Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
18 inch GTA wheels
Old Feb 26, 2014 | 12:20 PM
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
18 inch GTA wheels
In the near future i am going to be re-creating the GTA crosslace wheel in an 18 inch version. It will be a 3 piece wheel, in either 18x9.5 or 18x10.5. Polished lip and inner barrel, and a painted face, either gold, black, or gunmetal. Im going through the design stages at the moment, autocad renderings, and 3d renderings on autodesk inventor. Once i get the first set made, have tires mounted on them, and then mount them on my car and test them, i will make them to order if enough people want to buy them. So what do you all think? they will be able to fit the stock center caps also.
Old Feb 26, 2014 | 12:34 PM
88gunmetalgta's Avatar
Re: 18 inch GTA wheels
Have you found a source for the barrels? Are you doing a bolt-together design, or are you having them welded? How bout a source for the spin forged blanks for the centers?
I'm hoping this actually happens since I've been slowly gathering information, but it will be on the back burner for me for a long time yet. Even doing most of the work myself, I'm still looking at $800 for materials for the centers alone.
Old Feb 26, 2014 | 01:39 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I'm curious about your estimated price on these wheels. Most of the big brands ask around $1,000/wheel for a non custom 3pc in the 18" x 10" size, not counting finish or hardware upgrades.
Old Feb 26, 2014 | 01:46 PM
mac86's Avatar
Engine: Carbed 355
yes i have a source for the barrels. step-lip design. i can get the barrels in any width i want, but i will be mostly using ones that add to 9.5 inch wide, or 10.5 inch wide. if in the future a buyer wants them wider, i can most likely do that for them. They will be bolt together. im still working on a source for the spin forged centers. gotta see how much the centers will cost me. I need to finish my cad rendering before i can get a price for the spin forged center peices though.
Old Feb 26, 2014 | 02:55 PM
Do you have access to FEA software? How bout fatigue testing since you're planning on selling them?
Old Feb 26, 2014 | 03:28 PM
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
This is very interesting and depending on the final factors, mainly quality and testing, i'd be very keen.
Old Feb 26, 2014 | 03:46 PM
mac86's Avatar
Engine: Carbed 355
im still trying to contact companies on it, but ill keep you guys posted the best i can.
Old Feb 27, 2014 | 11:18 AM
mac86's Avatar
Engine: Carbed 355
the company im contacting that will do the cnc machining to the face of the rims also makes rim faces for other major companies. the faces they do the cnc to are spin forged aluminum. they would be doing the fatigue testing and run it through the fea program to make sure that it is up to spec. and the people who manufacture the barrels also have made them for HRE and a few other major wheel companies, so they have a good reputation.
Old Feb 27, 2014 | 02:36 PM
LX_SS's Avatar
Engine: 347ci LS1
Probably some of the best news if your going through with this, the larger companies have access to the equipment and software for testing which really is crucial for wheels + on-road use.
Looking promising ;-) But design will be everything has to be micky mouse ;-)
Old Feb 27, 2014 | 05:03 PM
Black Knight's Avatar
Count me in. I would want at least 11 or 12 for the rear.
Old Mar 1, 2014 | 03:15 PM
KBD85's Avatar
Car: 1985 trans am
yes, this is very exciting!! very curious about these. I too would want some on the wider side.
Old Mar 1, 2014 | 03:57 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
I'm in on as a buyer of a set with gold centers. Just keep me posted.
Old Mar 3, 2014 | 07:32 AM
mac86's Avatar
Engine: Carbed 355
sounds good guys, i will most likely need like a list of around 20-30 people to place my order so i get a better price for the materials for ordering in bulk. im still working on my cad rendering and 3d rendering, along with getting the dimensions of the barrels so the face can fit in them. Once i have that, and i finish the rendering, i can get a price on how much the faces machined will cost me, then i will get a price for powder coating, and finally i will have a final price for the sets of rims. Price may vary a little bit depending on how wide each person wants the rears. but not by much. it may be a while though, depending on how long the designing takes, and then the design needs to be run through the FEA program and stress testing etc.
Old Mar 3, 2014 | 07:55 AM
MASON1259's Avatar
What about big brake clearance? GTA wheels clear stock brakes but not sure about a 4 piston set up or Corvette brakes.
Old Mar 3, 2014 | 08:23 AM
For all you guys who have bought in already, here's what you can expect for a price: http://www.vividracing.com/catalog/h...150724000.html
20-30 pre-paid buyers is not gonna be easy to get.
Old Mar 3, 2014 | 08:24 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
What's your price point? Curious if you have priced out what the barrels, fasteners and CNC time cost.
Old Mar 3, 2014 | 12:32 PM
mac86's Avatar
Engine: Carbed 355
i have the price of the barrels and fasteners so far, but once i have everything priced out, and i have the price from the companies for ordering in bulk, i will have a final price. then i will post up what each set will cost.
Old Mar 12, 2014 | 08:21 AM
mac86's Avatar
Engine: Carbed 355
its gonna cost around $3000+ just to make the first set, and i dont have that kind of money at the moment, so im putting all this on hold for a year or so until i can have enough funds to start it up, once i have enough, and i can order in bulk, the costs for each set will go down a bit most likely, but im sure not alot of people will not want to pay $4000+ for a set of 18 inch gta rims, but if there is alot of interest still in a year or so, ill start it up.
Old Mar 12, 2014 | 10:36 AM
TRANSAM82-92's Avatar
You should check out HRE wheels website. They make one that looks like GTA crosslace rim. It comes in either 18 or 19 and are custom made to you spec...i.e. brakes width etc...
Vintage series
#501
http://www.hrewheels.com/wheels
Old Mar 12, 2014 | 11:14 AM
406TPI's Avatar
Car: 1985 IROC-Z
Honestly, I expected it to be higher. Hell, $3K for a true 3 piece forged wheel is still a bargain. Mine were over $4K. Guys that are in the market for a high quality 3 piece wheel would probably find this attractive from a price standpoint.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
gta power
Aug 13, 2015 06:15 AM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
