Can a 3rd gen driveline and suspension become a rolling setup?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Can a 3rd gen driveline and suspension become a rolling setup?
Body be lifted off? Yes. Driveline rolled out? No.
The car is a unibody. All the suspension components attach to the body. Front and rear are not attached to each other like a full frame vehicle. When you unbolt the front subframe and rear suspension, they become separate components.
Car: 87 IROC L98
Not possible. You need to start with the body as a foundation then attach everything to it.
whatever! but it worked.
compressed front coil springs
took rear trailing arm bolts out
rear track arm bolts
sway bar bolts
brake lines
and other stuff, then lifted body off entire assembly. so yes it is possible
sway bar bolts
brake lines
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
No. His definition of assembly is incorrect. He lifted the body off of assorted pieces/parts.
Just because you unbolted everything and lift the body off, and the parts MOSTLY stayed in place does not make that a rolling chassis. You couldnt even remotely begin to roll that around to a different spot. You removed the CHASSIS when you lifted the body off.
I can see your plan working out ok...I guess. But stripping good body, and then installing good parts to it is the way to do it. Would probably ended up being less work for ya. Unless you are
In for pictures though...because Im just going through all of that stuff in my head and it sounds like a royal PITA to do this. Not to mention dangerous. Leaving the coil springs compressed without the weight of the car on them. Just asking for a compressor to let go. Glad to hear they didnt..hopefully you arent leaving it like that for very long.
J.
J.
J.
J.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You could build a chassis if you got all the attachment points in the right places in relation to each other. Then swap bodies to your heart's content.
Car: 1987 camaro sc
Engine: lg4 305
put a dolley under the engine cradle and suspension cap the rear of the tranny and just roll the rear by it self
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Isn't the engine cradle and front subframe in these cars part of the body? Like welded to the body? The engine cradle doesn't come out without cutting steel.
Just follow the assembly line photos here and you see what you will end up with ... http://www.last1992camaro.com/pictures/page2.html
Some of the 3rd Gen dealer brochures have pictures of the "rolling setup" as well ... but totally different from none subframe car of course.
Car: 1987 camaro sc
Engine: lg4 305
the engine cradle is held in by 6 or 8 bolts and you unbolt the shocks. the tranny crossmember also have to be unbolted from the car the nyou lift the body simple as that
1 Post
Ah, I see. All the time I spend under my car the last few weeks I'm surprised I didn't notice the bolts in the engine cradle.
