Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Aluminum STB
Old Mar 29, 2012 | 10:15 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Aluminum STB
Thought I would try out an idea I had for a strut tower brace. Its made with three pieces of 1/8" aluminum making it 3/8 "thick and 2" wide. The thought was to design it like an I-beam for strength. Still have to finish the back two bars to make it a three point design before mounting it to the towers for some testing.
Old Mar 29, 2012 | 10:34 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
some pictures sitting in the car
Attached Thumbnails Aluminum STB-211-1280x960-.jpg   Aluminum STB-212-1280x960-.jpg
Old Mar 29, 2012 | 07:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Aluminum STB
thats a different approach. Should be sturdy enough i would think
Old Apr 1, 2012 | 01:02 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Aluminum STB
although interesting. Not sure on the strength at all. Rivets and aluminum not a good mix. most aluminum STB that you see is made from tubing, welded with rod ends... which is much stronger than that.
Creative yes... structually not so much.
Old Apr 1, 2012 | 02:50 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
Those are actually stainless steel button head bolts. its actually quite strong, I tried bending it before I mounted it in the car Friday. I have only put 20mi on it so far, so we will see how it turns out.
Old Apr 1, 2012 | 02:57 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Aluminum STB
Myself also have been fabricating my own STB with moly pipe I got from work. Was very unhappy with the one they sell for my 83 Camaro. Will post some pics asap.
Old Apr 1, 2012 | 03:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Aluminum STB
Originally Posted by 85Z28NOS
Those are actually stainless steel button head bolts. its actually quite strong, I tried bendind it before I mounted it in the car Friday. I have only put 20mi on it so far, so we will see how it turns out.
since its bolted together now, you have the option to take it to a welder and have it welded up
Old Apr 1, 2012 | 05:07 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
YES, excactly. Like I said, this was a trial of a design I thought of. I know the aftermarket industry is using tubing and rod ends(which I had also made but was un happy with). There final goal is to make money, so they use what is inexspensive and easy to fabricate. My final goal is something strong, lightweight, and not over priced.
Old Apr 1, 2012 | 05:17 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Re: Aluminum STB
Rivets and aluminum not a good mix? Quick, someone let the aviation industry know this!
Until the word gets out, don't fly on any planes.
Old Apr 1, 2012 | 05:37 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: Aluminum STB
:twothumbsup: I was thinking the same thing. many and many of bucked and popped rivets in the sky.
Old Apr 3, 2012 | 10:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Aluminum STB
Riveted aluminum, when done properly, is stronger than welding. The introduction of heat causes aluminum to weaken and become brittle. Snowmobile chassis (in addition to aircraft) is a good example. Newer, lighter sleds use more rivets and less welds in order to make stronger, lighter chassis.
Old Apr 3, 2012 | 06:31 PM
Edwardgp's Avatar
Engine: 454-350
Re: Aluminum STB
Well now I don't want to get in the middle but the last post Jim85IROC make sense to me. Of coarse who am I?
Old Apr 4, 2012 | 04:18 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
I have now put 250mi on car commuting back and forth to work in Dallas traffic. I love how it tightened my front end and eliminated some more rattles just like when I added my sub frame connectors. These cars seem to like it when you strengthen/stiffen the chassis.
Old Apr 4, 2012 | 06:01 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Aluminum STB
very cool! its nice to see someone think outside the box. it looks pretty strong. heres a pic of a tpi brace i made a few years ago. not aluminum though. Name:  040402_060800.jpg
Old May 26, 2012 | 05:57 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
Realized I never posted the final version. Turned out pretty good and solid. holding up great without any problems
Attached Thumbnails Aluminum STB-001-1280x960-.jpg   Aluminum STB-007-1280x960-.jpg   Aluminum STB-008-1280x960-.jpg
Old Nov 8, 2019 | 05:48 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
I had added a brake booster brace to my strut tower brace after reading about another member on hear
showing how much flex they have. This brace has been on the car for a number of years now and have had zero issues or failures. Plan on building a new version soon for my Firebird
Old Nov 8, 2019 | 11:26 PM
Firebirdwade's Avatar
Car: 1989 Pontiac Firebird
Engine: 383
Transmission: WCT5
Axle/Gears: 3.23Posi
Re: Aluminum STB
The question is: when are you going to polish it?
Old Nov 9, 2019 | 06:52 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Aluminum STB
A polished billet piece would be really cool.....and really expensive, lol
Old Nov 12, 2019 | 10:33 AM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Re: Aluminum STB
I like the look of it. Nice work. Could you expand on the brake booster brace? I've never heard of that.
Old Nov 12, 2019 | 12:49 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
check in the brake section for master cylinder brace.
I took a video of how much movement i have after installing it. Currently awaiting the swivel end for the bolt i used as i only have the bolt end rounded off
Old Nov 21, 2019 | 11:43 AM
VortecZ's Avatar
Car: Camaros
Re: Aluminum STB
I like the idea and it gives the engine bay an interesting look.
I took a different approach to an aluminum STB on my old race car. I just used an aftermarket aluminum panhard bar and welded brackets directly to the strut tower. It was very quick and easy to do and worked great. This method could work on a TPI car too if you bend the bar.
Old Nov 21, 2019 | 05:11 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
You have a very clean engine bay, and i like the ease of removal of yours. Oddly enough i have an aluminum panhard bar on my car i bought from a local member. I have A slightly modified design that will run down the side of the strut tower as well as along the top going onto my Firebird. There is no wrong way to brace these as i noticed alot of difference adding mine. Just comes down to what fits with your engine combo. I think the Carb/TBI gives a little more needed clearance in the front for a straight across approach
Old Nov 21, 2019 | 05:24 PM
Car: 87 TA clone
Re: Aluminum STB
Here’s what I ended up doing. DOM 1.25”x1/8” tubing. 1/4” plate on the tower which has tabs welded on and the caster camber plates bolt through everything making the whole tower thick and sturdy.
Old Nov 21, 2019 | 06:12 PM
NoEmissions84TA's Avatar
Re: Aluminum STB
I love the simplicity of this. I'm going to have to copy it now!
Old Nov 22, 2019 | 11:55 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
I dont think i ever saw anyone run the brace on the backside of the strut mount like that. Very nice. Quick question, what washer tank are you running. Love the car
Old Nov 22, 2019 | 02:11 PM
Car: 87 TA clone
Re: Aluminum STB
it was necessity, the bar wouldn’t fit forward of the motor as the hood insulation is knotched for the map sensor bc it’s so close. Lots more room on the firewall side.
it’s the stock washer tank from my 87 formula. I’ve converted it to my water meth reservoir.
Old Jul 17, 2020 | 08:31 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Re: Aluminum STB
I made a new version of an Aluminum strut brace for my firebird after getting the idea from modifying the original to clear a HSR. This has 2 1/4"X2" aluminum flat stock bent and bolted together. still need to finish up the back point
bars as i am waiting on some parts to complete
Old Jul 19, 2020 | 12:57 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Re: Aluminum STB
Looks good. Let us know how it performs and how it holds up over time.
robertfrank
Fabrication
27
Apr 2, 2014 12:21 AM
85z28nb
Fabrication
Nov 30, 2008 06:21 AM
weigesco
Fabrication
Mar 20, 2006 09:24 PM
Air_Adam
Fabrication
Feb 3, 2006 04:29 AM
