Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4 corner Hood Pins
Old Aug 22, 2005 | 12:08 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
4 corner Hood Pins
Well, my baby was backed into so now I've had to re-fiberglass the hood. I originally had two locking hood pins on the front, and since the hinges were bent in the accident i decided to go with a 4 corner pinned lift off style hood. I'm having a little trouble with the rear as to where to put the bottom mecahnism on the car itself. I was wodnering if anyone has done this, and could maybe provide some pics? BTW its an ASCD Big Block Hood.
Thanks,
Brett
Old Aug 22, 2005 | 01:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I still only use front hood pins on mine. Even with a fiberglass hood, it's too big and heavy to make it a one person lift off. The extra weight of the cowl doesn't help much either.
Old Aug 23, 2005 | 08:39 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
when I had mine i just threw a couple of pins in the cowl lip, on the driver's side i had to beat in the firewall about 1/4 inch, but it looked pretty good and was sturdy, I'd post pics but I'm deployed and don't have any with me.
Old Aug 23, 2005 | 11:39 AM
Car: 1985 Camaro
Thanks guys, I appreciate the feedback. Sounds good I'll try to post a pic when i finish mine so others will know what to do.
Brett
Old Aug 23, 2005 | 11:06 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
If your gonna do a lift off,dzues fasteners are money well spent.Costs about $50 for all the hardware,but you get none of the flopping and rattling that pins give you.Sucks the hood down nice and solid.
Old Aug 24, 2005 | 04:20 PM
357transam's Avatar
Car: 1986 T/A
Engine: 350 bored .040, s/r torquer heads
Transmission: 700r4, tci shift kit
Axle/Gears: stock borg warner
yeah, i have four hood pins in mine, with just a lift off fiberglass hood. It does flop a lot above 80 or in heavy wind, but its not that bad. Although, at about 130 or so, it acts kinda like a wing, and makes the front end reaaally floaty. I just got a couple of plates and mounted them near the fenders of the car... i get a pic for you in a while.
Old Aug 25, 2005 | 07:29 PM
Car: 1985 Camaro
I would really lvoe to see those pics... Thanks!
Brett
Old Aug 28, 2005 | 01:18 AM
357transam's Avatar
Car: 1986 T/A
sorry about not getting those pics for you yet.. ive been kinda busy trying to get my car to run right again. I will def. have them either tomorrow or the next day...
Old Aug 29, 2005 | 02:02 PM
Car: 1985 Camaro
Well, I finished the hood pins, I made some heavy gauge sheet metal brackets from the hood hinges . I'll post picks really soon!
brett
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
