auto shift plate idea
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
I’m in the process of remaking the gear strip for the shifter plate so it lights up differently. it’s going to have a blue back light except for the letter/number gear it’s in. that will be red. I currently have a crappy shift plate I’m going to be proto typing with.
Has anyone done something like this? I’ve searched but found nothing.
Comments questions suggestions?
I have some components on the way to do a test circuit with. Iff all goes well ill order the rest of the parts and start things up.
Car: 1983 Z28
Engine: Forged 355
Re: auto shift plate idea
SHOW PICTURES!
Sounds awesome, I bought some l.e.d.'s off of superbrightleds.com or something and swapped out my gauge lights and replaced the led under the shifter with a red one and painted the gear indicator bright white. I have the B&M shifter though, so I don't really know the difference with the stock one
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
later this afternoon after work ill post some pics and give a little more info as to what im doing. the electronics are at the house so ill get to test a circuit.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
ok so this weekend i had a little bit of time to play around. i put the circuit together and it worked nice. ill have some pics and the schematic below. so basicly, when the relay gets power/grounded it will switch the bicolor led(which i didnt order yet) from blue to red. now that i know it works im ordering the rest of the relays and the bicolor leds. as for the piece of glass with the gears on it, im working on finding a printer that will reprint it with a non transparent black that will block the light and a transparent white so it will look stock when not lit up.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Here is the schematic of the lighting sequence as well as the ground switching concept i've been thinking about.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
well the rest of the switches, relays, leds, and connectors have been ordered. should be able to start most of the wiring soon.
also. later to day im meeting with a printer to review the options he hasfor the indicator (pic).
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
So wha u saying is when u shift, it lights up diff from 1,2,D,OD. What I would do is... the lever should be ground, run 1 power feed from the stock light. Run all the Leds in series of that power supply, make a prong off the shifter so its like a switch. As u switch gears it will light up. Mounting will be up to u.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
but how will you actually switch S1 thru S7?
i used some hall sensors
https://www.thirdgen.org/forums/inte...dicator-t.html
not perfect.. but best i could come up with.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
im currently running different ideas around until i find one that i like best. your hall sensors are a nice idea but.. i have some reed switches laying around to use for now. until i go though the catalog i have about 100 more times that will work for the time being. got my relays and what not in, waiting on the leds, and some connectors befor i start soldering it together.
going to be meeting a printer on thursday. (i missed they last week)
so... that all for now. for to work on the engine a bit.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
quick update...
called the printer today ad was told the company he deals with can't make the panel.
so.....
i have to go back to my fist idea which was to engrave a peice of plexi and paint on the black, then spray on the transparent white.
as for the circuit, im going to try using the Presensitized PCB board to make a good looking design. but it will be the fist time so it may not come out as i please.
but ill keep updating as things happen(hopfully quicker than they have been)
so.....
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Was just on the phone with the printer and came up with a way to get the ind. plate to show light the way i want it to. so i have to find a day he and i are both free to talk about it.
as for the circuit... nothing. have not been able to do anything with it. im looking to use the Presensitized PCB board like i said earlier but im unsure how well in will come out. has anyone used this before. or how have you made boards like this?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The berlinettas use a thin plastic black strip w/ white letters that are blue when lit.Maybe that might work as well.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
calling the printers today about the art work for the plate. this weekend im going to try and get the circuit board etched. heres the piece im going to get printed out for the shifter panel. maybe ill finally have something to show you guys in the next few days.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Well. After almost a 2 month hold on this project for various reasons, i finally order the last few parts and the circuit board to put it all on. I’m going to be making the shifter plate this weekend as well as the board when i get it. Attached is a mock up to see if it will fit in the enclosure I have.
Sorry for the lack of updates. I’ve been way too busy.
Car: 1988 GTA
Engine: 400 CI
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
thats what my first plan was. but then i was like what if they all blue and changed to red when it was in that gear. so my something simple turned into a little project.
i sould be getting the rest off the parts today might have the pc board etched by the end of the day. possible assembled by the end of tomorrow if i dont have work.
I still have to make the ind. strip and switch circuit.
Car: 1988 GTA
Engine: 400 CI
Can't wait to see the finished product.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
So i actually made some progress on this thing. got the board etched. Not bad for my first time if i do say so my self. Was going to start drilling it out and placing parts but my chuck is broken on the press so I'm waiting for the new one.
Will keep you updated.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
So I was placing the parts in the board last night and found an "Oh Sh*t" in my design. When I designed the board the white connectors were the last parts designed in. after placing them I forgot to space them to account for human error in the drilling. If they were drilled perfectly, I would have this binding issue. so i have repositioned them in the design and will have to etch out another board. I ordered a few boards this time because radio shack charges way too much for one. While that is coming in I’m going to start making the indicator strip that will light up.
Car: '87 Flame Red/Carmine Red GTA
Pretty cool, but why on earth would you use relays? You're just lighting up an LED. Small signal transistors would have sufficed and you could have made the board the size of a quarter.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
mainly because my knolage about electronics is limited. the project along with my car is on pause for a while now.
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Mar 18, 2019 08:29 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
dhonda200
Aug 11, 2015 11:50 PM
