Cup holder
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Cup holder
Anybody make a cup holder in their center consol? right behind where the power window and hatch release buttons are?
Car: 2011 SS/RS
Engine: LS3
Well this is what i was thinking (yes im real bored lol)
use a car that already has cupholders and mesure the diamater of the cupholder, Then get a PVC pipe of that diamater (find a section of pipe where the inside diamater is the same as your mesurements) Then use the Pipe as your Guide to make the cupholder "hole", if their is not enough room with the switches, relocate them to where the front astray is and mount them there, Then with a sawzall or simmilar, cut out the opening for the cupholder (practice on a junkyard peice first, just incase) After that, put the pice of pvc pipe under the consol and find a way to "mount" it, Ie: Superglue, Epoxy, ect, After that fiberglassthe PVC area and shape how you want it.
Sound doable?
Sound doable?
Car: '89 Firebird Formula
Engine: 305 TBI
anythings doable, id like to see someone do cupholders in the console itself though.. like.. not sure I think 4thgen console is like that
im considering putting a cupholder on the hump right behind the console
would be a bitch to reach, but now that the 5spd is going in I wont have 1 hand free to hold the cup anymore, heh..
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I was thinking of doing that, but I like to rest my arm there, and I have a stick shift, so if it's a tall cup, I might be bumping it...
I thought there was an article on the main page of TGO for making these in the ash tray area (I can't do that either as my flip forward deck is rather long)....
I think you'd want a bit of a draft angle, rather then just PVC pipe, but just a guess...
I'd try to nab a center console (or whatever) with a cup holder, then just cut out the cup holder itself and mount that in to your center console. dropped down such that a normal pop can, can still be picked up, but yet low enough that a tall big gulp won't be super top heavy....
my other thought on the matter was to simply buy a big gulp (or something similar), and mold the cup in.... fiberglass, or just epoxy. then you have the size for any cup smaller then that, and it's got a perfect angle...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's really not as complex as you guys are making it out to be.
A speaker port cut to desired depth, a cap on the end. Cut hole in console, insert port, be done with it.
Consider the air bag module under the console in so eqipped cars before cutting.
2.5"... 3-3.5 would fit something more than a soda can.
A hole saw, I own a variety of sizes for work.
Pilot hole and a saber saw with a scroll blade for wood will work also. Roto tools (ie dremel), I don't know.
Yes, the whole car very dirty, not just the inside.
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
cup holder
Originally posted by Apeiron
https://www.thirdgen.org/newdesign/tech/cupholder.shtml
Car: 1989 Firebird
Engine: 2.8
Re: cup holder
Originally posted by rocluvr0013
I actually helped a buddy of mine do this exact thing in high school turned out looking factory and worked fine for smaller cups and beer... er i mean soda cans
You are NOT cool because you joke about alcohol and driving.
Just wanted to let you know that in case you had a false sense...
Car: 1985 Trans Am
Axle/Gears: 3.70
Re: Re: cup holder
Originally posted by birdofprey83
uh uh beer...derrrrr
Engine: TPI 305/ v6
Re: Re: Re: cup holder
Originally posted by Karps TA
Yeah cause it's way to easy to spill. And that's a party foul.
Car: 86 iroc
Engine: the 305 tpi that could
Transmission: soon to be WC 5spd
Here's a REAL EASY way I did it. I went on ebay and bought cup holder's for pool tables. Perfectly flat. Costs about 3-4 dollars. They are about 3 or 4 inches deep. Then dremel the hole and slide it in. Sorry don't have a picture.
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
You'll get more Ebay hits if you search for "poker table cup holder". There's a lot of them out there, just make sure they're the extra deep variety.
Car: 1982 Trans-Am
that's surprisingly helpful... huh, don't play poker/pool enough to notice that I guess. I'm going for that.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Re: Re: cup holder
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
That i did not know...
Thats kind of scary actually.
Not sure if they stil do, but back when I lived in Wichita Falls, TX they had drive thru liquor stores.
Something like McDonalds. Drive up, order a drink, pay, & drive off with you alcoholic drink in hand.
Car: 1989 Firebird
Engine: 2.8
Engine: TPI 305/ v6
Transmission: TH200C....700R4
Originally posted by roc city f body
damn that looks huge
nice cup holder
Car: 2011 SS/RS
Engine: LS3
Thats not quiet what i had pictured
i was looking for a more flush mount, perhaps if i just cut down that leftover and put some sort of molding around it it would look a lot cleaner
i was looking for a more flush mount, perhaps if i just cut down that leftover and put some sort of molding around it it would look a lot cleaner Supreme Member
just get some factory door panel cup holders.Thats the best way to go.
good luck finding some for a decent price tho
unless you get lucky and score some at a junkyard
I got a driver and pasenger side for 2.00$ each at a j/y once
Car: 92 Camaro (R)eally(S)tock
Engine: 305 TBI
Transmission: Auto 700r4
it would be a lot cleaner if you just cut it down, but i found it is better like this becuase i can take it out if I want (Cleaning,etc)
Its really not that big tho.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I bought a couple of cheap cup holders at Pep Boys (the kind that were meant to hang from the window).
Cut them down and modified them with some Velcro and then pop riveted them on the sides of the center console.
Car: 1991 GTA,1951 ford f1 pickup
Axle/Gears: 3.42 10-bolt
I think I would rather bump a bottle of water in a cup holder than have that hot cup of coffee between my legs spill onto my carpet in front of me. I have a 5-speed also, and driving with any beverage is a PIA.
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
up till october 15 of this year it was legal in montana to drink and drive if under limit, and even now its only like a 100 fine. and the cops have all said they arent gonna pull you over for it, but if you do get pulled over they will ticket it for you
Car: 91' Firebird
Engine: 3.1L V6
Axle/Gears: 3.23's
Originally posted by Xophertony
in texas it is perfectly legal to be drinking an alcholic beverage while driving. as long as you are not over the legal limit of course
no open containers, now passangers can't even drink
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
The whole trick is not to get caught. And if you are able to handle yourself, they can't even tell that you are drunk.
I drove many times like that, although I know my limits, and I am a much more cautious driver than I am sober.
I don't care what you think about that statement, all I know is that its true.
Drink up, and be responsible.
Axle/Gears: n/a
EDIT
this post was turning this thread into a debate on drinking while driving, as nothing i say, no matter how profound, is going to change anyones mind i removed it.
i like the cupholder in the tech artical, to bad that wont work for firebird guys....
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
wow...your an f'ing idiot...i hope you fall in a drunken stupor and kill yourself so you won't reproduce any more stupid people like you.
yeah buddy, drink up, and when you run into someone with your impaired judgement and kill their baby girl, you can explain to them your theory on knowing your limits. it doesn't work that way. alchohol is a depressent, and it slows down how quickly your brain reacts. just cause you *think* you have control...doesn't mean that's how it actually is.
I’ve been resisting adding non technical content to this thread, but I have to point out: if you can’t wait till you get to wherever you’re going to have a drink then you probably have a problem, no mater how in control you think you are.
I was gonna say something, but I decided to be the better man here.
I assure you no one will be hurt by me! Especially little girls at 3am in the morning!
Back to Topic.
Switching to fourth gen console is an answer for anyone who needs a cupholder.
Back to Topic.
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
I have a retracting cupholder unit that looks factory, no pics of it, nor have i installed yet. Haven't found a suitable location, its is just over 1/2 inch tal maybe a 3/4 would fit perfect under the center vents in a camaro, but you take a risk of what ever drink it is spilling on the radio. One salution i had was to move the radio under the vents, the add the cup holder to where the radio was, need a plate or something else in the hole to fill it in but it came as a kit so it also has a pocket piece to go with it.
Car: 1983 Z-28
Engine: 5.0 305 4bbl
Transmission: M5
You know people like you are the reason why every 22 minutes someone dies in an alcohol-related motor vehicle accident. Im 17 and i see that i already have more common sense than you. In the 3 1/2 years i have been in High School, i have been through the loss of 3 people i knew since childhood. All three were killed by a drunk driver.
Yeah youre real funny and cool; you make me sick.
