Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
battery tray
Old Feb 28, 2008 | 04:00 PM
Hartmann's Avatar
battery tray
any ideas on where one can find one for a 1986 iroc and what welding one should use to weld it in?
Old Feb 28, 2008 | 07:54 PM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
Re: battery tray
whats so wrong with yours?
just weld a piece of metal down and secure your battery, nothing special needed.
Old Feb 28, 2008 | 08:51 PM
Hartmann's Avatar
Re: battery tray
never thought of that but its around 80% rusted through...
Old Feb 28, 2008 | 08:57 PM
Re: battery tray
cut it out, or grind it away and just do what i said. i dont think you will find a new one for sale, unless someone is kind enough to cut theirs out for you. maybe someone in your area with a parts car.
Old Feb 28, 2008 | 09:48 PM
Mathius's Avatar
Re: battery tray
battery tray is beyond simple to fabricate, particularly if you can access a box and pan brake.
The part that requires a bit of planning and thought is what you want to do for a battery hold down.
Mathius
Old Mar 4, 2008 | 12:44 PM
strokedZ's Avatar
Car: 1987 Iroc-Z
Engine: 383
Transmission: None yet
Axle/Gears: None yet
Re: battery tray
go to summit or jegs and buy a battery box or relocation kit. not to expensive and looks good.
Old Mar 4, 2008 | 06:57 PM
Hartmann's Avatar
Re: battery tray
thanks
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
