Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
question about roll bar/cage metal
Old Sep 5, 2007 | 09:52 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
is there a difference between mild steel and dom?
Old Sep 5, 2007 | 10:26 PM
Eighty9RS's Avatar
Re: question about roll bar/cage metal
I'm no expert, but I believe technically DOM is mild (1020-1026 - low carbon). From speedymetals.com:
(Drawn Over Mandrel). DOM Steel Tube is produced using uniformly high quality C1020 steel strip and is formed and electric resistance welded into its basic shape. After annealing to produce a uniform grain structure throughout, the tube is then cold drawn over a mandrel to give it these advantages:
uniform concentricity around the central axis,
better ovality,
closer tolerances,
denser surface,
uniform wall thickness,
and higher physical properties.
The cold working process works the weld area to produce a sound, dense, and homogeneous structure comparable to that of the base metal. The weld line disappears, causing DOM tube to be virtually seamless. The surface is superior to that of regular seamless tubing, since the material has been cold drawn from strip steel. The hole is straight and concentric with the outside diameter. DOM Steel Tube may be machined, formed, welded, carburized, and subjected to other fabricating techniques that are ordinarily applied to low carbon steel. The use of DOM Steel Tube gives you a guaranteed micro-inch surface and lower productions costs by reducing or eliminating such operations as boring, honing, and finishing.
If you'll check out onlinemetals.com or speedymetals.com - they both have ALOT of information on different alloys, and what is their qualities, advantages, applications, etc...
Old Sep 5, 2007 | 10:41 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
thanks. i am just wondering if buying the comp engeneering 6 pt cage is a good deal or if i should have someone make it out of dom stuff.
Old Sep 5, 2007 | 11:57 PM
Eighty9RS's Avatar
I thought the CE kits were DOM?..
Old Sep 6, 2007 | 08:10 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
i don't know they say mild steel. but i did not read anything about dom.
Old Sep 6, 2007 | 08:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mild steel is the type of metal. DOM is how the tubes are formed. You could have mild steel or CM tubes and both are DOM.
Old Sep 6, 2007 | 10:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
mild steel is a material.
DOM is a method of forming a tube.
almost every real rollbar or cage kit out there will be made of DOM tubing.. so its not mentioned.
the material changes, so they mention it.
Old Sep 6, 2007 | 10:14 PM
Eighty9RS's Avatar
Ok, so comp. engineering said their kits are HREW - Hot Rolled Electric Welded, which is a form of DOM.
Old Sep 7, 2007 | 08:43 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
ok so the ce kit is an ok kit. also i was wondering i have seen a cage that looked something like this. but i have only seen one in person. would this actually help over being just a 4 point or will it add streingth like a 6pt. I am not going to be in the 10 sec class i just want to add some chassis regidity and still make it easier to get in and out of. also i wanted to keep the stock intoerior.
sorry i am not much of an artist.
Attached Thumbnails question about roll bar/cage metal-rollbar1.jpg
Old Sep 9, 2007 | 07:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its a 4pt with "door bars"
you can buy the door bars separate.
they are not legal for completion use, but i would assume they would still add some more rigidity to the chassis
Old Sep 9, 2007 | 09:36 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
Mild Steel is cheaper, heavier, easier to weld.
Chromoly is expensive, harder to weld, lighter.
Old Sep 10, 2007 | 05:54 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
would the door bars make it a 6pt cage? Competition engeneering has a 6pt cage that has the two door bars. i was wondering if taking the door bars and making them like the way i drew would still make it a 6pt with the tunnel braces.
Old Sep 10, 2007 | 08:04 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Technically it does have 6 points, but because of the way that the door bars are shaped, NHRA and IHRA won't certify it as more than a 4 point cage
Old Sep 12, 2007 | 05:55 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Basicly your going to get into three styles of tubing. You have your standard style welded tubing, DOM, and Chrome molly.
-The comp enginering cage is your standard style tubing for a cage. They take a flat peice of steal roll it then weld the seam. If you look at the tube you can see the seam.
-DOM style tubing is seamless. Its stronger and more expensive. Most all road racing sactioning bodies require DOM.
-Chrome Molly is like DOM but it is stronger. And you can run a thinner wall tubing. Which in turn saves weight. But its expensive.
All and all the best bang for the buck is the Competion Enginering cage. If you can spend a little more monney get the spohn door bars. That way you don't have to cut up the arm rests.
Old Sep 14, 2007 | 09:23 AM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
You also have to TIG weld chrome moly.
Old Sep 14, 2007 | 09:58 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Oh yeah. Good thing you mentioned it.
Vintageracer
Jan 10, 2020 05:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
NiG
Sep 2, 2015 06:54 AM
LittleFranks
Aug 20, 2015 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
