Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
velocity stack for 14" air filter?
Old Nov 13, 2005 | 09:37 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
has anyone ever hear of one of these ive only seen small air filters i think it would be a great way to bring my air filter higher into my cowl any ideas on how to make one?
Old Nov 13, 2005 | 10:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can find a 3-4" spacer that fits under the filter housing on many 70's and 80's pickups
Old Nov 14, 2005 | 06:21 AM
Car: 82 z28
Transmission: TH350
yea thats what i have i now dont like the looks of it
Old Nov 21, 2005 | 11:58 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
is this what you have in mind? probably to tall to fit under a cowl hood.
Old Nov 22, 2005 | 06:38 AM
Car: 82 z28
Transmission: TH350
exactely what i have in mind!!
Old Nov 23, 2005 | 04:07 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
are you wanting it to flair out from 5 1/8 to the id of your 14" filter? And if so how tall do you want the piece to be? If you just wanted it to go straight up which i guess that you don't cause that is basically what the setup that you have now looks like. It will take some time and a lot of patience, but if you can find some light gauge sheetmetal (like the kind late models and modifieds use) or aluminum you can fab up a piece, just roll it in the shape of a funnel, and mig, or tig it together then, cut out the section that you need to reach the diameters that you need, You need to have a close idea of what height that you need so you can change the angle of your roll accordingly. It will definetely take some time to make a transition that large. Good Luck!
Old Nov 24, 2005 | 02:23 PM
Car: 82 z28
Transmission: TH350
i think i can do it but i will need a tig welder and they are currently way outta my price range at least until i finish school but i could use oxy i just havnt dont it in a while it think im just gonna find an old air claner base at the bone yard use the piece to go around the carb and the piece to mount the filter and make the rest it might not be to hard once i get the time im pretty good at forming sheet metal i just gotta get a good torch set
Old Nov 25, 2005 | 01:37 PM
83 Crossfire TA's Avatar
It wouldn’t be that hard to spin something like that, but it would take one big lathe and pattern to spin something that large.
What is the point anyway?
Yes, a nicely radiused inlet like that does work, but the filter will act as a much smaller cross section then the opening unless the filter was HUGE so you’re pretty much wasting your time, unless this is all an appearance thing.
Old Nov 26, 2005 | 06:13 PM
Car: 82 z28
Transmission: TH350
i think it would look good and i wouldnt use a lathe i would have to form sheet metal
Old Nov 27, 2005 | 03:41 PM
spinning on a lathe IS a way of forming sheet metal, it's about the only way to form something nice and smooth like that.
Old Nov 28, 2005 | 06:36 AM
Car: 82 z28
Transmission: TH350
hmmm never heard of that is it a special kind of lathe?
Old Nov 29, 2005 | 04:41 AM
Most just do it with a woodworkign lathe
http://www.franjometal.com/metal-spi...-spinning.html
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Thornburg
Sep 1, 2015 03:39 AM
theurge
Aug 21, 2015 12:46 PM
