Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
CAI Question
Old Nov 1, 2008 | 12:28 PM
bigbird89's Avatar
Car: 86 Firebird
CAI Question
I have a carbureted lg4 (for now), and I have an idea for a simple Cold Air Intake. Couldn't you just cut a 4" hole in the firewall, and run a short length of 4" tubing to a carb hat or regular air cleaner base? This would be simple and not clutter the engine bay too much.
I welcome any thoughts, opinions, or pics!
Old Nov 1, 2008 | 12:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: CAI Question
Where are you going to find 4" to cut a hole, and how are you going to get air into it through the dash?
Old Nov 1, 2008 | 12:42 PM
bigbird89's Avatar
Car: 86 Firebird
Re: CAI Question
Hmm... I may be a little ignorant on the subject, but my understanding was that the cowl vents would route cold air in. Obviously, I haven't gotten beyond the brainstorming phase here...
Old Nov 5, 2008 | 05:06 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: CAI Question
Could relocate the evap canister and run it through there, in the front corner of the car. Down through and in front of the fender well.
Old Nov 5, 2008 | 08:05 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: CAI Question
he means the open area under the wiper arms. yes it would work but it seems like you would hack the car just for a couple HP? good idea in thought but I just would shy away from it
Old Nov 6, 2008 | 12:11 AM
bigbird89's Avatar
Car: 86 Firebird
Re: CAI Question
Yeah, I did mean the open area under the wiper arms. It seems like it would be a pretty clean install without running a tube all the way to the front of the car. I had cosidered running it through the front where the evap canister is, but just trying for something cleaner.
Thanks for the input!
Old Nov 6, 2008 | 08:25 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: CAI Question
Thats the duct for A/C and heat right? I think it would be cool. Just make sure its routed so that no water is getting funneled in I guess.
Old Nov 8, 2008 | 02:02 PM
Feroluce's Avatar
Car: 84 Camaro T-top
Engine: 350cu Interceptor
Re: CAI Question
you can also get the carb tophat fron a mopar or gm truck w/ a tbi style system from any junkyard
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
