Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
The first thing I fabricated for my car
Old Oct 9, 2011 | 08:26 PM
83z28_383's Avatar
Im 18 I bought this 1983 z28 off craigslist and its really been my first project none of the factory gauges worked except for the speedo so I found this piece of aluminum behind my house cleaned it up bought some gauges and made this what do yall think
Old Oct 9, 2011 | 08:44 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: The first thing I fabricated for my car
not too bad for a first attempt . keep up the practice & polish your skills . good luck .
Old Oct 9, 2011 | 08:45 PM
83z28_383's Avatar
Thanks man
Old Oct 11, 2011 | 11:17 AM
83 Crossfire TA's Avatar
Not a bad start.
So here is the deal with making stuff like this look really good- nothing is ever perfect (well, rarely it happens), learn to hide the flaws
- never expose an unfinished edge- either get the edges perfect (sanding drums on a drill work well for curved sections, the closer to the curve radius that you can get the better it will work, and a file is incredibly good at straight edges) or cover them up with something (even a vacuum hose split lengthwise and pushed over the edge looks good, they make door edge trim that is similar but has a strip of glue inside, but it's not as flexible)
- carpenters do this all the time- a reveal is your friend- trying to line bits up and keep them lined up is a pain, a slight step or detail at the edge of things looks decorative, hides slight misalignment and lets face it, 99% of people don't know if you were going for a 3/32" or 1/8" gap/step... so if it moves it doesn't matter as much.
- aluminum will always eventually start looking ratty unless you protect it- paint it, sand it an clear it, polish it... but leaving it like that will always look incomplete in anything but a race car.
- semigloss and textured finishes are your friends- gloss shows off imperfections in the substrate, scratches..., flat shows off dirt, fingerprints, if you get wax or silicon on it it gets uneven... semigloss/satin hides all of this. "hammered" finishes are gloss with a texture which hides the gloss problems (look cool and are usually pretty durable also)
Old Oct 11, 2011 | 11:40 AM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Originally Posted by 83 Crossfire TA
Not a bad start.
Good tips! Thanks!
Old Oct 11, 2011 | 12:44 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Ive got some gray hammered paint that manages to stick my rusty OEM swaybars. Been on there for years - still looks fine. I dont know how in the hell that paint manages to stay adhered to it, but for sure it works!
Old Oct 12, 2011 | 09:22 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Not bad man... I built my 1st gauge cluster when i was about your age and had to re-do it like 10 times before I got it right. a drimel (?) and a vise will be a good investment as the fella above said...
Old Oct 13, 2011 | 09:40 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Overall a good job, but imo you should've taken the extra 5m to go around the edges and holes you drilled with a file or dremel, but other than that nitpick you did a pretty good job I'd say.
Old Nov 2, 2011 | 12:45 AM
mitchberry's Avatar
Car: 99 SS G2
Engine: 389 rwhp ls1 n/a
Transmission: viper spec t56
lol general consensus....
not bad! ...
um.... did you actually get it back into the dash behind all the plastic and stuff?
Old Nov 10, 2011 | 02:37 PM
Goosehead's Avatar
now paint your steering wheel black again, that rust doesnt look good..
and keep up the fabrication!
Old Nov 10, 2011 | 02:54 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Not a bad start.
Very nice encouragment. I always use the cliche "a Good craftsman hides his mistakes and a bad craftsman blames his tools".
Nice job and a lot of effort, I'm sire. Makes you appreciate how much effort some people put into their rides. If it makes you happy, that is all that matters. I think it works! Nice job, at least you had the fortitude to not only try to fix it but put the sweat and $ into making it happen.
Ghettobird52
Jul 5, 2024 11:18 PM
Terrell351
Jun 13, 2021 01:13 PM
kyleb24
Aug 15, 2015 08:24 AM
milk
Aug 10, 2015 06:26 PM
