Pizza Box and Duck Tape
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Spent an afternoon workin on my car. Was gettin tired of the speakers in the sail panels rattlin so i cut up a pizza box and duck taped it down and also did some sound proofing inside with the duck tape
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Re: Pizza Box and Duck Tape
we get that...but why take the time to post pictures and add to the stereotype?
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Yeah, I kind of have to agree with them, I had a couple odds and ends from lowes' plumbing department to replace my LIM pipe fitting when I was in a pinch, I've since replaced it with a nice one piece chrome fitting from summit, but I certainly didn't make a thread and post pictures of my ghetto plumbing fixture setup I had till then...ghetto rigs are things to be ashamed of, not proud of, lol. Now if you post pics of the dynamat and this plate thing, you will probably get some compliments. But unless it was a REALLY, REALLY, REALLY ingenious ghetto rig, you shouldn't show it off imo, lol.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i agree, we find ALL manner of ******* foobars in customers cars.one of my faves is the trans mount made from wood and heater hoses
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
well im new to custom added stuff and customizing and im tryin to see if im starting out good. I have never really attempted to custom anything on my car, so im gonna try to start but ive only had the car for a few months, since i turned 16 in january
Engine: 3.8, 3.4
Just try to remember there is a difference between ghetto rigs, and fabrications, lol. My LIM pipe fitting made out of bits and pieces from lowes, not even all the same metal type=ghetto rig.
Removing the substructure of my fiberglass hood, patching the crack on the corner, pinning it on at all four corners, removing the shocks, hinges, pull cable, latch, and latch bar, or cutting a hole(clean straight cuts) for an access panel to the fuel pump=fabrication. Well maybe not fabrication so to speak, but definitely modifications.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
good point. i hopefully will b able to get some more good modifications in this year on it. but im tryin to start somewhere in custom modification and ill slowly get there
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Basically I think they operate as both a relief path for the HVAC when the windows are up, as well as allow fresh air to circulate when driving. Air enters via the cowl, and exits there.
Engine: 3.8, 3.4
I believe just that, probably to vent moisture so it can't collect in there or something.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
so are they really necessary? or will it mess anything up? I havent really found an anwser on here
Engine: 4++,350 & 305 CIs
those vents are there so your eardrums wont blow apart when you close the door with the windows up..
Well you get the idea.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
well my window motors went out and their stuck down for now so i dont have to worry about it
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Just when you think Little Caesar pizza cant get any better, it acts as ******* Dynomat
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Do like i did, 1/4" MDF, take out that fiberglass cone if its still there. And build a custom box. If you take the metal trim out that mounts to the car, and the speaker mounts to it, you can make a nice size custom enclosure for the speaker , it will get rid of the rattle, and give the speaker great sound(if you build it to the right air vol).
Car: '87 Z-28
Engine: LT1-topped 400
Heck, unless it's an emergency and you won't get home without it, duct tape shouldn't be used at all in any vehicle.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Looks great amazing fab work...
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
LMFAO, what next???
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
seriously just let the thread die..this **** is the cancer that is killing tgo
