Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
t/a hood grills !~ cold air intake?
Old Dec 5, 2006 | 04:52 PM
ezliving4ume's Avatar
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
I've been wanting to upgrade my air intake sys. and just havn't found anything I like.
I was wondering If anyone has tried to modify the air grills on a stock t/a hood to operate as cold air engine intake? Could the "Y" air intake off of a thrid gen camaro work? Just flip it over, to collect air from the hood?
What do you think? any chance?
Old Dec 5, 2006 | 07:45 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
I thought about this too, I think it would work, should look good too.
Old Dec 5, 2006 | 07:57 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
There is no room between the rad support and hood.
Old Dec 5, 2006 | 09:06 PM
Car: Forrest 91 t/a
it works on camaro's? isn't that clearence the same?
Old Dec 5, 2006 | 09:31 PM
No.
The hood /fenders on Trans Ams are sloped quite a bit more.
Old Dec 6, 2006 | 06:35 AM
Car: Forrest 91 t/a
SO THE GRILLS ARE JUST FOR LOOKS, TOO BAD
Old Dec 6, 2006 | 10:01 AM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
if you look around on here you will find someone did it to there GTA.
Old Dec 6, 2006 | 03:52 PM
Car: Forrest 91 t/a
I did a seach before I posted, any idea what forum?
Old Dec 6, 2006 | 06:40 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I looked into this,
you have to move the rad down or have the hood lifted to get the right clearance.
Try putting a piece of styrofoam underneath the hood and close it where the intake tube would be, it will crush it.
Old Dec 7, 2006 | 11:38 AM
Car: 1985 Trans Am
Engine: 305 5.0 LG4
https://www.thirdgen.org/forums/fabr...-cold-air.html
this will be the topic i mentioned, and was on this forum on page 2.
Old Dec 7, 2006 | 03:26 PM
Car: Forrest 91 t/a
thank u very much, the thread looks promising. I guess I didn't type the right words into the seach engine. sorry.
Old Dec 16, 2006 | 06:28 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
heck,
on the ta incerts for the hood just cut the back side to let out hot air from under the hood. I did- it probly dose not do much but to each his owen.
later
rk
Old Dec 18, 2006 | 09:19 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Originally Posted by Rick King
heck,
later
rk
you<grammar
j/k with ya, but i dont really think they do too much accept let water drain into then when it rains..they may let some heat out, but not too much
1992 Trans Am
May 10, 2023 07:19 PM
PestilenceIV
Aug 20, 2015 02:33 AM
kyle5647
Aug 15, 2015 11:56 PM
bryan623
Aug 10, 2015 11:33 AM
