Anyone use a front air splitter?
Car: 1984 Trans Am
Engine: 1996 Corvette Lt1
Transmission: Richmond 5 speed
Axle/Gears: GM 3.27
I plan on making a detachable front air splitter for my car. I was wondering how many third gen owners utilize these for racing. If you can, show pics!
Car: 1984 Trans Am
Axle/Gears: GM 3.27
Re: Anyone use a front air splitter?
That's awesome, thanks for the picture! I also plan on added a rear air diffuser as well to better direct airflow leaving the car.
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Probably a dumb question but wouldn't covering the underside of the engine block the airflow that helps cool the oil pan?
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Keep in mind that thirdgens get air from underneath to cool the rad.
Made this up for the Firebird, works for street and track use but is 4" off the road. A true splitter is 1.5 - 2" off the road, wraps around the nose of the car, and still needs to find a way to feed cooling air to the rad. Much more involved, and as you say needs to be detachable for trailering and for street use. Ideally would incorporate a belly pan and brake cooling ducts, and has to be strong enough to stand on.
Do a search, there are a few threads on TGO, and on frrax.com.
Car: 1988 firebird
Engine: Lt1
Axle/Gears: 7.5in 10 bolt. 3.42, possi
It's a diffuser not a splitter but I wasn't sure if you wanted that specific
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
