Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
roll cage for T-tops????
Old Nov 25, 2004 | 03:07 AM
82crossfireTA's Avatar
Car: 82 Trans Am T-top, Red
Engine: 305 Crossfire
Transmission: Metric 200
do they make a roll cage out there specifically for T-toped 3rd gens, where-as it follows the the shap of the t-top, or is that something i would have to take down to a fabrication shop?
~Nick~
Old Nov 25, 2004 | 06:25 AM
ede's Avatar
ede
you won't find many if any roll cages that are a direct fit, they're more universal and you cut to fit your application.
Old Dec 23, 2004 | 11:36 PM
lobuckhotrod's Avatar
Car: 1987 IROC
Engine: 1972 350
Transmission: turbo 350 w/3500 stall
I installed an eight point roll bar in my 87 iroc. took several days to install. The roll bar kit came from Jegs. All kits have to be cut to fit as all parts come too long, this allows you to custom fit to your particular needs. Also invest in the rear seat saver bars if you want to retain the use of rear seats. I will post some pictures after I get some made.
Old Dec 24, 2004 | 01:29 AM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
We have an S&W 14 point kit for the turbo car. I haven't installed it yet but when I mocked everything up the t-top levers look like they'll be tight, but, they'll work just fine
Old Dec 24, 2004 | 06:09 PM
Mathius's Avatar
I wanna say it was Kenny Brown who used to make F-body specific roll cages, but I'm not positive on that.
Mathius
Old Dec 25, 2004 | 02:43 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Re: roll cage for T-tops????
~Nick~
Nick, if you need to go to a ten-point cage with tubes heading along the roofline to a forward hoop, you'll most likely have to run your tubes across near the hatch lever to keep it safe. Otherwise the forward hoop will not have enough strength to keep you safe in the event of a rollover. If you are thinking of putting in a forward roll hoop with a single overhead tube that runs down the centerline of the car, then you will be in essence adding nothing more than weight to the front of the car: Weight that you can smash your skull into as the roof collapses in around you.
Either stick to an eight point roll bar, or else do the conventional ten-point design and wear a helmet when you drive the car.
Think twice about it,
--Dan
Old Dec 26, 2004 | 10:51 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Get in touch with Stephen 87 IROC over in the Organized Drag Racing and Autocross board. He's the Moderator over there and he has a T-top car with a full cage. He should be able to answer any of your questions or concerns.
Old Jan 17, 2005 | 11:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was bored and decided to check out some of the other forums when I just found this topic.
I use a Jegs cage which I think is made by S&W. The halo bar is bent enough to allow T-top removal. The bars don't go straight back to the main hoop but are bent inwards. It's a tight fit but I can still unlock and remove my T-tops when I'm working on the car. I made sure of it before welding everything in.
Old Jan 20, 2005 | 12:13 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Re: Re: roll cage for T-tops????
--Dan
Here's a thought......Why not have the best of both worlds?
I know it's not AS safe as having the full cage, but it's better than not having anything. Keep the center bar in place under the T-Top center section and use removable outer bars to connect the rear hoop to the front. Then to keep the roof from collapsing in around you and smashing your skull, use some "gusset" bars to keep the front hoop open in case of rollover. Then You can have your full cage and still have the open feeling when the T's are out.
Old Jul 29, 2007 | 05:16 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I'm not so sure that would be NHRA certified. I'll have to look in my rulebook tomorrow at work too see if it would be legal. I've never heard of removable halo bars.
Old Jul 29, 2007 | 11:39 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I just read my SFI Specs for rollcages. No way would that be legal or certified in NHRA or IHRA.
Old Jul 29, 2007 | 02:25 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i have a competition engineering 10pt. cage in my car and the t-top handles are right above the top hoop.. i can open and close the t-tops pretty easy.. but i never use them since i have windows that open.. i can try get a pic if you want..
Old Jul 29, 2007 | 11:14 PM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
Here's a link to my T-top install, with two bars along the center. Definately not something you can buy in a kit, but a bender and welder would pay for itself if you didn't have to have a shop do something like what you want. You can start with a 4 or 6 pt kit, so you don't have to make the main hoop.
https://www.thirdgen.org/forums/fabr...e-install.html
Old Jul 30, 2007 | 02:13 AM
83 Crossfire TA's Avatar
Steve, I’ve seen pics of yours in a few places… based on what I’ve seen I’d guess you’re fairly short/not that big. From the pictures I’d guess that someone my size would take quite a while to get into your car if they were able to get in at all…
I’d bet that we’d all like to see all the pics we can get…
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
