Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
using the cowl on the factory hood????
Old Jan 16, 2006 | 10:46 PM
exodus's Avatar
Car: 88 Formula 350 WS6 (sold)
I want to use it like in this thread, but the only difference is the engine. My intake is on the front of the motor, and i was wondering if people could help me brainstorm some idea's here. I am using an ls1 motor. Thanks for any help in advance.
https://www.thirdgen.org/techbb2/sho...hreadid=328175
Chris
Attached Thumbnails using the cowl on the factory hood????-100_1839small.jpg
Old Jan 17, 2006 | 06:31 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
How much room above the intake?
Old Jan 17, 2006 | 08:54 PM
exodus's Avatar
about 4-5 inches i think, i will have to measure it.
Old Jan 18, 2006 | 06:58 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
What about something like this mounted over the engine near the firewall.
http://www.apmautomotive.com/airboxes/dr_59_airbox.htm
Old Jan 18, 2006 | 02:24 PM
exodus's Avatar
That might work, but the tubing would have to be a little different. My throttle body is farther forward, and would have to routed back to where the opening is in the formula hood. Where did you get the pics from, is it something you can buy, or did you make it?
Old Jan 19, 2006 | 02:59 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Old Jan 21, 2006 | 05:12 PM
exodus's Avatar
Thanks, I am definetly looking inyo that.
Old Jan 26, 2006 | 01:40 AM
b_the_j's Avatar
Car: 92 RS
how about this one
Old Jan 29, 2006 | 09:15 PM
exodus's Avatar
same concept as that, but the opening in the hood is onthe drivers side by the windshield. (formula hood) I would have to find a way to get the filter sealed off, and plumb the intake tube to get there too.
Old Feb 2, 2006 | 01:12 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
You could always fiberglass a tunnel into the hood. Make it 12-18" wide, and 1.5-2" thick, and have it gather the air from the cowl, then run to the front of the hood, where you could use an airbox like abocve, thats made for the Ram Air hoods.
If you can get a shot of an SS hood off of a newer camaro, you can kinda see what im talking about. Basicly its all done in the hood, and when you pop it, it looks nice and clean under it
Only problem is getting the air to channel its way to it. As you want it to be the high pressure air, is moving to the low pressure area of the filter, so that the motor does not have to draw air in, but simply take in whats there. Personnaly i would do a RA1 hood, with the above airbox, it will be the best power wise, and simplicity, just not the cheap route.
Old Feb 2, 2006 | 06:21 PM
exodus's Avatar
I came up with an idea to make a smooth tube from the throttle body to up where the opening in the hood is, and use a whisper lid from a 4th gen that is atached to the hood upsidedown somehow with the same k&n filter that the lid uses, I don't know if it will work, but I have a lid and filter, all I would need to do is run the tube. What do you think?
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
