Whats the most original or practical mod you've seen on TGO?
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
So many great ideas here it can be hard to see them all. Whats the most original or practical mod you've seen on thirdgen or elsewhere (on a third gen)?
Engine: 5.0 L03 V8
Re: Whats the most original or practical mod you've seen on TGO?
Not exactly what I had in mind but I suppose that is one
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Engine: 5.0 L03 V8
That is pretty cool. The lines really resemble the SS hood I'm surprised he doesn't have one to go with that notchback.
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Lt1 what the Thirdgens should have came with stock. And that SS notch back looks really stupid imo.
The most practical is the fuel pump access door. Having owned 2 thirdgens (one was a daily driver for 10 years) and changed a half a dozen fuel pumps, this mod saved lots of time and is less hassle than dropping the tank. LS1 fuel tank with LS1 pump is a good mod to compliment the fuel pump access door.
My other favorite practical mods:
-Drill two holes in the inner metal door skin to get the window motor out is a good one. There is a template somewhere on here on TGO.
-97-02 center console swap (stock center console usually falls apart, has no cup holders)
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 86 IROC
Engine: 5.0 TPI
The most practical is the fuel pump access door. Having owned 2 thirdgens (one was a daily driver for 10 years) and changed a half a dozen fuel pumps, this mod saved lots of time and less hassle. LS1 fuel tank with LS1 pump is a better mod though.
Also the mod to drill two holes in the inner metal door skin to get the window motor out is a good one.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Most original i liked Neils widebody camaro he made. One of the biggest/longest threads on tgo. Def something you dont see everyday
Most practical, i feel is a modern big brake kit. Stock brakes always left more to be desired and after driving late model f bodys you can appreciate more brake. The kits done by ebmiller and big brake upgrade have always had my appreciation.
Linson
Aug 21, 2015 02:12 PM
