Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
ram air set up
Old Dec 1, 2006 | 04:54 PM
djtricia's Avatar
Car: 1986 Z-28
ram air set up
I bought a couple air cleaners and am putting together my own dual snorkel set up. But I also got a hold of the tpi V-8 air cleaner set up and am considering adding it to the front middle of the air cleaner too. My question is, is this too much ram air? I have a 305 with a 600 vacuum Edelbrock carb and performer manifold, factory roller cam and headers. Thanks.
Old Dec 1, 2006 | 07:21 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
as opposed to a open element which would be the least restrictive?
Old Dec 1, 2006 | 08:29 PM
Firebat's Avatar
Ram air is just a fancy cold air intake. Air doesn't actually get "rammed" like a supercharger/turbocharger would do unless you are going maybe 200mph but i'm guessing on that speed. Plus, the camaro TPI dual air filter setup is very restrictive.
Old Dec 2, 2006 | 12:10 AM
djtricia's Avatar
Car: 1986 Z-28
But if added to the dual snorkel set up, wouldn't it ad more cold air to the intake?
Old Dec 2, 2006 | 06:23 PM
xpndbl3's Avatar
Car: 1984 Z28
best is cowl hood and open element with a aluminum sheet around the carb to seal the cowl to the hood.
Old Dec 3, 2006 | 11:46 AM
djtricia's Avatar
Car: 1986 Z-28
Can't afford a cowl hood. Going low buck for now.
Old Dec 4, 2006 | 04:41 AM
83 Crossfire TA's Avatar
That depends on the design… to make it work you need a largish chamber behind the opening that is filling it to slow down the air flow filling it and increase pressure, sort of like the diffuser after a turbocharger compressor wheel… the wheel speeds up airflow, and then as the area increases that airflow I slowed down increasing static pressure.
Old Dec 8, 2006 | 11:27 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
I heard of some pple running dryer hose to the front grill and using that for a homemade ram air setup but dont know if that actually works
Old Dec 8, 2006 | 11:39 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
go with the dule air clearner an get some flex dryer tube and run it bhind the gril
Old Dec 8, 2006 | 11:47 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
ha ha someone was thinking the same thing I was must have been a good idea
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
