(Factory appearing Camaro Dash) I Deleted The Center HAVC Vents...
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I'v always disliked the center vent on the Camaro dash so i do what i do best but it took a bit of work...
Re: (Factory appearing Camaro Dash) I Deleted The Center HAVC Vents...
making the first cut no turning back...
I am not done yet but you get the idea...
The dash should turn out just as nice as the center console i did
https://www.thirdgen.org/forums/inte...ed-center.html
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Good work!
I assume you have no heat or ac?
Thanks! yeah no HAVC...
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Nice clean look it's going to have.
Car: 1971 Camaro
Engine: 427
What about the vents near the doors? You gonna seal those off? And the ones in the dashpad?
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Nice job and kudos on the workmanship.
I'm sure it will look great but I just don't get it. Maybe it's because I'm older, but I like my A/C when driving on a summer day when it's too hot or I don't have time to put the top down. I like to be able to turn the heat on when there is a chill in the air after I've been out all day but still enjoy having the top down on my way home from where ever I've been.
That being said, It is your car and I'll defend your right to do to it as you see fit.
I just know that when it comes time to sell or trade (even though you say you never will) by doing a mod like this, the value of the car (at least to me as a buyer) has gone way down. Good luck with your project. I'd like to see it when its completed.
Maybe it will change my mind.
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Looks really good! I also like your HVAC control delete panel. I'll be very curious to see the complete interior when you're done.
Car: 1988 IROC-Z
hey man.. that's amazing work.. I don't want to do what you did.. but, have some cracked areas on my dash.. that need fixing.. could you check this out
https://www.thirdgen.org/forums/inte...ml#post5641348 and give me some thoughts? Thx!!
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Like most of your other ideas/threads I'm using this one for my build. What paint did you use for where the old center vent was? Is it a plastics paint? Can you tell it is smooth there where it should be textured? Did you paint the entire dash? I took the extra step and blocked off/removed all of the vents. Living in the desert I don't need heat and if it's hot enough to need AC I just drive the other car.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Vintageracer
Aug 11, 2015 08:13 PM
