Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Front clip/bumper mod
Old Oct 6, 2008 | 02:38 PM
88camaroluvr's Avatar
Has anyone tried this in real life yet? I really want to try something like this with an 89 camaro that had a small engine fire. its a v6 and just about on its last leg so no worries about ruining a good third gen, it would just go to the junkyard otherwise. It seems fesible and would be perfect for an autobody man like me, but its hard for me to start on the car or do a mock up because i'm deployed overseas. I barely have a picture of my blue 88 because I sprayed the clear the day I had to leave. So any help, suggestions, smarta$$ comments, or detailed descriptions/drawings are very welcome. Thanks a ton
(i stole this from iansane on this page: https://www.thirdgen.org/forums/fabr...ody-kit-3.html ) hope you dont mind me using it
heres the BEFORE picture:
Last edited by 88camaroluvr; Oct 6, 2008 at 02:39 PM. Reason: Automerged Doublepost
Old Oct 7, 2008 | 09:14 AM
83TransAmRECARO's Avatar
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
Re: Front clip/bumper mod
that looks awesome... when you start it.. post lots of pics... subscribe..!
Old Oct 7, 2008 | 11:18 AM
jfg455's Avatar
Car: 89 formula *sold*
Engine: 305TPI
Axle/Gears: 3.45 9 bolt
There are companies out there that will mold you the covers if you have a template. You could build the template by cutting up the origanl bumper covers and gluing or riviting them back together. Or make a reverse mold out of fiberglass once you have the shape where you want it. Time consuming and probably expensive but it would look cool. G
Old Oct 8, 2008 | 03:25 PM
Thats a good idea, G. thanks. I also think the fenders would need to be trimmed and maybe shortened in height. The hood might need to be messed with but I plan on using an aluminum hood so I can cut it at will. Also, I assume the bumper impact crushing crap would have to be moved and maybe the radiator support might need to be adjusted.
But like I said I can really get my hands on a Camaro over here. I have only seen one Camaro in Kosovo and its has be messed with a lot. ie put together with assorted parts, bad paint, THOSE SIDE-VIEW MIRRORS, and a strange exhaust. I might just try and send it home to sort it all out. But this doesnt help me with my ideas.
Check this thing out.
Front clip/bumper mod-dscf1078.jpg
Old Oct 9, 2008 | 04:48 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Do you have a front or rear shot? I would love to do this with my car.
Old Oct 9, 2008 | 06:55 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
If you read the origanal post it says that was a photo shop. and just look at the shadow on the front of the car pretty obvious. anyhow that is a pic of a trans am 91-92. There is definatly room in the front to shorten these cars but I don't think there is anyway you could get it that short. Need a place for the radiator and bumper. well good luck with you're project and I hope to see some pics.
Oh and thouse side view mirrors were standred on pontiacs for sure over seas. and that is the first time Ive seen a camaro with tailights for the wider plate looks prety cool. and the mirrors go for quit a bit over hear because they only came on a very small number of cars and always break. So for that perfect resto they are hard to find.
Last edited by 87tpi350,6spd; Oct 9, 2008 at 07:00 PM. Reason: Automerged Doublepost
Old Oct 9, 2008 | 07:42 PM
FYRCHKN's Avatar
Engine: LT-1
I really, really like the rear of the car with the bumper gone. I'm going to have to look into doing that.
Old Oct 10, 2008 | 12:21 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Haha its a third gen/G35!
Old Oct 11, 2008 | 01:51 PM
Goagioou's Avatar
On Probation
good friend
Bump! thx ! --------------------------------very good wow power leveling site:buy WoW Gold, World of warcraft Power Leveling, World of warcraft Power Leveling, wow power leveling, wow power level
Old Oct 11, 2008 | 10:06 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Call me a purist, but I don't like any of it. I like the lines of the cars as they were designed by the general. It makes me think of the el camino camaro noses, which look overly blunt and just too tall in my opinion. But, if you're going to go through with it, this may be worth looking into for you.
Old Oct 12, 2008 | 09:18 AM
I think that in order to match that bumper cover so far up on the fender of the camaro that the fender would need to be sectioned or instead a triangle. the fender support and subframe might need to be adjusted too. that sounds like a lot tho. what do you think?
Old Oct 12, 2008 | 06:18 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
too much work for something that won't make you go faster don't ya think? just my input though.
Old Oct 12, 2008 | 07:51 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I have messed around with the wheelbase on these cars with the Adobe and although it would be really hard to do on a rear car it would look pretty cool to stretch out the front a little and bring up the rear
Attached Thumbnails Front clip/bumper mod-1stock.jpg   Front clip/bumper mod-2front.jpg   Front clip/bumper mod-3rear.jpg
Old Oct 12, 2008 | 07:53 PM
Car: 1989 IROC
Engine: 305TPI
And here is a notch version for the Z06 look
Attached Thumbnails Front clip/bumper mod-4notch.jpg
Old Oct 20, 2008 | 10:34 AM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
I'm going to have to say that I too am a purist like 90firebird said. I really do prefer the body lines of the cars the way the General made them. However, I like the idea that 88camaroluvr is kicking around here, and would really like to see the process and finished project. And as a body man he should have a much better chance at getting it right than a gearhead like me. Go for it man, just be sure to show us all LOTS of pictures.
Old Oct 24, 2008 | 07:32 AM
kahless's Avatar
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
Old Oct 24, 2008 | 10:52 AM
Car: 1989 IROC
Engine: 305TPI
I agree about the pics. Anyone can show a side view of a modified car but the design of the front and rear lights, hood and grille will really tell the tale. Most of the aftermarket bumpers and custom designs I see make the bumpers longer not shorter.
Old Oct 24, 2008 | 01:56 PM
I would really like to keep the front stock appearing. But again I didnt do the picture and dont do photoshop and probably cant. Maybe somebody can help make one.
Old Nov 8, 2008 | 09:43 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
I think it would look pretty cool done to a Bird but not a Camaro. Later.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
69 Six Pack
Oct 5, 2015 07:51 PM
fbirdroller
Sep 2, 2015 10:27 PM
