Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
pro stock wing / spoiler and chute
Old May 3, 2009 | 07:06 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Heres some pictures of the Ed Quay full body width spoiler I put on the car this weekend, the package is delivered in a wood box lined with cardboard & peanuts. It arrived 2 days after I ordered, all of the need items were included and the fit is beyond expectations !
heres a trial fit up
Old May 3, 2009 | 07:10 AM
Re: pro stock wing / spoiler and chute
Next on the list was the parachute shroud mount from which I made a template from the stock bumper. I used 1/8 6x6 plates and 1 5/8 mild tubing to get a cross bar, added a snub for the 1 1/2 slide in tether mount and braced with some 1 inch mild, all to fit behind the factory bumper cover.
As you can see the f body is not a true square frame, one side longer than the other
Old May 3, 2009 | 07:17 AM
Installing the wing just requires drilling alot of holes and assembling about 1000 6/32 nuts and nylocks, arthritis is the word that came to mind
This fit is unreal!!
Old May 3, 2009 | 07:22 AM
next came the struts and finalizing the bumper, then onto the chute mount!
the chute mount is c/m and is 1/2 tube, I welded some larger tube to the hatch key area and some jack bolts to the bumper to accept the larger tube with 1/4 20 welded into the, I wanted the pack and mount removable since I have a open trailer.
Old May 3, 2009 | 07:24 AM
Old May 3, 2009 | 07:27 AM
I ended up getting a stroud chute and have to get the cable and deployment handle installed as of now but it should be easy compared to this 12 hrs of thrashing! End results
Old May 3, 2009 | 09:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Very nicely done!
Old May 3, 2009 | 10:22 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
that looks great.
the only thing that really gets me is why didnt ed build the wing with a lil extension on the side to use the bottom hole for the stock spolier. if the side plates were made just a lil different, it could save the customer aggrevation of having a hole there or having to spend cash on body and paint work.
thats the best pics ive seen of that wing, and it changed my mind on it after seeing these pics.
the one on the website makes it look horrible and too wide for the car.
thanks for the pics!
Old May 3, 2009 | 11:28 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
gorgeous...i can't wait to be as fast as you so i can do these types of mods to my car, lol!
Old May 3, 2009 | 04:13 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Looks good man very nicely done. I am going the same route with the chute when the time comes.
Old May 3, 2009 | 10:18 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
What mph/time required a chute? It looks great by the way.
Old May 3, 2009 | 10:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
over 150mph i believe is the chute requirement
Old May 4, 2009 | 03:15 PM
Shagwell's Avatar
Car: projects.......
Gawd that came out b-e-a-utiful greeze!
I have got to get some BS projects done so I can get back to doing some fab work.
Old May 4, 2009 | 09:15 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
ok, i'm gonna have to get one now! i'm gonna have one racy suspended fast lookin mid 10s car lol
Old May 4, 2009 | 10:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's not square, it's not symmetrical etc. I noticed that when I tubbed out my car. The wheel well openings are different from side to side. I've noticed a bunch of other side to side differences as well.
I love the look of the Ed Quay wing. I don't know how well one would fit on my car. I don't have a factory deck lid. Mine is just a sheet of aluminum. My factory spoiler seems to be doing fine bolted to it. My car still goes straight at 144 mph. If I installed one of those wings, I'd have to redo my chute bag mount by moving it back a lot more to get it out from under the wing.
I've seen wings on slower cars. Don't know how functional they would have been. A third gen body already acts like a huge wing providing downforce on the whole car. When you look at older cars like a mid 60's Nova, it's a box. Local racer has an early Nova with a wing like that and it only runs low 12's. It also still has 4 wheel drum brakes and he uses the whole length of the track to slow down.
At least with a nice wing like that, it looks like it can go fast. Other than my car is tubbed out and has a full cage, it doesn't look like it can go as fast as it does. Add on a wing like that and people expect it to go fast. Don't forget to put on that mountain motor prostock scoop that sticks up above the roof line.
Old May 4, 2009 | 10:37 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
well yeah thats a given...either that or a dummy blower lol
Old May 5, 2009 | 12:38 PM
Shagwell's Avatar
I was thinking more of the chrome fire extinguisher mounted on the passengers' a-pillar; that way if you do need it you have no chance of getting to it....
Old May 5, 2009 | 03:36 PM
Thanks for the compliments guys! " if you have one it better be fast", it`s all relative I suppose, I`ve seen 11 sec cars with them and yes thats ridiculous, I dunno- 8`s seemed like a good area to introduce the car to one. I always said if I put a chute on it, it would get a wing...I didn`t want to do the chute mount twice. I`ll agree with you stephen, my car @ 158 is still stable, do I NEED the wing?? Probably not but I wanted it.
Old May 5, 2009 | 07:08 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
simply awesome man i love it hopefully one day my car will "need" or can support the look of a spoiler but it wont be anytime sson.
Old May 8, 2009 | 09:26 AM
Was feeling ILL today so stayed home, pushed this thing out of the garage for a picture..(i`m climbing the walls here!)
Old May 8, 2009 | 11:19 AM
Shagwell's Avatar
hmm one day flu on a Friday?
Car looks great though. I've been scared to go to their site to see how much that bad boy is...
Old May 8, 2009 | 11:44 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
its enough ****...its enough lol. i'll be getting his headers one of these days...
Old Nov 26, 2009 | 09:35 PM
badbilly's Avatar
Car: 89 camaro rs
Engine: intercooled f1r procharged 383
Transmission: turbo 400
awesome!!!!! i got the stuff from comp engineering so i have all the little parts, now im gonna get to the garage and get that rear bumper off!!!!
Old Nov 26, 2009 | 11:55 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Nice job. Can you post a close up picture of the struts for the spoiler? If they are made the way I think they are, I think I may have a use for them with one of my new projects.
Old Nov 27, 2009 | 08:37 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Goodlooking car. clean lines. no stickers all over it.. looks like
a Hot Rod.
Old Nov 30, 2009 | 07:10 AM
BMR Sales's Avatar
Former Sponsor
Damn looks good, nice job!
Old Dec 1, 2009 | 09:08 PM
ronnyinwaxhaw's Avatar
Car: 1991 RS Camaro 1979 El Camino
That's awesome. Ed Quay has been all over these cars since they were new. His headers are pricey, but I bet they're super nice. They're 1 7/8" tubes, aren't they?
Old Dec 1, 2009 | 09:52 PM
mw66nova's Avatar
Engine: 7.0L
i'm pretty sure you can get Ed's headers in any primary size you want. a healthy BBC is going to want a 2 1/8" or larger primary tube.
Old Dec 16, 2009 | 07:18 AM
jacksoni's Avatar
Very NICE! Did you pick up anything at the track with the spoiler compared to before the install? MPH?
Old Dec 16, 2009 | 11:49 AM
as soon as your car gets into the 9's you start looking at pulling stuff out of the cars.. like the glass and power seats.. i say
get into the 9's with all the cumfy goody's.. then Just go more power.
with a Bigger eng.. that way you can have all the cumfy goodys when you drive it on the street.. looks like you still have all your Glass on the Car.
thats Fantastic.. the car just plain Looks GOOD! the way it is.
Old Dec 16, 2009 | 08:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
As mentioned way above, I wish the side panels extended down enough to cover the factory spoiler hole.
I still use a factory 3 piece spoiler and even at 144 MPH, the car is still stable. The big wing just looks impressive. On cars like ours which are built like a wedge, they don't need the big wing at the slower speeds like older cars such as a 60's Nova which is built like a brick.
Old Dec 23, 2009 | 05:38 AM
The wing did help, I can drive the big end without white knuckles, generally at speeds appraoching 150 the car did have a "sas-sha" it`s completely gone with the wing, feels like driving an 11 sec car again..in complete control
Old Jan 19, 2010 | 12:11 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Looks killer, but the "kill" switch looks like it might be hard to reach.
Old Jan 19, 2010 | 03:52 AM
yes but at the track they know it's back there some place.. not alot of hunting..
could, add a bright colore to it..maby... but im thinking in real life not photos it stands out a bit more..
i like the looks of the car...Sweet.
Edit:
ooo reach.. was thing hard to see..lol. the track monkeys, they can get to it. it's there.
Old Jan 27, 2010 | 04:03 PM
Thanks, thanks alot...I gotta start working on this thing soon for spring. I absolutely destroyed the pure little 496 mid summer 09` tight stem to guide clearance hung one of the valves slightly in number 8 at the most inopprotune time (top of 1st gear @ 8000 rpm) should be back better than ever this spring...hunting for the 8.7-8.60 zone with a cam change and a little work to the heads.
Old Mar 21, 2010 | 06:40 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
What size tubing did you use for the center post and what size did you use for the piece that slides into it?
Old Sep 17, 2015 | 03:13 PM
kamu's Avatar
Car: 84 Z28
Engine: 400
Transmission: tex racing t101a
Axle/Gears: 4.56
I know this is an old thread, but just letting everyone know that Ed Quay updated the wing design to cover the bottom hole. They also narrowed the back to follow the body lines.
Old Sep 18, 2015 | 11:51 AM
mw66nova's Avatar
Engine: 7.0L
Hmm, that looks great. I wish they'd fix their website so you can see the catalog. What is the cost on one of those?
Old Sep 18, 2015 | 12:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Looks Nice!
Old Sep 18, 2015 | 03:10 PM
kamu's Avatar
Car: 84 Z28
Engine: 400
Axle/Gears: 4.56
$484.00 plus shipping
Old Feb 12, 2016 | 11:01 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
I don't car how unnecessary it is on my car I want it lol, but that price throws me in check for the firebirds and t/a's it will look a lot better because it wouldn't have to go down ad far to cover the spoiler holes, I just want something to be able kinda hide a kill switch back there
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
LilHot
Aug 19, 2015 10:02 AM
Exxon Limited
Aug 9, 2015 08:13 PM
