Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom once peice roof for t top
Old Sep 29, 2005 | 01:27 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
i was thinking of trying to make a custom roof that would be once peice that would fit over the t bar and look like the one peice roofs that the corvettes have. I was think of using some used t tops and fiber glassing over them and trying to use the part of the t tops with the locks and handels with the fiber glass. This whole idea came from trying to find a used t top for the one I lost on the freeway and I found a company that sold a once peice roof for the old 70' s corvettes that have t tops. Any one have any ideas or feed back on the idea?
Old Sep 29, 2005 | 09:42 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Biggest problem with that would be storing it. You'd pretty much have to leave it at home when you took it off.
Old Sep 29, 2005 | 01:45 PM
92Transam's Avatar
yeah unless you made it hindged..... The corvette one fits behind the seats
Old Sep 29, 2005 | 08:22 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
cant hurt to try =) keep this updated .. maybe with pics =D cuz id like to see what it looks like when its done.. or in the process
Old Sep 29, 2005 | 09:35 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i think it would be cool to make a one piece roof but only to get rid of the t-bar. if you made something like the newer corvettes have that you can take that whole piece out that would be tight. but structurally i think it would take alot of work.
Old Sep 30, 2005 | 01:31 PM
92Transam's Avatar
yeah thats been done before on here to a thirdgen
Old Sep 30, 2005 | 03:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Its called a targa top.
Old Sep 30, 2005 | 06:09 PM
92Transam's Avatar
what im looking to make is not a targa top but similar , I know what a targa top is
Old Oct 30, 2005 | 03:46 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by 92Transam.what im looking to make is not a targa top but similar , I know what a targa top is.
This is exactly what I am doing, how strange this is coming across this post. I already cut the T-BAR off, and I just finished welding in steel lips (where the weather-stripping will run, front and back) that runs from one side to the other....
I haven't gotten into any fiberglass fabrication yet, but I did however cut it's shape out of some plywood that I painted black to match the body (temporarily), and simply taped the seems with some black electrical tape (relax, I do not drive her in the rain... and again, it's only temporary until the fabrication is finished.).
92TransAm, lemme know how you're progressing....
Old Oct 30, 2005 | 05:29 PM
92Transam's Avatar
yeah but I don't want to remove the t bar from the car because I plan on droping in a 350 with a supercharger later for about 500-600 hp. I replaced the t tops with a used set from a guy out here off a z28 70 bucks, just had to repaint the edges because they were red .
Old Oct 30, 2005 | 05:53 PM
yeah but I don't want to remove the t bar from the car because I plan on droping in a 350 with a supercharger later for about 500-600 hp. I replaced the t tops with a used set from a guy out here off a z28 70 bucks, just had to repaint the edges because they were red.[/i]
... have you decided yet what you will be using for the one piece? Fiberglass, steel? As for the T-Bar, I could understand why you would want to keep it in tact. But, judging by what I see many Corvette's running these days at the track (both convert, and targa top), it honestly prompted me to cut the freaking thing off, regardless. But again, I could understand why you would want it there though.
Old Oct 30, 2005 | 08:34 PM
92Transam's Avatar
i was thinking fiberglass and metal for the frame
Old Oct 30, 2005 | 08:51 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
fiberglass top would be easy. and you could fit it in the back seats. just hope nonone askes for a ride..lol.
I started back in 03 and desided to just cut it all off and make it a vert.
http://www.cecoatings.com/images/Car.../roofview2.jpg
(vert parts car in the background)
http://www.cecoatings.com/images/Car...gatop/low1.jpg
this is the now
http://www.cecoatings.com/images/Car...s/DSC01193.JPG
http://www.cecoatings.com/DropTopZ.html
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
E_S
Aug 29, 2015 04:09 AM
Dialed_In
Aug 20, 2015 01:45 PM
