Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
antenna idea. Needs work....
Old May 30, 2005 | 05:01 PM
Mathius's Avatar
Hi. I'm looking for some help with an idea I had....
I think it would be neat to mount a power antenna so that the tip of the antenna (when retracted) was flush with the top of the rear quarter panel. The antenna would be mounted in the trunk/cargo area, and be nearly invisible when retracted.
The problem is, how would I keep water from running into the hole?
Does this idea have any merit, or will it not work?
Mathius
Old May 31, 2005 | 06:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd think the antenna would seal against it's mounting bezel pretty tightly. You'd probably just have to french the bezel, and to seal the bezel to the car, you could probably just use black silicone.
Old May 31, 2005 | 09:33 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Awesome idea if you're ambitious but a hidden antenna can work just as well, especially with a booster.
Old May 31, 2005 | 11:48 PM
83 Crossfire TA's Avatar
That would be a lot of work to get it to look right and I don’t think that you could ever get it to seal water out, but would be cool. Shaving and relocating is generally the easiest… my brother shaved his and wired the radio antenna connection into the defroster grid. Audis do that from the factory but the defroster grid is also functional in that case, I don’t know how they do that.
Anyone ever wonder why GM got rid of the 2 antenna wires molded into the windshield like they used to do in the 70’s?
Old Jun 1, 2005 | 12:13 AM
Mathius's Avatar
According to my dad, they were only used for AM. I have one in my '76 Malibu. 'Course the radio never worked since I bought the car and it only had 24k on it when I got it.
He also said they didn't have great reception, but AM needs a stronger signal doesn't it? Not sure.
I haven't heard anything good about the "hidden" antenna's. and I don't like the idea of just sticking my antenna under the dash.
The defroster thing is something I've never heard before, and may have merit.
TomP, I think I understand what you're saying, but in order to truly hide the bezel, I'd have to french it into the trunk, effectively making it inaccessable, or else I'd have the same problem, water draining into the trunk.
Frenching the antenna on the outside of the vehicle just doesn't look as good to me on a curved quarter panel such as we have as it does on a truck, where you can mold the tubing into a flat panel.
Mathius
Old Aug 3, 2006 | 07:00 PM
knightrider2278's Avatar
Car: I have a 1987 firebird
Engine: it has a 7.5l 455 in it
Transmission: i have a turbo 400
Axle/Gears: im not sure their factory
am is a much weaker signal thats why you can never pick anything up on it you need to be pretty close to pick up that signal
Old Aug 3, 2006 | 10:06 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
my old blazer had one in the windshield and it picked up fm radio pretty good.
Fast355
Dec 2, 2016 06:33 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
scottmoyer
Sep 7, 2015 07:06 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
