
But what the hey... anyhow
I'll probably never end up making one of those things. Just wondering if anyone's ever seen one or thought about doing it.
Anyone besides Mad Max that is
Old Aug 13, 2004 | 10:54 PM
Rage13's Avatar
Car: 89 Firebird
they had a clutch like you guys are talking about on the 87' or 88' toyota mr2, it was a little roots blower
Old Aug 14, 2004 | 01:28 AM
92Transam's Avatar
If you look hard enough on the web you might find the super stallion made by ford it was a mustang with a supercharger that had a clutch type system on it to shut off the supercharger when not needed.
Old Aug 23, 2004 | 11:25 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
use an electric water pump
Old Aug 31, 2004 | 09:25 PM
Dr BBS's Avatar
Car: 1982 camaro (13.063 @ 105.61mph)
Engine: 5.7
Transmission: T5 with a 3.27 9 bolt
I've seen a nova with a AC clutch on the crank pulley, he was running an electric water pump, and is alternator and P/S were belt driven... He wired it for the clutch to be engage as soon as the key is turned on, and with the flip of a switch, it disengaged the accessories.
The guy told me he was running it on a daily basis on summer and never had slipping problem (he disemble the clutch many time to look at it the first time he was running it)...
It was doing steady 10.8 1/4 a 120+ mph all motor.
Too bad I did not have my camera that day... If I see him again, I will take pics
Old Sep 1, 2004 | 02:30 AM
Car: '85 IROC
Engine: LB9
That's very interesting.
Please do send a pic if you can.
lakeffect2
Aug 23, 2015 08:44 AM
jharrison5
Aug 19, 2015 05:53 PM
BikeFarm
Aug 11, 2015 11:35 PM
rsrmoore
Aug 7, 2015 08:44 PM
