Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Installed Breather Cans
Old Aug 3, 2008 | 10:28 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Got my breather cans installed. Pics
Old Aug 4, 2008 | 02:25 PM
jonarotz's Avatar
Car: 91 Z28
Re: Installed Breather Cans
Wow 2 of them? Moroso came out with one that has two 3/8 NPT bungs on it. That is the one I just picked up for $60. They look good though. I installed mine in a similar spot, but I only have one and I made a bracket and mounted it off onto the drvers side.
Old Aug 4, 2008 | 03:49 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Hmmm ill prolly do one plus my PCV... i was considering two pcv's cuz the breather i have now pukes onto my valve cover and looks ugly
Old Aug 4, 2008 | 03:59 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Yeah one is enough but a local talked me into doing two.
Thats the exact reason I did it. Plus I wanted to get rid of my PCV valve. No use in having hot crank case air in my intake manifold.
Old Aug 4, 2008 | 04:43 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
My motor has enough problems not blowin out seals i'll keep my PCV for now.. but i know what you are sayin.
those are nice tho. prices? PN?
Old Aug 4, 2008 | 04:52 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
The cans were $70 per can, hose was $60 for a 6ft length, and $30 per 90 degree fiting, 15 per straight.
Old Aug 5, 2008 | 01:43 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
wow... wat size AN is that
Old Aug 5, 2008 | 06:41 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Wow...Im more impressed with the heater core hoses! haha. Not to say the cans are cool though. I really like how clean the hardlines make things look. And you can tuck them down and mount them. I really like that idea. I might have to steal it.. hehe
J.
Old Aug 5, 2008 | 11:30 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
-12 Line
J.
Thanks it took me a little bit to come up with that. I tired using 5/8 roll of fuel line but it was too hard to get straight. So I ended up using aluminum tube that was about 1/8 thick. Then I used a pipe bender to get the bends. Kind of a pain but it turned out good.
Old Aug 7, 2008 | 09:09 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Wow are those great!
Old Aug 8, 2008 | 12:05 AM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
may sound a bit dumb, but what advantage do breather cans have over regular breathers that sit in the valve cover itself? thanks.
Old Aug 16, 2008 | 08:56 AM
CHAMARO's Avatar
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
cans can be installed on high blowby aps (supercharged/turbocharged) to eliminate spewing oil onto the valve covers, they displace pressure better b/c of size and trap the oil within the can. It is not necessary really to have 2 or to apply them to a NA motor unless it is high comp. Very clean compartment by the way, well done!
Old Aug 16, 2008 | 12:48 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
My valve covers did not have baffles in them. So oil easily went into my breather filters on my valve covers. Then it would leak. So I put these cans in. It fixed the problem. Plus I will possibly be going turbo this winter.
Old Aug 22, 2008 | 10:36 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i need to do this. hum.....
Old Aug 23, 2008 | 07:03 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
ahhh it all makes sense now. thanks guys
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
