Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
welding equipment
Old May 11, 2007 | 05:40 PM
Nickofcourse's Avatar
welding equipment
i know how to weld, but i learned on real expensive tig welders and such.
the point of this thread would be to ask what is a good all around welder to work on cars, looking to spend less than 400.
Old May 11, 2007 | 09:09 PM
Mathius's Avatar
Re: welding equipment
Hmm. Less than $400 is tricky.
I have this one: http://store.summitracing.com/partde...5&autoview=sku
Obviously it isn't under $400, but it is fairly inexpensive.
It'll do up to 1/4" which means it's hefty enough to do frames, but will also run .23-.25 wire which runs a nice bead on thin stuff like 18 gauge. (Yes, it will run an actual bead, not burn through, with .25 wire on the low setting. No stopping to tack every 5 inches)
Also, it runs on 110, so you can take it basically anywhere you want to lug it.
They make a smaller model that's just under $400 at Summit, but it only goes up to 88 amps.
Of course you could also try the Harborfreight models. They have a TIG for $200, but it's very VERY limited. Basically it's scratch start and you can use it on sheetmetal, steel and stainless only. That's about it.
I had a HF flux core unit once. Worked ok for what it was. I hate flux core, personally though.
Mathius
Old May 11, 2007 | 09:21 PM
Mathius
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
thank you for the reply and informative post.
Old May 12, 2007 | 09:09 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I'd say save your $ a little longer and get a GOOD welded the 1st time you buy one. This way you won't regreat it later.
I mean whats $150 more for a little better machine.
I used my buddies SP135 + on everything from sheetemtal to box tube and 1/4 thich plate. Seemed to work great.
I have a Millermetric 250 and its a BIG welded. sometimes i with I had a small box like a sp135.
Old May 14, 2007 | 01:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, but with a big 110V unit like that, he then has to rewire his garage for a bigger breaker in there, 30+ amps. Might as well rewire for a 220V outlet, but that's a pricier welder then anyway...
And really, what do you weld that's bigger than 1/4"? I'm really trying to think, and I can't think of anything. Race cage - nope. Turbo charger manifolds are thick, but you're welding to thinner tube, so nope. I can't think of anything really..?
On your car that is? And if you REALLY had to, it's MIG! You can do a wide weaving pattern, or a multi pass weld. Not like you have to worry about inclusions from flux core of stick welding (yea, it's a pain, I hate that).
At least, I'd be more inclined to get a big name brand, over a cheaper overseas harbor freight. You can get miller/lincoln spare parts anywhere in your city, the cheaper lesser known or fly by night type operations you'd have to mail order spare parts, if you can still get them
Old May 14, 2007 | 08:34 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I didnt say he should get a Big machine like I have. If you notice I said a Lincolin SP135+ which is a NICE 110 machine.
Its not hard to run a dedicated plug for a welder.
Old May 17, 2007 | 07:28 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
For 90% of my welding I use a 110v flux core. I also have a lincoln MIG welder, and a few stick welders (a 110v, and a 220v).
For stupid think sheetmetal, the MIG is good. Though, I've found the fluxcore is almost better all around for everything. Notice I say 'almost'. On the thinest of metal, the flux core will blow through. But for most stuff it works.
Here is a good article to read:
http://www.millerwelds.com/education...article62.html
You can get a cheap flux core for around $200, and get a flux/mig for around $300. I think you'll find most of the time you end up using .030" flux wire for most of your automotive projects.
-- Joe
Old May 18, 2007 | 01:13 PM
Mathius's Avatar
-- Joe
I totally disagree. Flux core wire goes bad very quickly and of course there's the slag to deal with.
If he ever tries to do anything like a frame or roll cage, he's going to need to know how to weld without leaving slag deposits.
You can get by with flux core, but a MIG would be way better.
Mathius
Old May 18, 2007 | 01:47 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Mathius
Well, I read the article that miller wrote and I very much agree. I think they're dead on.
-- Joe
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
meeklay812
Oct 1, 2015 03:46 PM
indygene
Sep 26, 2015 11:21 AM
wstephan96
Sep 25, 2015 04:28 PM
