Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Camaro cold air induction
Old Feb 16, 2007 | 08:25 PM
MyMaro89RS's Avatar
Car: 89 Camaro RS
Engine: 5.0 TBI
Axle/Gears: stock
I have noticed that there are no cold air inductions kits for TBI 3'rd gen cars. Airaid has a cold air induction kit for chevy Silverados with 5.0, 5.7, and 4.3 TBI engines (part #AID-200-104). Why wouldn't this kit work on a camaro with a little component relocation like the battery or the purge cannister? I have not actually seen these systems, I've only seen them listed in the summit magazine. has anyone done this or seen these induction systems and why would or wouldn't it work? For the price of an HO dual snorkel air cleaner you can get one of these, save a few bucks, and I think it would look better under the hood. Let me know what you guys think.
Old Feb 16, 2007 | 08:44 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Forget that do it yourself...It is easy, and the results are SO worthwhile....Look at the setup I did..Have posted pic's several times...It even looks kinda stock...I used a TPI airbox in the front, and made a hybrid.....Sounds awesome also, not to mention the improved performance..Cost about 35 dollars...Not counting the Filter....Tom
Old Feb 19, 2007 | 10:48 AM
MyMaro89RS's Avatar
Car: 89 Camaro RS
Engine: 5.0 TBI
Axle/Gears: stock
Thanks I searched for stuff but there is just so much info on this site. that setup you have looks pretty cool almost looks stock. did you cut off you snorkel and reweld it or did you just turn it and put a new hole in the housing for the crankcase vent?
Old Feb 19, 2007 | 07:35 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Had to weld it, but man it was worth the trouble...I do want to get a better flex hose on it tho...Next time, I will make the hole on the breather case bigger also.....Dont forget to remove the silencer ring inside the breather case......Tom
Old Dec 9, 2007 | 04:02 PM
cbdub405's Avatar
Car: 1989 Chevy Camaro RS
Engine: 305 V8
Transmission: Automatic
Re: Camaro cold air induction
Can i see sum pics of ur set up??? im tryin to add a cold air intake on my camaro
Old Dec 10, 2007 | 07:16 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
I will try to take some pictures for you............This is one of the best things i've ever done on my car.........I have a chrome Edelbrock also, but if the car goes to the track, or to a drive in, I put my ram air setup on..........Tom
Old Dec 10, 2007 | 11:16 PM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
id like to see a ram air setup on my 92 RS, can sum1 show me some pics or give me a link in my pm box? i would really appreciate it.
Old Dec 10, 2007 | 11:56 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
This is the thread to answer your questions. I been running this setup for years and my car has NEVER run hot no matter what the temp was...and it was very cheap to do...under $100.
https://www.thirdgen.org/forums/tbi/...ir-intake.html
kyle5647
Aug 15, 2015 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
