Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom battery relocation (pics)
Old Apr 23, 2012 | 06:22 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
did this while i was putting a new starter in
thought id share it
Old Apr 23, 2012 | 06:42 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Custom battery relocation (pics)
Is there a special reason for moving the battery to the firewall? I think it looks good and nicely mounted. Did it help you with the cables going to starter, keeping them from the header heat?
Old Apr 23, 2012 | 07:01 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
my old battery tray was rusted out and i wanted to add some symmetry since i dont have an AC
Old Apr 23, 2012 | 07:12 PM
Edwardgp's Avatar
Engine: 454-350
OK looks nice I have been toying with the idea of going to the back or trunk of mine with the battery. I don't know it could help with traction a little.
Old Apr 23, 2012 | 07:30 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Many foreign cars have the battery in that position-
mercedes benz and the like... Will get some weight off
the nose...
i relocated my batt to the spare tire well-much less
hostile location for a battery and i needed to make room
for an air tank(air horns)
Old Apr 23, 2012 | 07:48 PM
Edwardgp's Avatar
Engine: 454-350
Alright LostX keep the shiny side up and good luck with your projects to come.
Old Apr 23, 2012 | 08:58 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
that was a pretty cool idea to do on the cheap. the only thing i thought of, was it reminded me of the old datsun 280z. i think it was that model car? but when the battery gets mounted there, you need to watch that your framerail just under the battery doesnt rot out like your battery tray. im pretty sure it was the old 280zs that were famous for rotten frames on that side from the battery. just my 2 cents.
Old Apr 23, 2012 | 09:05 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
i figure if it took 25 years for my old battery tray to rust out then ill be fine for a while.
it only cost about 45 dollars to do
Old Apr 23, 2012 | 09:11 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
lol. true. i like it though. good job.
Old Apr 23, 2012 | 11:28 PM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
where you get that bracket its very similar to the one in my circle track car
Old Apr 23, 2012 | 11:45 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
55-57 chevy, older trucks, new mudstains, and many other cars have the bttery there.
My lil G5 has the battery in the trunk!
Old Apr 24, 2012 | 07:01 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Too bad you couldn't keep the heat..
Looks great!
-- Joe
Old Apr 24, 2012 | 07:05 AM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
AFC-50302
this is the part number. it was a weld in tray that i modified to be a bolt in because i couldnt weld steel to that aluminum plate
Old Apr 24, 2012 | 07:34 PM
wretched737's Avatar
Why is your oil dipstick zip tied to your pcv valve?
Old Apr 24, 2012 | 09:12 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
the bracket on the dipstick tube broke so it falls over
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
