Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Front Breather Conversion
Old Jun 14, 2008 | 10:07 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Did a search and surprisingly didn't come back with anything on front breathers.
Just finished up mine tonight. I know there are still a few nickle size holes here and there and was wondering how critical it was to seal those up.
TIA.
My fab skills are waaaay behind some of the others around here. Pop rivits FTW!
Old Jun 14, 2008 | 10:55 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: Front Breather Conversion
I think the small holes here and thare are going to be ok, if you can get them filled, go for it, but I would test it and see. The key is to get a pressure drop behind the radiator, and a high pressure zone in front of it. You might consider adding a smallish air-dam under the radiator anyway, even though you are a front breather, the airdam may help to get a good lower pressure zone behind the radiator.
Aero stuff is so hard do visualy though, the best thing to do is go test it. Get to a OT or practice day, and run a few laps watching the temps, and see how she does.
BTW, what class are you running your car in?
Old Jun 15, 2008 | 09:49 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
I've removed the rubber strip at the back of the hood and jacked the stops up at the rear as high as they will go already. This upcoming weekend I'll be racing at Hallet, OK, and we'll see how well it works. I'm running in NASAs Camaro Mustang Challenge series.
*edit* https://www.thirdgen.org/forums/orga...tml?highlight= */edit*
So you're saying to add an small air dam basically where the stock one used to be? I can see how that would work in creating low pressure right behind the radiator, but what about adding a small air dam coming down at the very front of the nose? Would that have the same effect? That would give me a bit more front downforce too.
Old Jun 15, 2008 | 09:56 PM
Dewey316's Avatar
Car: 1990 Camaro RS
for cooling, i would be inclined to put it as far back as possible basicly right at the end of where your undertray is. That should make sure that their is a good low pressure void right behind the radiator.
Doing the airdam at the front for downforce you could do, it may not have that much effect on cooling, or it might. Its hard to say, it would come down to how good of a job it did, at keeping the air out, and how well you are able to extract the underhood air to keep a pressure drop behind the radiator.
I haven't really read up too much on the CMC rules, are you allowed to modify the hood? Puttting some vents/louvers in the hood, right behind the radiator should help a lot also, as this will get that hot air moving out of there, and give you a even bigger pressure drop across the radiator, and should also give you less high pressure area underhood, so it should also help with the anti-lift on the front end.
--John
(waiting for NASA to really get going in the PNW, i would really like to run CMC)
Old Jun 26, 2008 | 07:44 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Hey Gary, how did the conversion work out? I am pretty interested, and would love to hear how it went, and also if you have some more pictures of what you did. (front breather has always been on wish list of things to get to and do)
Old Jun 28, 2008 | 04:32 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
CMC doesn't allow you to modify the hood. I had made my louvers functional before I considered going into CMC and had to cover up the holes to be legal. You're also only allowed to remove so many sqaure inches from the bumper.
pics here...
http://www.fototime.com/inv/A8493E1502C7294
The past weekend at Hallet, OK, it was hot!
The car was running quite hot as well, til I realized that the timing had shifted. I corrected that, temps came down a bit but still high for my liking ~240. I ended up taking off the grill cover. I had previously modified it by cutting the slots all the way along thinking this would be enough. Once I removed it completely and took some racers tape to fill in the gaps at the top/around the airfilters, temps never got over 220. I *think* I still have a 195 thermostat. The radiator is a stock b4c radiator using water and water wetter and I still have one fan.
I'm still pretty new at this racing thing, so I'll admit I didn't keep as close an eye on the gauges as I should have. Next event is TWS in August and I'll keep a better eye on the temps.
Old Jun 28, 2008 | 06:31 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
A 160 thermostat and a dual fan setup would cure the rest of your problems.
How is your first season going so far? I really want to get into this series one day.
Old Jun 28, 2008 | 06:52 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
160 is too low for a sbc, I may put in a 180 later on. I already had the duel fan setup and pulled one of the fans... it's just more weight and it's not really doing anything once you get up to speed. Most guys don't run any fans, but I like the safegaurd of having one if it's a long wait on grid or red flag etc...
So far my season has been a blast. I'm still trying to get up to speed, and this last event I was actually able to keep up and pass some of the guys at the tail of the field. Baby steps.
Old Jun 28, 2008 | 09:31 PM
Dewey316's Avatar
Car: 1990 Camaro RS
If you are running at 220*, then changing the t-stat isn't going to do a thing, the t-stat had been open for 30* already.
I would agree, the single fan is all that is needed as a safeguard, the computers won't turn the fans on about 40mph anyway.
If you saw a 20* temp swing with the front grill off, you may still need to try to get better airflow through there, or get a better pressure drop. Although, running full out like that, I don't know that you will do that much better than 220*. Have you talked with any of the other racers from that weekend, to see what kind of temps they were running? If it was really hot out, it could be that everyone was running in the 220-240 range, in which case your conversion is doing its job.
Old Jun 28, 2008 | 11:12 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Yeah, a few of them were commenting that this was the hottest their cars have ever ran. I'm going to see how TWS is like, then may put on a lower air dam like you suggested.
Old Jun 30, 2008 | 08:02 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I need to pull up the CMC rules. Could you add a wicker-bill to the rear end of the hood, to help it pull underhood air out? That along with extending the undertray, may give you some better cooling, and also some anti-lift on the front end.
--John
Old Jul 10, 2008 | 08:08 PM
stroked_n_blown's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: Richmond Gear street 5 speed
Been debating on building my car to CMC specs..but I think I'm going to go with AIX, get a lot more leeway, and freedom to do what you want with your car, and by golly I want 400 at the rear wheels, and ya just can't do that in CMC.
8.5.2.
A front air dam may be used provided it meets the following requirements:
1. Air dams must fit securely to the body with minimum modifications to the original bumper cover.
2. Air dams must only extend downward from the original bumper cover, with no horizontal sections, and may not protrude beyond the overall outline of the body when viewed from above.
8.5.3.
The slotting, cutting, or drilling of the front bumper cover and underlying bumper structure to provide additional cooling air to the radiator, brakes, or coolers is allowed provided that:
1. No more than 120 square inches of material is removed from the bumper cover
2. No more than 30" total width of material, measured horizontally, is removed from the underlying bumper structure. In no case may a one piece bumper structure be cut into two pieces.
8.5.5. No body component, including the front air dam (spoiler) or lower radiator deflector, shall be lower than 4" measured vertically from the ground.
8.5.6. Hood pins must be fitted. Trunk pins may be fitted. Stock hood and trunk latches may be replaced with clips. The car must be run with the hood, doors, and truck completely closed and securely latched
Even though it doesn't specify it, judging by the intent of CMC to be extremely stock in appearance and function, with the exception of being able to gut your car, the only hood mods allowed is interchanging between cars in the same generation.
Old Jul 11, 2008 | 10:44 PM
83 Crossfire TA's Avatar
heh, doesn't the front air dam on a sock f-body hang down lower than 4"?
Old Jul 12, 2008 | 10:38 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Definetly when you lower the car
There's a rules change coming to fix that, something to the effect that unmodified stock stuff is acceptable.
Yup, that's pretty much the rules in a nutshell, but they're talking of some big changes for 2010.
As far as AIX (why not AI?) over CMC... your wallet must be a LOT bigger than mine.
3tas4me
Sep 4, 2015 01:45 PM
lt1z350
Aug 28, 2015 05:57 AM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
stalkier
Aug 13, 2015 12:59 PM
