Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fabrication CAI/RAM air
Old Oct 10, 2008 | 09:45 PM
85z28LT1's Avatar
Car: 1985 Camaro Z/28
Engine: 5.7L 350TPI
Axle/Gears: stock 3:42 open
I want to take the stock airboxes of my 85 z28 thats got a 350 TPI. I want to cut out the plastic that holds the filters, fabricate a pipe that will attach to the front like normal but come straight forward split into a V that comes down and puts two cone filters right behind the grill.
get me?
so the only thing is my brother welds but he cant do alluminium anything think this would be cool? I def think it would be alot more functional than the stock on there too and I wouldnt have to worry about heat sheilds
Old Oct 10, 2008 | 09:54 PM
Stephen's Avatar
Car: 87 GTA
Re: fabrication CAI/RAM air
Sounds like the one Herb Adams (IIRC) did in he mid 80s.
Old Oct 10, 2008 | 11:15 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
do you have a picture of it?
Old Oct 11, 2008 | 02:46 PM
Stephen's Avatar
Car: 87 GTA
Sorry...It wasn't Herb Adams...Just Gale Banks. What does he know about induction anyways?
Attached Thumbnails fabrication CAI/RAM air-gale-banks-tt.jpg
Old Oct 11, 2008 | 02:56 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
I wanted to do this too but i always ran in to trouble when u try to go down by the grill, you need a VERY thin pipe so it will still be just as restrictive if not more then stock i assummed and just gave up lol
Old Oct 11, 2008 | 09:05 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
where do you need thin pipe? Im talking about doing this with a cowl hood so I have more clearence
Old Oct 17, 2008 | 05:42 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Having it wrap around through the wheel well is a good idea... maybe that's the way to go...
Old Oct 17, 2008 | 10:02 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
Old Oct 17, 2008 | 11:12 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by 85z28LT1
Look at the pic in Post #4 & you'll understand what he means.
Old Oct 18, 2008 | 12:31 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
ahhh, I thought he was talking about what I said lol
Old Oct 27, 2008 | 11:17 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I just used dryer duct. I actually noticed a difference too, it actually brings in cold air. Someone on here with a black Z fabbed some up from sheet aluminum (I'm thinking 1meanZ possibly...)
Old Oct 28, 2008 | 01:00 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
you can buy some pretty small flex pipe from advance auto parts an the parts stores in some very long lengths when i worked there.
Old Oct 29, 2008 | 10:42 PM
Wrenchp's Avatar
Car: 1988 RS Camaro
Engine: Undetermined
Transmission: TH400
Axle/Gears: Stock
What about cutting a hole in the battery box on the left side. (the opposite side of the battery) that way you can run whatever you want in it! This is what I want to do to put the turbo system in my RS, only, I will have the battery relocated to the back so that way I can get to and from the aftercooler in the bumper!
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
