Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
custom lights
Old Jul 11, 2005 | 01:47 AM
Mathius's Avatar
custom lights
Has anyone attempted to make their own custom lights? I think someone did a conversion for fog lights a few years ago with plexi glass.
I was looking at some tail lights. My question is, if you went with just plexiglass, would it look ok and would it perform as well without all the reflective grooves built into the factory plastic lenses.
I was gonna start with something small like tails for my motorcycle before tackling something larger.
Mathius
Old Jul 11, 2005 | 11:27 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Its only going to look as good as your skills at making it. As far as looking ok, i dont really have a good idea of what all you want to change out, if you just want to do the internals, or if your talking about the whole light assembly.
If you want to do something small, change out the 3rd brake light to red LEDs, and still use the cover on them. For NICE and bright LEDs go to LSDiodes
and get some 5mm
They will beat the heck out of Radio Shacks LEDs, with twice the brightness, and almost 50% cheaper.
Old Jul 14, 2005 | 08:15 PM
Mathius's Avatar
I'm talking about making a new housing. My concern is not so much the craftsmanship, but the appearance. I'm wondering what materials would work ok. If I were to use red acrylic plexiglass would it look ok, or be too transparent, and let you see the bulbs inside. I think that would look tacky. Part of the advantages of the "reflector" texture the stock lights have is that it also helps cut down the transparency.
Mathius
Old Jul 15, 2005 | 12:46 AM
357transam's Avatar
Car: 1986 T/A
Engine: 350 bored .040, s/r torquer heads
Transmission: 700r4, tci shift kit
Axle/Gears: stock borg warner
I think if you were going to do it, you would want to use something that would obscure the shapes of the actual bulbs... like you said, you dont want it to look tacky. Maybe if you used a smoked plexiglass or something.
Old Jul 25, 2005 | 12:29 AM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
hey ive did a headlight conversion to my car and the headlight mod ur referring to is redraifs.
Old Jul 25, 2005 | 12:30 AM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
heres another and yes its just like redraifs just mounted differently
Old Jul 25, 2005 | 06:42 PM
Mathius's Avatar
No this was a Camaro fog light, someone replaced the lenses with plexiglass.
Mathius
Old Jul 26, 2005 | 09:53 AM
Firebat's Avatar
look into the stuff they make clear paperweights with.
Old Jul 28, 2005 | 03:16 PM
83 Crossfire TA's Avatar
What lights are those?
Old Jul 28, 2005 | 10:11 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
there cyber whites u can get them at your local walmart or advanced auto....wal marts cheaper
Frozer!!!
Jan 19, 2024 04:55 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
Omega
Aug 10, 2015 12:46 PM
