Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom SFC's
Old Dec 20, 2011 | 07:58 AM
ZROCz28's Avatar
Custom SFC's
i know there are many threads about aftermarket sfc's and custom made, i am hoping to make my own most likely out of box tubing. or maybe roll cage steel, my question is does anyone have any rough demensions for sfc's for an auto z28? i know i can go out under my car and measure but it is a shell right now due to my motor rebuild, and its very cold and uncomfortable in a stone driveway haha. any help is apprieciated. - Ray
Old Jan 7, 2012 | 02:52 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Custom SFC's
https://www.thirdgen.org/forums/susp...on-thread.html
post #16
Old Jan 7, 2012 | 03:20 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Custom SFC's
When i built mine i just used string and tape as a guide to estimate the length of tubing and how much i needed... the whole thread can be found here:
https://www.thirdgen.org/forums/fabr...al-design.html
Old Dec 22, 2012 | 03:22 PM
ZROCz28's Avatar
Re: Custom SFC's
thanks haha
Old Dec 22, 2012 | 03:30 PM
Twin_Turbo's Avatar
Re: Custom SFC's
Home made. Not as intricate as FueldSouls (because I had no room for the inside SFCs)
Old Dec 23, 2012 | 11:54 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Custom SFC's
Bundle up and get to measuring
Personally, Id get a pre-made set because they're all around $200. Factoring time and materials in, you wont be far off that in your custom set unless you have additional needs. For mine, I needed a rearward trans mount for the 4L80E crossmember and a torque arm mount. None of the options suited, so I built these
Being an empty shell doesnt mean you cant install the SFCs. Just ensure the doors open/close properly. 3rd gens are a floppy noodle without SFCs and they help greatly, but dont expect it to be as solid as a rock with a handful of short tubes welded in the middle
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
