Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
got cold air ?
Old May 17, 2006 | 07:39 PM
gtabob's Avatar
got cold air ?
ram air on my 89 gta ws6 u like
Old May 30, 2006 | 03:16 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
can you show some more pics and kinda explain, im not sure whats going on in those 2 pics
Old Jun 19, 2006 | 10:45 PM
gtabob's Avatar
With scoops removed you will see large open area across front of hood, this area is what makes up the cold air duct. Seal the outer edges with sponge trimmed to fit or soft foam. Seal off driver side routing air to passenger side of hood. Air clearer canister is fitted with 90 degree, 3" elbow of PVC. Core support must be trimmed elbow points straight up, air cleaner mounting hold is moved forward 1/4" in canister allowing the assemblly to sit further back away from the core support. When installed a large washer will seal the old hole. Vapor canister front mounting bolt is removed. Canister can be moved over to passenger side slightly allowing room for elbow on air cleaner assembly. Now you can locate where hole in hood bottom will be made, just mark it for now with marker, and a piece of 3" PVC must be fashioned to fit the bottom of the hood and once hole is made passenger side of hood will be sealed off with sponge or foam directing air down through the hole. PVC can be glued with Fuzor EZ100 or equivillant, I reccomend taping it for alignment into elbow on canister when hood is closed. I also reccomend you check your hood allignment before any cutting is done. Flow sensor mounting must be moved to driver side slightly to allow air cleaner canister to sit in desired location, much preperation and time was spent on getting this right. Hope this helps you make your Poncho how it should have been from the factory with scoops that work.
Old Jun 20, 2006 | 03:22 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Can you tell a diff performance wise? Ive seen those vents used for a fresh air charge before, but wasnt sure how much pressure they actually get at speed.
Old Jun 20, 2006 | 05:28 PM
gtabob's Avatar
denser air is always goning to make more power .i also recomend using a hypertec thermomaster prom chip to bring down engine temp for the same reason a k&n air filter to increase flow and a spolier installed in trottle body.to answer your question yes i have much better trottle response when passing at highway speeds over 40 idont know actual air pressure at nose of car but it has blown duct tape off holes i covered.
Old Jun 21, 2006 | 10:55 AM
Car: 87 Firebird
Engine: 5.3 76mm
Thats good to hear. I saw a memeber once, make a fiberglass pan that hooked up to the nostrals, and then closed its self off to the hood, and to the air cleaner on the carb. I always wanted to try that on one of my junk hoods, and now I think I might, and try to do some testing upthere now that the car is running again.
Old Jun 23, 2006 | 01:59 PM
krechj's Avatar
Car: 1896 trans am
Engine: 77' 350 comp cam, headers, tpi, sucky 882 heads
hey thats a great intake system you built! i was just wondering though if the hose from the air filter to the throttle body was k@n or something else. i cant wait to this on my car
Old Jun 23, 2006 | 06:08 PM
gtabob's Avatar
i only changed two peices ,tube from hood elbow on canister the rest is all factory and looks factory but i see no reason why a k&n componet could not be used.
Old Jun 23, 2006 | 07:47 PM
krechj's Avatar
Car: 1896 trans am
hey thanks alot, my intakes an older uglier style so i'll have to see if i can pick up a gta one
Old Jun 26, 2006 | 08:27 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
that is a pretty nifty setup, but i would cutout the original bracing on the hood, block off thepassages that would push air in the wrong directions and fiberglass a new ductway fot the air to pass through
Old Jun 28, 2006 | 07:01 PM
gtabob's Avatar
I did block off all other areas with foam glued in place ,and she gets plenty of fresh air try it you might like it.
Old Jul 1, 2006 | 05:37 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
That is the best intake upgrade I have ever seen. I love my gta hood and have been trying to figer out how to do a clean cold air intake, been thinking bout buying the ram air just for that reason but I wanted to keep the stock look. I will be going to start the work today thank you so much for the idea. I am going to use expanding foam to fill the voids, thanks so much it is so simple and clean and only a third gen guy would even notice it.
Old Jul 7, 2006 | 10:28 PM
gtabob's Avatar
I have thought about expanding foam but was concerned about too much expandsion deforming the hood outer .
Old Jul 8, 2006 | 06:28 PM
johnnyboy's Avatar
that "Great Stuff" expanding foam would be a good idea to block off any escaping air, and it wouldn't deform your hood it would just expand to the sides instead of up and down. you just have to be careful not to use too much of it or it would make the duct smaller.
Old Sep 18, 2006 | 06:21 PM
gtabob's Avatar
i am sure you are right jonny but you cant be too careful with baby
Old Sep 19, 2006 | 05:54 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
excuse my ignorance... but I don't get it. wtf exactly, did he do, besides putting some pipe on his hood, effectively sealing off that pipe? or was sealing that off kinda the point? I don't own a GTA or GTA hood, i have a carbed car with a stock flat hood. is that hole a source of trouble? does it divert air into the engine bay for cooling and reducing engine bay temps? if the idea is to force more air into the stock duct, than it looks good. simple, yet effective. you can always fab some scops and ducting to bring in more fresh air to the engine bay for coling it off. I thin i may do that just because my underhood temps seem to be horrendous since i have a black car (until it's painted. that, and i live in FL. it's friggin hot here.
Old Sep 22, 2006 | 10:10 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
This set-up actually crossed my mind a few weeks ago ... but I just can't justify doing it. With all the twists and bends and constrictions BEFORE you even get to the air filter, my guess is that it loses a lot of its effectiveness
Plus, I would have to cut on my car ... I'm not into cutting on my car
Old Sep 22, 2006 | 12:54 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
That might be too convoluted...
I've also fabbed up a cold-air system on my '89 GTA, & I would guess that it's at least as effective as the one described above.
All I did was
* remove everything from the MAF to the airbox,
* cut the piece of metal that sits beneath the airbox & charcoal canister so that it only supports the charcoal canister,
* then cut a hole in the horizontal piece of metal beneath that (on the other side, it's the piece of metal that supports the battery tray).
With that hole cut, I then used a piece of black PVC tube that exactly fit the elbow that goes to the MAF. On the other side (the bottom), I have a conical K&N filter (that I've secured using a self-tapping screw, as well as being placed on top of the diagonal crosspiece that's right there).
It may look "ghetto" compared to some high-dollar setups, but it has it's advantages. Since the air filter is tucked up in the dead space behind the fender, there's very little danger of it inhaling water, being hit by gravel, etc. It's also completely isolated from the hot under-hood air, & access to it is fairly easy.
If I wanted a "ram-air" effect at speed, I could fabricate a scoop right there, but after doing the research for it (I've been studying aero effects for my Bonneville venture), I found that the benefit wouldn't justify the effort.
Just my 2 cents...
Old Sep 22, 2006 | 01:58 PM
V8Rumble's Avatar
All I did was
Just my 2 cents...
Old Sep 23, 2006 | 07:59 PM
gtabob's Avatar
denser air allways makes more power air flow is direct still looks factory i did hate to cut the car saved pieces only people who know the car notice. some think it is oem
Old Oct 22, 2006 | 06:18 PM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
I have an SLP CAI but that sounds like an interesting idea. Perhaps I can upgrade my SLP box... I'm not to excited about cutting up the box though. I'll give it a thought. A custom box perhaps, so you can take air from both the fender and hood at the same time. Sounds like a project.
Old Oct 26, 2006 | 06:54 AM
Vader's Avatar
I have cold air induction on everything - It was 22ºF this morning.
Old Oct 28, 2006 | 02:19 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
People spend alot of time about cold air yada yada...
If cold air was as great as people made it out to be in the winter time we would all be driving some serious 10 second cars.
It is not about dense air or cold air.
It is about the velocity of the air.
Old Oct 28, 2006 | 03:42 PM
Engine: 350 tpi
theres no HUGE differance but there is a differnce.
Old Oct 28, 2006 | 04:40 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Wow, that's awesome! Never seen that design before. Great idea!
Old Oct 29, 2006 | 03:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The problem is to many folks don't know what cold air really is. A true cold air system takes air directly from out side of the car and ducts it into the engine with no gaps.
The fancy blue filter under the hood with some crapy divider is not true cold air.
True cold air does work. My V6 Bird would get sluggish and lame in stock form when it got hot outside. With a True cold air / ram air setup it runs crisp and responsive all the time. It will rev fast and hard to redline no matter what the conditions are outside. It also lowers my running temps to 185-190 constant with no need for a power suckin fan, unless I sit still for 3-4 mins.
[I also have an aluminum air dam and no AC rad in the way.]
I molded 68 Firebird hood scoops into my stock 86 Firebird hood. Right at the apex of the hood so the scoops face forward to grab mass air.
Nother version, right now its only using one side but soon as I stop being lazy one day Ill cut n weld the 2nd snorkle snout on and run both inner headlights for true cold air. car has/had 4 headlight.
Old Oct 29, 2006 | 03:47 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Cold air, short ram air, and ram air are three completely different things.
The scoops you fabricated do nothing except keep your engine dirty.
Also, your dryer tubing will problem get even more hot than the stock setup. Then material is thinner and would be easier to heat. It would however dissapate heat better which means.... it would be quicker to cool when the car is off. That means nothing while driving.
Like I said it is about velocity not density.
You would see more gains if your dryer tubing was a mandrel bent tube. The air would be used faster and more efficiently. Rather than a rough surface that disrupts air flow.
Old Oct 29, 2006 | 04:00 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Thats basically everything I was going to say.
Old Oct 29, 2006 | 04:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Complete BS, you’re talking out your *** like you know something when you don't.
With my car sucking hot under hood air on hot summer day it would be running 200+ and be sluggish as a snail. With the cold air, ram air it stays crisp and responsive no matter what the condition are. And even better when its cold.
I don't care if you believe it or not.... Real world experience blows your theory out of the water. Feel free to come over any time and see what I mean. Though wait till its 90F+ outside.
Old Oct 29, 2006 | 04:28 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Believe what you want, fact doesn't disappear simply because you do not trust it. Your are falling victim to the belief system. You are wanting to believe your home depot intake works. On a 2.8, the stock intake supplies more than enough air for the engine. By all means it is not the bottle neck of the engine.
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I don't BS on boards for attention. Anyone who wont take my word for it is welcome to come over. My word is good just ask around. I have owned many hot V8s, but there is nutin like a 60* V6 when it runs how it should. On stock temps and stock hot underhood air, they are a dog when warm. Not so when feed cold air. Though some reason most of this board is just full of haters who have some sort of instant grudge with fellow 3rd gen owners with never anything nice to say. A good 30% of folks never say anything nice, they just post to disagree or hate, never to help or say anything nice.
Kind of a shame but from experience most 3rd gen owners I run into are aholes.
Though the board owners can control that.
Oh wait they own 3rd gens too
Old Oct 29, 2006 | 04:38 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Your confused, were talking about colder air temps here, not mass or volume tricks.
Were talking about running colder then normal air into your engine for a real postive effect. No one here believes there is some kind of turbo or ram effect.
colder air temps do make a difference. I can prove that. More dirt is lame, and duh, ram air doesn't do anything but feed your car true cold air.
Its nothing more then a term for having scoops on the hood. Like calling NO2 NOS. There is no real ram air effect unless the scoops were near or past the very nose of the car. As the air just goes right over it in reality.
No one is aruging that but you. Were talking about colder air temps.
Don't assume stuff. Colder air into an engine makes a difference.
But duh there is no added flow or bottle neck stuff. Man your just assuming what you want to hate, your looking for something to fuss about for your kicks. No one said there is any air volum gains. Its just colder then normal air, which does make one heck of a difference.
Old Oct 29, 2006 | 04:45 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Cold air = Dense air.
Dense air does not mean anything. Especially when it is 90 degrees outside and you think that air is dense just because it is sucked through your bumper.
Fast air = Velocity
Which means more air. Which is why we use CFM as a unit to measure airflow. Dense air does not give you more CFM. Velocity will.
Now, does dense air have more velocity? Yes sure it does. But not when you have a dryer tube taking that dense air and make it turbulent.
Old Oct 29, 2006 | 05:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You do know your looking at two different cars??? Next time read everything instead of making general assumptions.
top pic is a 2.8 Firebird with hood scoops RAM AIR BABY, TURBO EFFECT
2nd pic is a Buick 350X V8 station Wagon with a headlight knocked out
Firebird only have 2 headlights that pop up.
Your assuming again aren't ya?
Im talking about colder then normal air. normal air = hot nasty dirty underhood air. Air around an engine is always hotter then from directly outside the car. That hot air coming through the rad goes somewhere don't it?
Though as you keep bringin it up the thermal properties of that hose does not transfer heat in any direction well, or if it could [ is so minute], it couldn't heat or cool the air enough in any direction to make any difference either way.
your turbalnce thing is mute. weather there is a short section of intake sucking air in or a long one, its all turblant untl it hits the throtle blades.
The stock intake works is just like that hose, but with more bumps n deeper valleys.
Old Oct 29, 2006 | 09:21 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I was going by the 2.8 by the side of your name.
I am done listening to your whining. No one is hating, just you. I have nothing against you. I just disagree with you. You do not merely disagree with me though. Take it personal... I do not mind.
When you want to talk cars like adults, give me a PM and we shall have a good time.
Old Nov 4, 2006 | 07:43 PM
305q_ta86's Avatar
Transmission: 5 spd
Woah, woah. Hold on a sec there, bud. It isnt velocity that counts. It's MASS. There is a conversion. If you're sucking in really hot air at a certain volume flow rate, and then you start suking in colder, denser air at the same volume flow rate, because the density is different, you can get the same ammount of air into the engine at a lower velocity. Ever heard of Bernoulli?
Anyhow, you're right about one thing witht he dryer tubing, though you probably didnt know it. Because of air's specific heat capacity and the fact that it would only be in the (heat insulated) dryer tubing a short time, it wouldnt actually have much of a chance to heat up. BUT, since the dryer tubing is pleated, it's relative roughness is really high, resulting in a really turbulent flow of air, compared to the nice smooth laminar flow you'd get from a smooth mandrel bent exhaust pipe taking its place.
Old Nov 4, 2006 | 07:48 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
This is pretty much as pointless as the Horse power vs torque arguement. Everyone thinks they know it all but no one really knows anything. You, gumby, and myself are in the same boat.
These are all theories, no one including myself can provide adequate proof. Can we?
Old Nov 4, 2006 | 10:29 PM
305q_ta86's Avatar
Transmission: 5 spd
No real proof? Well, the law of conservation of mass states that the mass into a system has to equal the mass leaving a system, and since mass is equal to density times volume, and volume flow rate is equal to the area of the inside of the tube times the velocity. So just having a high velocity of air means ***** if the air has no density.
Imagine you flowed 500 litres of a fluid in one minute. And imagine the density of the fluid was 1.5 kg per liter. So 500 x 1.5 = 750 kg of fluid per minute.
Now imagine you flow twice the volume of a different fluid, whose density is only half that of the above. Then you have 1000 l/min x .75 kg/l = 750 kg per minute.
QED. That's proof enough for me.
Old Nov 4, 2006 | 11:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Q-E-D? Did you just say QED on the INTRAWEB? Huh, I no longer feel nerdy at all....
Just for info's sake - "They" say that a cowl induction hood provides more/better airflow into the motor, then a ram air setup. Assuming in both cases the setup is directly over a carb, and the carb is sealed via a pan to the hood.
The ram air, would have higher velocity, but lower pressure. A cowl, will have much higher pressure, and the velocity is lower. Net gain is on the cowl induction side, see pic in this thread:
https://www.thirdgen.org/forums/tech...light=pressure
However, the ram air, as the air hits flow restrictions (smaller cross section piping) it'll.... increase the pressure? Or will pressure drop and velocity increases more? I remember it was bass-ackwards of logic, Ryan, what is it?
In a nozzle vs a diffuser? I think the diffuser, increases velocity, and drops pressure, and the nozzle increases pressure and drops velocity... Yea, that's it, the opposite of what it "feels" like...
Old Nov 4, 2006 | 11:43 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Your analogy means nothing, considering you mentioned velocity is not a factor compared to density, which in fact you said velocity is worthless without density, which would mean your precious density would mean nothing without velocity.
You are contradicting yourself. By saying it is all about mass really.
Think of it like an exhaust system... which density has no real factor. The whole reason mandrel bent tubing is used is because it increases velocity of which the air escapes. Put a sharp bend in a straight pipe and the air loses some velocity which in return adds a questionable amount of restriction.
The same principle would work for your intake. 3" straight tube vs 3 1/2" tube with massive amounts of ridges. The velocity of the straight tube would force more air in than the bigger version with more turbulence.
Old Nov 5, 2006 | 01:08 AM
305q_ta86's Avatar
Transmission: 5 spd
Yeah, same flow rate going thru a pipe, diameter gets reduced, so does pressure. Very counter-logical if you are thinking ideal gas law.
Nelapse, I never said you can have one without the other, what I meant was that both are important and those equations show the relationship. I wasnt trying to get much into turbulence of the flow, though you're right that it'll have a major negative impact.
Oh, and Jay, suddenly I feel MORE nerdy.
Old Nov 5, 2006 | 08:25 AM
  #42
nelapse's Avatar
Car: GTA
Engine: 383 HSR
That was the whole point of all my posts, the fact that it would be more beneficial to have a system that increased velocity rather than rely on density. You are right you never did say you could have one without the other. I never meant to put words in your mouth.
I understand your formulas about mass, but it does not pertain to basic air systems. The whole objective is to make an efficient, air system, inwhich the engine could use everything it needs.
You could have an intake system that can flow 2000 cfm, If your engine only uses 1000, then it really wont make a difference to have an over kill intake system. However, by using velocity, using the right size intake tube you can actually force the engine to draw in more volume of air than which is typically required. Density can do the same, but velocity is more constant.
Plus if your system is not set up for velocity, than then restrictions, and turbulence, turn your density into friction which actually heats the air up to a measureable amount.
You are absolutely right, one factor always affects another. In direct proportions.
Old Nov 5, 2006 | 01:36 PM
  #43
305q_ta86's Avatar
Transmission: 5 spd
Yeah, and I guess it's also easier to get cold air (well, ok, maybe not always on a 'Bird) than it is to actually engineer the ducting required to make sure your cold air efforts are all for naught. Another thing to consider is that even though mandrel bends are way better than crush bends, bends are still bends and they still contribute to minor losses. The screen in the MAF would help smooth out the flow of air to some degree too, but at the expense of some kinetic energy. I guess the best thing to do would probably be to just cut a bigass hole in the front of your hood, run a smooth 3" pipe out of it to a cut cut funnel or something and call it a day. :P
Old Nov 5, 2006 | 02:27 PM
  #44
nelapse's Avatar
Car: GTA
Engine: 383 HSR
a bend no matter what degree is a restriction. The best intake is forced induction at that point it really doesnt matter.
Old Dec 7, 2006 | 03:32 PM
  #45
ezliving4ume's Avatar
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
GTABOB,
I think its a pretty good Idea. Just wondering can you hear the engine sucking the air thru the grills?
I won't bother with the conversation going on about cold air.
Old Dec 7, 2006 | 05:42 PM
  #46
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
hmmm well all this confirms my idea as to how to use the "ram air" slots in the '83 Z28 hoods
I'll use the K&N filter I got at the junkyard, something like 11.5x6.5 or whatever (supposedly came from a SAAB 9000 Turbo), use the bottom of a SAAB air cleaner, and then funnel it through PVC or ABS or whatever kind of tubing
Old Dec 7, 2006 | 10:57 PM
  #47
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Your little air induction system isn't giving you a turbo effect
I think nelapse knows what he is talking about...
People waste too much time being concerned about their IATs
Old Jan 7, 2007 | 03:22 PM
  #48
gtabob's Avatar
yes you can hear air sound from grills in hood.one of my favorite things about the set up
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 2, 2015 02:01 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
kyle5647
Aug 15, 2015 11:56 PM
