Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
test engine shot
Old Oct 14, 2009 | 12:49 PM
Mell's Avatar
Car: 92 TA Yellavert
Engine: 355
Transmission: TKO
test engine shot
double wishbone conversion
Old Oct 14, 2009 | 12:56 PM
Mell's Avatar
Engine: 355
Transmission: TKO
Re: test engine shot
My mistake - the files are too big
Please delete this post moderators
thanks
Old Oct 14, 2009 | 01:19 PM
Mell's Avatar
Engine: 355
Transmission: TKO
OK lets see
Attached Thumbnails test engine shot-img_0011.jpg   test engine shot-img_0010.jpg   test engine shot-img_0016.jpg
Old Oct 14, 2009 | 01:26 PM
ls six's Avatar
Thats very cool Can you give some details?
I'm slowly but surely working on a bolt in SLA/double wishbone conversion, I noticed the spindle looks like a cast aluminum piece. Is it custom off the shelf for another app or off a production car I didnt consider?
Old Oct 14, 2009 | 02:06 PM
Mell's Avatar
Engine: 355
Transmission: TKO
Just thought I'd post this now that I know it works
the front suspension is:
ccw 18x10 275/35 pilot sport
wilwood 4 piston 14'' brakes
hat n rotors
C4 spinldes
custom steering arms - 1x1/2 in steel bolted with 3 of the spindle rotor bolts
modified AFCO 7inch upper arm - mounted to 1/4 in brackets on 1/4 in support plate
custom 16.8 in lower arms - hyperflex bushings
c4 ball joints
custom kmbr
4rth Gen rack
QA1 10'' - 500lbs spring -
I used performance trends 2D suspension analyzer to determine layout
I cut flat opening across the frame where it protrudes out for the stock spring-
(there were little dimples on eack forward side) and welded a 3/16 inch plate over it
front and back and welded on the upper coil over bracket
I welded a T shaped connecting the front and rear walls of the spring hole in the frame and the back side of that plate for strength - on the drivers side the support for the steering
shaft is welded to that T support
and when I cut the shock tower out I had to weld the seam that ended up on the frame
and I welded and X bar between the frame rails behind the radiator supporting the sway bar mounts
I wanted weight loss and improved handling but most of the weight I lost was due to
the rack conversion, kmbr (weighed 20 lbs est) and the brake package (30 lbs under 1le) because of the extra bracing I added
I just got it on the road - and now tuning - thanks to Mark and autoprom
Old Oct 14, 2009 | 03:06 PM
Mell's Avatar
Engine: 355
Transmission: TKO
Thanks - replies are on your thread
Old Dec 19, 2009 | 03:02 PM
newto3rdgen's Avatar
hat n rotors
C4 spinldes
c4 ball joints
custom kmbr
4rth Gen rack
hey those steering arms look a lot shorter than oem camaro did this pose any problems thanks great work
Old Dec 19, 2009 | 03:07 PM
i mean the c4 spindle steering arms sorry
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
