attempted a mumford linkage for the 92
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I wasn't going to post this, but figured i would throw it out there and see what you guys think. Got bored this winter with no car projects to do and layed out and built a mumford link. Im sure a certain somebody will pop in here and tell me i did something wrong, but hey, thats how you learn. Besides, it was a fun project.
If i did it again, there are a couple details i would do differently, mainly added support for the main pivots, probably make the crossbar out of 2 pieces of 1" square tube and run one bar high and the other low, mounting everything between them for some added stability, but for now this is it.
Thats pretty much all the parts, minus the rod ends and connector tubes, bolts ect. Im using HDMV bushings for the main pivots, if everything works out well i'll have new set machined out of aluminum with real bearings.
The crossmember bolts in place of the stock panhard bar and upper support. I ended up using bolt on LCARB's to mount the axle side mounts, and with bolts and spacers, i allowed for adjustment on the axle side as well to help keep the roll center in the stock location even if you lower the car, and for fine tuning other times.
Now, im sure somepeople are wondering aobut the springs, well i tried my best to keep the stock coil spring locations, but it just wanst going to happen, i couldnt get the axle mounts high enough, and the connector tubes long enough to get enough articulation to keep the setup from binding if you dropped the axle. so...
i have a bunch of parts i can't use now
and i have to use coilovers for the rear, which is fine, but more $$$ than i wanted to spend on this project.
oh, and is the panhard supposed to look like this?
The PO must have backed into something an hit the bar, it was bent toward the front of the car and twisted.
this is kinda how the axle mounts assemble, the v-shaped plate welds to the bumpstop plate on top of the stock axle, and to part of the remaining spring perch. Made me a bit happier because i dont have to weld directly to the axle tube and possibly warp it.
Mocked up without bushings it looks kinda like this
you can see how the axle side can be adjusted. Ignore the sweged tube, its just for mockup, im making 1" tubes with adapters for the rod ends later.
I had to have the connector arms aim inboard a little, its not as much as it seems in the pic since the main pivot bushings are out and everything is really loose and off. Not sure how/if that will affect anything.
i made the little clevis's for the axle side mount, and im not happy with them, so im going to look into making them out of a piece of solid stock instead of welding them together. Hopefully i can manage that myself, or have to get a friend to machine them for me.
Car: 86 Trans Am
Re: attempted a mumford linkage for the 92
So anyway, at the highest setting, the roll height is stock, and i can lower it over 5" is it needed to be. I think its a little overkill, but you can never have too much adjustment right?
The pivots are also really close to the fuel tank, i think i have 1/2" of clearance when they are straight up, thats why half the pivot arms are shorter.
the triangular pivot mounts just touch the heatshield, and the pivot bolts should clear a 10/12bolt with a girdle. I think :fingerscrossed:
Car: 86 Trans Am
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
Just a question. Wouldn't a watts link be easier to make. simpler and just as effective? That what most of the CP class autocrossers use.
Car: 86 Trans Am
its just about the same work as a reverse watts, just an extra pivot, so no massive amount of extra work. The mumford does have benefits above and beyond the watts linkage though, so its work the extra work. Besides, how else has one? Dean hasn't made his yet, and i dont know of any others on f-bodies.
Its different and unusual, so it has a bit of uniqueness to it. It was a fun project too, and some good experience.
im actually getting everything back from powdercoating tomorrow, so maybe this weekend i can get most of it installed, I still have to finish the connection rods and coat them, and a couple other little pieces before its all finished.
Car: 83 Camaro
Transmission: TH350
I will agree with you on that point. Looks like great Fab work, wish mine looked so clean. At least you gave me a great idea how to start building my Watts link with that crossmember.
Car: 86 Trans Am
if i did it again i would make the crossmember more like the fayes2, with 2 smaller tubes running high and low for extra support. That does make it more comples though with more welds, or the need for a square tubing bender.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I haven't looked into this so I don't know, but are your leverage ratio's right?
Car: 86 Trans Am
As for progress, its moving along, had everything coated and its assembled on the car, had to have 2 clevis brackets machined and now im just waiting to get the connector arms and some misc parts back from powdercoating. Had some issues with my coilover setup that needed to be resolved and that took a little more priority over the rest.
Took the time to touch up a couple small spots on the underside that were beginging to pickup some surface rust.
Car: 1991 RS
Engine: 5.0
So...is this a replacement for the panhard bar? Is it for track use only or can it be used on a daily driver?
Car: 86 Trans Am
its on my summer driver, this one is an experiment, might make another one later with some changes
it does away with the panhard
Car: 86 Trans Am
Car: 86 Trans Am
no new pics, ran into trouble with the coil-over setup, lost a lot of time fixing that issue, had some parts machined, and I should have the last of the parts back from powdercoating tomorrow?, had a little delay Then i can put it all together and weld the last of the brackets on the axle.
weather is getting nice and im itching to ge the car out of the garage so i can park my truck for the summer and get some things fixed/serviced on that.
Car: 92 RS
Engine: 305 TBI
Axle/Gears: 4th Gen/3.23/Posi
Well I'll be watching for updates on it... curious to see how ya feel it compares.
Car: 86 Trans Am
finished up the install today, along with the coil-overs and related BS.
went for a spin and nothing fell off, so thats good news!
and i managed to nail the ride height first shot, the spring and lower mount for the coilover were perfect. I was quite impressed, finally something went right.
The car defiantly feels different, but i need a little more seat time, i just took a little trip around town and out on some counrty roads. IT does feel different, but i did install the coilovers and slightly stiffer springs too. The car does turn either direction more evenly and rolls the same way too, the jacking from panhard in gone.
I need to throw it around a bit harder in a more controlled situation and see what happens. But as far as this project goes, it was a success and im happy with the result.
Car: Used to drive a camaro
Sounds VERY cool. This "jacking" effect. I'm wondering if that's what I'm experiencing now. When I take a corner hard (sharper corners more so) it literally feels like the rear end on the side on the outside of the turn literally picks up. I'm sure the tire isn't leaving the ground but it's certainly a weird feeling. I put in a BMR track bar and use an EdelB adjustable panhard. Rest of suspension is all tubular Spohn products + Spohn sub-frame connectors.
Car: 86 Trans Am
i think the jacking is when you turn right?, and if you have the BMR upper panhard relocation bar, its probably much worse because of the altered roll center.
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
How much lifting accually happens? 1/2" , 3" has anyone ever tryed to measure this with the panhard setup?
Car: 86 Trans Am
Car: 1987 IROC-Z
Transmission: TH350
If someone buys me the part I'll gladly test it.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Let me know when you have time to come over and help me start building this for my car Phil
Now that I got the 6 speed in the 73 Camaro I have time to start working on the 91 again!
Now that I got the 6 speed in the 73 Camaro I have time to start working on the 91 again! Thread Starter
Car: 86 Trans Am
you got stuck under my car
if you want to make one, let me know, i have to do a little work and redesign the crossmember and see whats needed to do that, then we can build something crazy for the 91, just dont set it of fire when its done
Car: 92 Firebird
Engine: 4.8 LR4
so the 73 is road worthy again? sweet.
Yes, I DID get stuck under your car, lol. I was about 2 seconds away from telling you to start pulling me by the ankles. Woulda hurt too from the road rash I would have gotten
Yeah I want to make one, no doubt about it. I figure it is out for the count right now, I may as well just go all out and make something nicer than the stock rear end.
Fire? Thats low
If you would stop taking your cars apart maybe you could actually drive them
I am a little surprised Dean hasnt commented on your setup at all.....
Car: 86 Trans Am
i talked to him when i started this, since he plans to produce these one day, he made it clear that he wont post in reguard to this, since his ultimate design is "secret" and he doesnt want sombody to rip it off. I have a good idea of most everything he wanted to do along with this setup, i just dont think its going to be as simple as he thinks. Its a little tight up in there and clearance for everything is limited. I would be interested is seeing what he some up with whenever he builds one, if he ever does.
Car: 86 Trans Am
Car: 83 Camaro
Transmission: TH350
I guess I am just wondering. Other then both bars being low on a mumford, rather then one low and one high on a Watts link, what makes this superior to a watts linkage? Of All of the built up autocross and road race cars that I have seen, most are useing a watts link and the rest have a panhard bar. Just seems like a hell of a lot of work for very little if any advantage. No doubt, it is neat looking but can it really do that much more over a more traditional watts link?
Car: 86 Trans Am
And again, honestly, its not much more work to build than a reverse watts like the Fayes2. Just one extra pivot. you still need axle mounts with the watts and the mumford.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
just a FYI fact, 05 and newer dodge durango's and possibly dakotas had a watts link from the factory.
http://www.dodge.com/shared/2009/dur...durango_09.jpg
the PT cruiser came with one as well.
i imagine that the reason was to let the designers use a really high roll center out back, which would match with a huge front roll bar.
this way you get understeeer that builds progressively, and a cushy ride to boot
Car: 86 Trans Am
Car: 1987 IROC-Z
Transmission: TH350
My uncle's '39 Chevy coupe has it too.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Car: 88 IROC-Z
Engine: 383
Any more pics with the coil overs installed. This seems like an interesting mod.I would love to see an anamation with this setup in motion.
ps. anyone find out how much "jacking" happens with a panhard?
Car: 1987 IROC-Z
Transmission: TH350
That is based entirely on how the car is setup so you will never get a straight answer.
Car: 86 Trans Am
I have to do something with the heat shield, its banging around a bit and is getting annoying.
I'll grab some pics when i get back to the car, maybe this weekend if there is time.
IROCNParts
Sep 24, 2015 10:50 AM
