Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
1,000+ hp 1LE F2 build
Old Dec 29, 2012 | 12:08 PM
  #101
superirocz's Avatar
Re: 1,000+ hp 1LE F2 build
what brand is that steering shaft you have there with the red boot on it. I need a new one to replace my big stock shaft that just touches my new headers
Old Jan 4, 2013 | 07:39 PM
  #102
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
wheres the like button?
I approve your message
Old Jan 6, 2013 | 06:12 PM
  #103
project89's Avatar
Originally Posted by 1LEZ
Mock up stage begins
do i dare ask how much that intake cost ? im going to be looking for something similar soon except with 2 injectors per cyl
Old Jan 6, 2013 | 06:36 PM
  #104
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
http://www.hogansracingmanifolds.com/priceList.htm
Old Feb 13, 2013 | 08:00 PM
  #105
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Wicked build, looking forward to more updates!
Old Feb 14, 2013 | 07:16 AM
  #106
1LEZ's Avatar
Should have some soon. Working on the exhaust and intercooler mounting. As soon as I have more pictures I will post them
Old Feb 14, 2013 | 09:53 AM
  #107
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I was digging the F2 setup, the the TT build should turn out really nice.
Old Feb 14, 2013 | 10:07 AM
  #108
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Originally Posted by ogie
No that is fwhp . At 1400 hp the heads start to become a restriction and to keep the engine under the stock hood I cant run a 18 or 15 degree head so that is what I am limited to. 1500 hp is really leaning on this combo and safe is 1400 hp .I would assume that the car has 1200 rwhp leaning on it using the 20% rule for drivetrain loss .
Talk to chad speier or dr j. They both have 260-290cc 23 deg heads and will handle anything you want. Afr 227's are not in the same league as other heads available out there
Old Feb 14, 2013 | 04:57 PM
  #109
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Sucks about the fire.... Was a sick looking car and I'm sure it will be again! Glad to see the carb gone and FI in the works Also, the turbos should WAY out-perform the blower, but I'm sure you already know that..
Old Feb 14, 2013 | 05:43 PM
  #110
1LEZ's Avatar
I was never really down with the carb but I bought it that way and it really ran great. It ran 11.60's on the motor with a 315/35/17 M/T drag radial and 6.70's on a 200 shot in the 1/8 mile with the same tires. I had already been collecting parts when the fire happened. The F2 was just too archaic and I couldn't run A/C so I make the switch to twins and never looked back. Thanks for all the comments..
Old Mar 16, 2013 | 10:50 AM
  #111
1LEZ's Avatar
A few updates
Attached Thumbnails 1,000+ hp 1LE F2 build-dsc00021.jpg   1,000+ hp 1LE F2 build-dsc00023.jpg   1,000+ hp 1LE F2 build-dsc00024.jpg
Old Mar 16, 2013 | 10:51 AM
  #112
1LEZ's Avatar
More
Attached Thumbnails 1,000+ hp 1LE F2 build-dsc00025.jpg   1,000+ hp 1LE F2 build-dsc00026.jpg   1,000+ hp 1LE F2 build-dsc00028.jpg
Old Mar 16, 2013 | 10:54 AM
  #113
1LEZ's Avatar
A few more
Attached Thumbnails 1,000+ hp 1LE F2 build-dsc00029.jpg   1,000+ hp 1LE F2 build-dsc00032.jpg   1,000+ hp 1LE F2 build-dsc00034.jpg
Old Mar 16, 2013 | 10:56 AM
  #114
1LEZ's Avatar
Last 2 for now. Cold side next!
Attached Thumbnails 1,000+ hp 1LE F2 build-dsc00038.jpg   1,000+ hp 1LE F2 build-dsc00039.jpg
Old Mar 16, 2013 | 12:40 PM
  #115
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
My new favorite thread. Awesome build!
Old Mar 17, 2013 | 06:50 AM
  #116
1LEZ's Avatar
Thanks! It's really exciting for some forward motion. I think the build is as much fun as driving is going to be
Old Jul 20, 2013 | 03:19 PM
  #117
1LEZ's Avatar
A few updates
Attached Thumbnails 1,000+ hp 1LE F2 build-dsc00044.jpg   1,000+ hp 1LE F2 build-dsc00046.jpg
Old Jul 20, 2013 | 03:21 PM
  #118
1LEZ's Avatar
A few more
Attached Thumbnails 1,000+ hp 1LE F2 build-dsc00055.jpg   1,000+ hp 1LE F2 build-dsc00048.jpg   1,000+ hp 1LE F2 build-dsc00053.jpg
Old Jul 21, 2013 | 04:20 PM
  #119
ogie's Avatar
Car: 89 GTA
Engine: 400
Transmission: 400
Axle/Gears: 9 inch 355
Your build is going well !! I am sure you will be very happy when you have it all complete. I have stayed with the F2 on my car and tweaked it some for this season. Last year it was just starting to come around and it broke the AFR 227 casting
This year I upgraded to the AFR 245 casting which is a little more solid and am looking forward to getting some testing in soon with the new F2 engine I had done.
Old Jul 21, 2013 | 09:58 PM
  #120
1LEZ's Avatar
Kudos on your new engine. I am really excited to have some forward motion myself.
Old Jul 21, 2013 | 10:32 PM
  #121
ogie's Avatar
Car: 89 GTA
Engine: 400
Transmission: 400
Thank you, Making a car just the way you want it is a hard task but rewarding as well. Once the car starts taking shape like yours is the anticipation of the final product becomes very exciting. Enjoy that feeling as you earned it!
Old Jul 21, 2013 | 11:07 PM
  #122
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Subscribed! Awesome build
Old Jul 31, 2013 | 08:43 PM
  #123
1LEZ's Avatar
Today's update
Old Aug 30, 2013 | 06:33 AM
  #124
1LEZ's Avatar
updates
Attached Thumbnails 1,000+ hp 1LE F2 build-dsc00091.jpg   1,000+ hp 1LE F2 build-dsc00092.jpg   1,000+ hp 1LE F2 build-dsc00095.jpg
Old Aug 30, 2013 | 06:39 AM
  #125
1LEZ's Avatar
more updates
notched and boxed the frame so the exhaust could be raised for more ground clearance.
Attached Thumbnails 1,000+ hp 1LE F2 build-dsc00078.jpg   1,000+ hp 1LE F2 build-dsc00079.jpg   1,000+ hp 1LE F2 build-dsc00080.jpg
Old Aug 30, 2013 | 07:55 AM
  #126
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
subscribed
Old Aug 30, 2013 | 08:26 AM
  #127
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Beautiful work! Make a skidplate for that oilpan!
I'm really glad you went turbo and plan on driving this thing a lot. You cant hear a radio over an F2 setup... Haha hope to see you at some True Street style races! That thing is going to be a monster! Goodluck and BE CAREFUL when you get it running.
Old Aug 30, 2013 | 08:56 AM
  #128
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
WoW, the intercooler piping made to look like the OEM airbox is awesome!
Old Aug 30, 2013 | 06:24 PM
  #129
1LEZ's Avatar
thanks. I told the fabricator that's the look I wanted and it clears the stock hood too! Thanks for your words....
Old Mar 8, 2015 | 12:31 PM
  #130
nossbc's Avatar
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
any updates on the build?
Old Mar 8, 2015 | 03:32 PM
  #131
1LEZ's Avatar
Nothing post worthy. I have amassed some parts but other than that I am just holding on until the economy makes room for my toy. Thanks for checking in...
Old Apr 8, 2015 | 12:11 PM
  #132
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
subed
Vintageracer
Jan 10, 2020 05:33 PM
da35114
Oct 3, 2010 02:18 PM
light drinker
Mar 11, 2009 11:02 PM
suh weet
Sep 29, 2006 10:33 AM
palric
Mar 1, 2002 07:38 AM
