Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Triple Snorkel Air Cleaner?
Old Apr 13, 2012 | 07:42 AM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
This is the plan for my air intake. I have the second arm cut and sandblasted ready to be welded in then I'm having it all powder coated. Just thought I'd post this to see what kinda feedback I get. Has anyone on here already done this?
Old Apr 13, 2012 | 08:28 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Triple Snorkel Air Cleaner?
Id just run a open element
Old Apr 13, 2012 | 08:36 AM
Engine: 5.0 L03 V8
I thought about that but I think this set up would get more focused air and possibly faster air flow
Old Apr 13, 2012 | 10:45 PM
FueledSoul's Avatar
No... If you want a ram air effect the best place is in the front of the car... you would gain more with a open element then you would with your current design
Old Apr 14, 2012 | 02:30 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
The flaw in your design is the TPI intake, they are too restrictive. Just use piping and a filter. Or the open element like FueledSoul mentioned.
Old Apr 14, 2012 | 12:36 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
More volume, but hotter air which equals less oxygen.
Slightly less volume cooler air (more oxygen rich) is better than a higher volume hot air.
Old Apr 14, 2012 | 11:19 PM
FueledSoul's Avatar
open element over his design
Old Apr 15, 2012 | 12:08 AM
Dakota W.'s Avatar
I saw a setup similar to this that would work better, the guy used the stock piping for the hole at 4 o'clock and also put in another bit of piping at 8 o'clock, I can't seem to find the picture though.
Old Apr 15, 2012 | 12:20 AM
Car: GTA
Sounds like the stock dual inlet setup from the early 3rd gens.
http://www.oldcarmemories.com/content/view/104/114/
Old Apr 15, 2012 | 12:29 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
From your profile you have a 305. I don't think 3 air tubes is necessary.
Old Apr 15, 2012 | 12:49 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
One snorkle works fine https://www.thirdgen.org/forums/tbi/...l-diy-tbi.html
Old Apr 15, 2012 | 05:32 PM
Dakota W.'s Avatar
Pretty much is, but you could tell this guy's was fabbed up.
Old Apr 15, 2012 | 07:15 PM
Engine: 5.0 L03 V8
Everyones saying open element but I think this will work well. I already put the TPI intake in connected to nothing and just the air running through that thing made my car run noticeably cooler now when its focused into the air cleaner it should show some results.
plus this way its cool air from outside as opposed to air from inside your engine bay
Old Apr 15, 2012 | 07:23 PM
Car: GTA
Run the stock dual style like I posted above & that will be plenty of air to feed your engine & leave the TPI duct open to provide cooling air just flowing over the engine components. Run a cowl induction hood & the cooler air flowing in the front could provide enough under hood air pressure for air to flow out the cowl hood instead of it getting sucked in like normal?
Old Apr 15, 2012 | 07:58 PM
Engine: 5.0 L03 V8
Yeah that would get the job done the only issue is when running it with the TPI intake connected to nothing it blows dust and stuff all over my engine bay. Now that I put filters in it it might not do that though.
Old Apr 15, 2012 | 10:33 PM
FueledSoul's Avatar
If you want cooler air ditch your factory intake... The Whole plenum is wrap with water jackets to keep it hot and the whole thing is restrictive...
Old Apr 16, 2012 | 12:32 AM
1gary's Avatar
Orrrrrrrrrr-you take one of those and ya know your hair dyer...........well.......aaaaa,naw that won't work.LOL.
Hey-hey.Here's a idea.Take one and pipe into your A/C for cold air.Now only if ya could figure a way to get rid of all that moisture.
Old Apr 16, 2012 | 03:45 AM
Dakota W.'s Avatar
The A/C thing actually kind of makes sense...If you could run the aluminum A/c piping through your intake and then back out so it's just a piece of cold piping in there. That's actually a really good idea if you have A/c.
Old Apr 16, 2012 | 07:05 AM
Engine: 5.0 L03 V8
That would be pretty crazy, my only concern would be the moisture but if you could find a way around that it sounds like a really good idea.
Old Apr 16, 2012 | 08:32 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
It would take more power to run the ac than any possible power added for cool air. Then add all the extra weight on top of that it is just not a good idea.
Old Apr 16, 2012 | 08:43 AM
Engine: 5.0 L03 V8
Well the way I planned to do it couldn't add more than 10 pounds. The only new pieces would be the TPI intake, filters, plastic air duct tube, and snorkel arm.
Based on the results from running the TPI intake with nothing connected I'm expecting a decent improvement. Just having the thing blow cold air on the motor made it run significantly and consistently cooler.
Old Apr 16, 2012 | 11:45 AM
1gary's Avatar
This a loaded question.Is it just a matter of a dense air charge or is it a matter of a colder more dense fuel charge??.If you do only one,could you end up with a lean condition?.
Old Apr 16, 2012 | 05:11 PM
Dakota W.'s Avatar
Provided you want a fast car with a/c, that would be the perfect way to counteract having a/c.
Old Apr 16, 2012 | 10:42 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
why not open element with a nascar style cowl style intake. then you have cool lower pressure air coming straight from your cowling
Old Apr 17, 2012 | 04:45 AM
1gary's Avatar
Guys-wait a minute.I was kidding about the use of A/C because it is soooo silly.
Old Apr 17, 2012 | 11:36 AM
Engine: 5.0 L03 V8
Yeah I wasnt exactly sure I just didnt wanna shoot down your idea haha
Old Apr 17, 2012 | 03:39 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
You really want to run the dual snorkel OEM style setup as it fits great and has enough capacity for almost anything you might run, of course get a K&N for it...
Old Apr 17, 2012 | 08:40 PM
Engine: 5.0 L03 V8
They're nearly impossible to find in good shape for a reasonable price
Old Apr 17, 2012 | 10:42 PM
Dakota W.'s Avatar
K&N's let in more dirt than a paper filter, unless you're running boost you don't need a K&N, and you certainly don't need the extra dirt associated with it.
Old Apr 18, 2012 | 07:28 AM
Engine: 5.0 L03 V8
I'll just wash the K&N's and replace the factory circle shaped one more often.
Old Apr 19, 2012 | 09:52 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Look at the 1970s air cleaners or the one on a Monte SS. Rivet a second air inlet neck on the other side; presto, dual snorkel w/ nicely sized openings. It's not even much work to copy the L69 F-body Thermac vaccuum hoses.
Old Apr 20, 2012 | 08:11 AM
Engine: 5.0 L03 V8
If theyre compatible and have larger openings thats a really good idea, I'll probably finish this set up first though because I have most of the work done already.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
