Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Lightweight hood struts
Old Feb 7, 2010 | 10:35 AM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Does anyone know where I can find lightweight hood struts? I have a duraflex hood that weighs about 15lbs and I removed the stock struts. I have been using a copper pipe since then? I've checked around the web but haven't found anything yet. So does anyone know of a company or individual who offers lightweight hood struts for our cars? I posted this in the body section as well, just in case.
Old Feb 7, 2010 | 12:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Lightweight hood struts
you need the ones for the 82-84? camaros that came with the factory glass hood. I found mine on ebay, try hawks
Old Feb 7, 2010 | 12:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use a factory fiberglass hood and still use the original 87 struts.
Never close your hood by grabbing it at the corners. Always pull down from the center.
Old Feb 7, 2010 | 01:11 PM
tealrs's Avatar
Car: 1991
Engine: 454
Transmission: 4L80E
Axle/Gears: s60 3.73 true trac
go to napa and take your stock ones with you match them to one they have in the store with a lower pressure rate. the pressure rate is part of the part number ex. pt#SPD-GSNI-5200-40 (spd-gsi means ? , 5200 length in/out piston dia. for manufactures info, but the 40 means how much power it has so two struts would yield 80 lbs lift. try this web site might help www.spdhardware.com/ check out the m-struts looks like some thing that would last.
Old Feb 7, 2010 | 03:09 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
eBay sells them. I have the same hood you do, I just havnt bought em yet cause they are $50. Just do a eBay search for 82 92 Camaro hood and search through the listings it will say hood struts w/ fiberglass.
Old Feb 7, 2010 | 03:20 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Better idea: Go to the junk yard and look for struts that cannot hold up the stock hood. They will hold the fiberglass ones fine. Or ask someone that has bad hood struts and take them off of their hands
This is what I did at least.
Old Feb 7, 2010 | 07:36 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
What he said.
Old Feb 8, 2010 | 07:03 PM
Engine: 5.7 LSX
Ok I got some fiberglass hood struts off of ebay. $56 with shipping. They will be here in about a week. Thanks for the input guys!
Old Feb 8, 2010 | 07:51 PM
Axle/Gears: stock
Hey let me know how they work for you, I want to make sure they are worth the money before I get them.
Thanks a lot!
Old Feb 9, 2010 | 09:20 AM
Engine: 5.7 LSX
will do bro. I will also throw up some pics too.
Old Feb 16, 2010 | 05:59 PM
Engine: 5.7 LSX
Thanks a lot!
Ok I got them in and installed them in yesterday. They work GREAT!!!! Here are some pics....
Heres the passenger side
Heres the driver side
And heres both!
They look great and work even better! A perfect fit! No more holding my hood open with a pipe!! Yay!
Old Feb 17, 2010 | 05:19 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Mine were cracking my (free) hood near the hinges so I just use a homemade rod
Old Feb 17, 2010 | 06:20 PM
Engine: 5.7 LSX
you must have been using the original ones for the steel hood. i was too at first but the hood was bowing and really hard to close! these ones are perfect! they hold the hood up just right and close with the least amount of effort. i suggest you try em out!
Old Feb 17, 2010 | 11:25 PM
rybread11's Avatar
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
I agree with what the other guys said incase other people read this thread. Struts that are old/wore out and will not hold up a steal hood are PERFECT for fiberglass hoods. I did the same thing, went to the junkyard, found some that would not hold up a steal hood (on a third gen) walked up to the front and asked them how much they wanted for the wore out (bad) struts. They gave me the stuts with the hinges for 10 bucks and they have worked perfectly for me for the last ten years. You should be able to get some for free or pennies on the dollar.
Old Jul 30, 2022 | 06:21 PM
Brian Laycox's Avatar
Attachment 418507
Attachment 418508
Attachment 418509
And heres both!
But they are installed upside down. Now someone can reply to me in an irate tone for re-opening an old post. That's why these stay in here...so people can get help 2, 3, 5, 10 years down the road if needed. If you don't want future comments, take the original post down.
Old Jul 30, 2022 | 08:32 PM
Engine: 5.7 LSX
Ha!! I just noticed that. Also, I just ordered a new set of hood struts because those ones also started giving out. Literally just installed them a few days ago. So it looks like the “new” ones I got up there lasted about 8 years. Oh well. We’ll see how long these ones last.
Old Jul 30, 2022 | 09:50 PM
I just installed these from Rock Auto. They have the fatter casing like OEM. I bought a set that were skinny and it would almost rip my hood off from the power they had. The ones on the invoice are Stabilus brand. They go up real nice. They make a nice wooshing sound, and slow up as it reaches the top. Im happy. Way better than the skinny auto-zone ones.
Old Jul 31, 2022 | 06:15 AM
Axle/Gears: stock
Somebody needs some attention… it’s like a toddler when you bring a new baby home. “If YoU dOnT wAnT fUtUrE cOmEnTs, TaKe ThE oRiGiNaL pOsT dOwN.”
I could care less if you reopened an old post… kids these days.
Before you take this too serious, it’s a joke. I haven’t been on this site in years but randomly got an email saying someone replied
Old Jul 31, 2022 | 08:23 AM
Engine: 5.7 LSX
Yo!! @92z28camarokid welcome back!
I got the same. Saw the email and was shocked that this old thread was commented on.
Oddly and coincidentally enough, I literally just replaced my hood struts again! What are the odds?
I’m in the final stages of my LS swap now!
Old Jul 31, 2022 | 01:25 PM
Axle/Gears: stock
The car looks amazing man! Soooo clean!
It’s been probably 7-8 years since I sold mine and to be honest I think the next route I’m going to go is to build a ratrod. Just welcomed my second kiddo 11 days ago so buying a project anytime soon probably is going to happen haha
Old Jul 31, 2022 | 09:08 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Good to know. Just changed mine this week. When they are shot, I'll give these a whirl.
Old Aug 5, 2022 | 09:02 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Did you make that lower front lip? Any pics of you making it, if you did?
Old Aug 9, 2022 | 06:15 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
I know this is an older post but in case anyone didn't know, the 1982 Camaro came with a factory fiberglass hood with functioning hood vents. If you look up lift supports for that year you will have a steel hood and a fiberglass hood option.
https://www.rockauto.com/en/catalog/...t+support,1404
Old Aug 11, 2022 | 03:10 PM
Engine: 5.7 LSX
Nope. I wish. But I ordered it from Hawks Motorsports. Love it!! I made a custom under belly for it too. Perfectly flat now.
Old Aug 12, 2022 | 07:53 AM
Engine: LS3
Neat piece. Hope there is more support for stuff like this in the future. I have a 91 Z28 so it won't fit mine.
Guess I will hold out and wait, or maybe someday buy and mod to fit. I saw the side and rear pieces, don't like them half as much.
85projectZ28
Feb 7, 2010 05:48 PM
1BADRZ28
Mar 30, 2006 11:53 AM
importeater2k4
Nov 22, 2005 01:45 AM
1 DwnCam
Aftermarket Product Review
25
Feb 16, 2003 11:40 PM
Camaro350TBI
Jan 13, 2002 10:51 AM
