Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
pinto rack
Old Apr 16, 2008 | 09:01 PM
runt's Avatar
pinto rack
is any one fabin up some brackets for this swap or are you buying the k member with the mounting brackets instaled?
just trying to see what my options is i already have a k member but it doesnt have brackets
also what are you doin about the stearing arm
thanks for any help you might can offer thanks
Old Apr 17, 2008 | 01:07 AM
Pocket's Avatar
Car: 91 Trans Am
Re: pinto rack
Most aftermarket k members have options of rack
They dont put them on there for free thou
The brackets are very simple, do it yourself
Old Apr 17, 2008 | 08:06 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: pinto rack
racecraft inc has them for 15.00 bucks and inclused bolts. get a billet clamp while youre at it.
made my install very smooth. they are already bent and notched for the tube.
weld and paint.....
Old Apr 17, 2008 | 09:28 PM
runt's Avatar
Re: pinto rack
cool thanks for the help i hated to sell my k member just to get the brackets
and that 600 something bucks for the k member kit i was really leaning tward building my own
wich rack is it that you are using is it the pinto with a bump steer kit thanks again for the info
Old Apr 17, 2008 | 09:54 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: pinto rack
buy the racecraft bumpsteer kit as well.
its a bad boy for the price.
comes with FK rod ends. anodized black too. much more nie than most of the kits for similar prices. i am very happy with their service and pricing.
Old Apr 18, 2008 | 10:26 PM
runt's Avatar
Re: pinto rack
thanks i will do that you have been a major help i have been searching here and ls1 tech trying to find out about this swap for a while know
what peices did you use to make the steering arm work
Old Apr 19, 2008 | 08:26 PM
mike leon's Avatar
Re: pinto rack
how are the manual racks steering effort on the street with 245 on the frt?? also is there a power unit available?
Old Apr 20, 2008 | 10:41 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: pinto rack
pinto rack and the bumpsteer kit. i cut my steering arm off to match that of a mustang unit. ill admit from a dead stop, its harder to turn the wheel than an s10 manual box, but with my arm cut i have my turning radius back. about 80% of it anyway. car doesnt turn bad at all.
the pinto rack would only be last resort, serious mod for weight reduction, IMO.
i saved 34 pounds in hard parts alone. i didnt weigh the bag of bolts that were removed, or the fact i saved some weight with a custom steering shaft.
with a stock steering arm, it will prolly steer fine, there will just be no turning radius.
i wouldnt suggest a rack unless its a serious street/strip car.
Old Apr 20, 2008 | 10:47 AM
mike leon's Avatar
Re: pinto rack
what do you mean by steering arm?? the rack would eliminate that correct?? any pics of what your talking about?
Old Apr 20, 2008 | 10:33 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: pinto rack
the arm the tie rod hooks to off the spindle. its too long, or the rack doesnt have enough travel, whichever way you want to look at it.
i DO NOT ADVISE you do this mod to a stock spindle if you carve corners.
for a weekend car/strip car, its more than strong.
racecraft offers a nie spindle with a shortened arm, but they are 550.00, respectfully. i didnt want my car lowered 2" so i passed on them.
https://www.thirdgen.org/forums/susp...nt-struts.html
2nd to last pic you can see where i cut the arm and welded on a steel bushing.
Terrell351
Jun 13, 2021 01:13 PM
Ed1LE
Sep 30, 2018 09:14 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Thomas
Southern California Area
Oct 3, 2015 05:31 PM
SG91camaro
Sep 5, 2015 10:27 PM
