Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
reparing upper door hinge?
Old Jul 3, 2009 | 06:11 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My upper door hinge needs to be fixed, and I don't know what is the best way of going about repairing it. It is dragging on the ground effect. Any suggestions?
Old Jul 4, 2009 | 01:39 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: reparing upper door hinge?
Replace the pins
http://www.top-downsolutions.com/index.php?cPath=21
Old Jul 4, 2009 | 01:45 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
You'll have to unbolt the door from the body. You should replace the lower hinge pins while you doing this as well, they're only like $15. You'll also need a spring compressor to take the spring off the lower hinge. The upper hinges get cut out with a grinder and the new ones will bolt on.
Alex
Old Jul 4, 2009 | 07:34 PM
I talked to somebody this morning, and he told me he can repair it w/o removing the hinge. He is a third gen techi. Something about drilling out and replacing with a bolt. I didn't quite understand, but I'll look into it. Ever hear of anything like this?
Old Jul 4, 2009 | 07:57 PM
Stephen's Avatar
Car: 87 GTA
Sounds like he thinks he can just put in a bolt in place of the bushings....I sure hope not!
Be OK for a bit, until the HEAVY doors start chewing up the metal of the bolts he slid in as "hinges".
Old Jul 4, 2009 | 08:08 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
That would temporarily fix it, but it would squeak, and probably wear out quickly. Also, that would make it more difficult to fix correctly later. IMO, That sounds like a stupid ******* way to fix it.
I recommend doing right the first time, with a kit like TDS sells.
Old Jul 4, 2009 | 08:44 PM
You are probably *** **** right. Just seems pricey.
Old Jul 4, 2009 | 10:26 PM
Stephen's Avatar
Car: 87 GTA
Welcome to the world of "Only ONE place to get it so......"
Old Jul 4, 2009 | 11:19 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I'm sure there are lots of other places to get them, but, you get what you pay for.
Old Jul 4, 2009 | 11:24 PM
Stephen's Avatar
Car: 87 GTA
Show me then.
Lowers you can get at Autozone. But not the uppers anywhere.
Old Jul 4, 2009 | 11:39 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
http://shop.ebay.com/?_from=R40&_trk...All-Categories
http://www.hawksthirdgenparts.com/doorcomponents.aspx
http://www.top-downsolutions.com/ind...4cf5d60ec00a43
You aren't really saving much, if any, by buying them elsewhere though.
You can also, at least to get upper pins, take them from any '82-'02 F-body, or just make your own.
Old Jul 5, 2009 | 03:03 AM
I'm planning on getting lower pin, but the upper in my IROC is definitly loosie goosie. In the mean time, I put a thin layer of axle grease on my ground effect so it doesn't rubb it away. Gonna get if fixed next week. If I need a new hinge, then it will get one.
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
codeysabatini
Sep 20, 2015 11:36 AM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
