Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fabricating an air dam?
Old Feb 18, 2012 | 08:33 PM
Slayerx666's Avatar
I have no airdam. Does anyone have a pic of one off the car? Is it something I can just fabricate out of sheet metal? Im assuming that it's something I must have?
Old Feb 18, 2012 | 09:17 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Fabricating an air dam?
Yes you should, there is a thread around here that has all measurements and shows exactly how its done. I will try and find it for you.
Old Feb 18, 2012 | 09:21 PM
Engine: MPFI
Here you go slayerx https://www.thirdgen.org/forums/cool...their-own.html
There are other links as well, just put airdam in search bar, you might find what your looking for. I saw a few on here pretty cheep also. look in the sales forums.
Here is another one.
https://www.thirdgen.org/forums/fabr...t-air-dam.html
Old Feb 18, 2012 | 09:40 PM
Slayerx666's Avatar
Weird I searched airdam and just got threads where air dam was mentioned, like scrapping on the ground. I didn't find anything good. Thanks for the info.
Old Feb 18, 2012 | 10:25 PM
Slayerx666's Avatar
I think the easiest way for me will be a sheet metal piece. And if it gets banged up an kit make another lol.
Old Feb 18, 2012 | 10:46 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Try something more descriptive like..."make your own air dam (or airdam)" not just "airdam". Or "custom airdam" or "fabricated (or fabricating an) airdam".
Simple 1-words searches for anything is rarely successful.
Old Feb 18, 2012 | 10:47 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
bad thing about sheet metal is that it only flexes once then it needs either adjusting or replacing. you can make your own from plastic, that's what a lot of guys do in dirt racing where cooling efficiency is so important in a harsh environment.
https://www.performancebodies.com/Pr...l.aspx?pid=880
Old Feb 26, 2012 | 09:37 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
I made my own, here it is.
Old Mar 8, 2012 | 04:35 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
I also went for a plastic airdam in the end. Mostly because these things take a beating and I had to replace it once already because I hit a speed bump.
Easiest way to go about it is to pick up a piece of metal, bend it at an 80° angle, drill holes to make it fit the radiator support (you need to cut out a small piece in the center. About 2" or 3" wide because the radiator support has a small bump there)
Then drill some holes to fit your plastic airdam and pick up a piece of high density styrofoam or the material chevyracingrox posted a link to.
Looks a bit like this when done:
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
