Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fuel Rail
Old Dec 2, 2005 | 06:21 PM
Persanity's Avatar
Car: 1987 Camaro
Engine: 2.8 soon to be 3.1 Twin turbo
Axle/Gears: No idea ATM
Fuel Rail
Should be the right place for this... How possible would it be to fabricate a fuel rail that was mostly flexable fuel line? maybe just have the part above each injector be solid, kinda like a t fitting above each injector with hoses coming out each side, there can be a main unit if its away from the injectors cause u need the fpr still, i just have really limited space and need to compact stuff in, let me know how easy/hard this should be
Old Dec 2, 2005 | 09:18 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I belive some Caddys had flexable line. Main concern would be leaks. You have more spots to keep an eye on now.
What are you doing that regular rails wont work?
Old Dec 3, 2005 | 12:28 AM
Persanity's Avatar
Car: 1987 Camaro
switching a carbed supercharger to mpfi for my v6 camaro
Old Dec 3, 2005 | 03:27 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Yes they did on northstars, and yes they leak. They have such a problem that there is a recall for mid 90's northstar powered cadillacs. I would stay away from that type of setup.
Is there a lack of room to run a conventional alum. fuel rail?
Old Dec 3, 2005 | 04:25 PM
Persanity's Avatar
Car: 1987 Camaro
i dont have the setup in my hands yet, there might be room but there might not be, i want to make a plate to raise the sc up if they wont fit, but i dont want anything misalligned
Old Dec 4, 2005 | 04:41 AM
Persanity's Avatar
Car: 1987 Camaro
i had an extra mpfi fuel log from my engine swap so i just took out an injector to get a real close look at it, from what i see i can stick the non injector end into a T fitting and run fuel hoses from T to T with the 1st fitting getting the fuel in and the last fitting get the return line, i plan to make a cartridge for the injector to go into with a screw on top or something similar to keep the T fitting firmly pressed onto the injector, i think this set up will well, just need to pressure test it before i use it daily, let me know if you think this idea will work
Old Dec 5, 2005 | 10:27 PM
83 Crossfire TA's Avatar
there are standard body fuel injectors with hose barbs on the end rather then the standard o-ring fittings. If it's really a problem you can use those and run hose right to the injector.
Old Dec 6, 2005 | 12:26 AM
Persanity's Avatar
Car: 1987 Camaro
would giving you a hug and telling you that i love you be too straight forward? lol, do those injectors have a special name? what did they come in? i can make a sick setup with injectors like that!
Old Dec 7, 2005 | 02:44 AM
Might offend my wife...
Bosch and nippondenso made a bunch. As far as I know they were used on assorted European imports that used the D-jetronic FI (like the early FI setups) and some early Japanese FI setups.
There’s also a few bosch injectors that have a top fitting that looks just about like a barb except it only has one ridge on it that was used in a bunch of stuff.
All of them are 5/16” in diameter, so some 5/16 FI hose (or -6 braded) will work.
I’ve also seen some slick, machined aluminum pockets that are built in 2 halves, the bottom half is an injector seat that you would weld or epoxy to the manifold and the top is held down with a couple of screws. A standard injector drops inside, the bottom half holds it to the manifold, the top half holds the injector in and the top half is threaded for an 1/8” NPT fitting which you could connect to anything you want (hose barb, NPT to -4 or -6 fitting and some braided…)
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
