Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Billet Hood Hinges
Old 05-06-2014, 05:28 PM
bvahnee's Avatar
Billet Hood Hinges
Hey everyone. Just wanted to give a sneak peak of my first prototype billet hood hinges. Pivot points have ball bearings. They're made to factory specs and reuse the stock shocks and bump stop. They bolt right in with no mods.
In case anyone is interested I did make a couple jigs that aid in the production of these, meaning I will be making several sets. Cost still isn't finalized yet but somewhere around 450 a set with chrome plating. I'm hoping by the end of the week to have a finalized set I can show off.
image hosting no register
Old 05-06-2014, 06:07 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Billet Hood Hinges
Keep us posted....
are you using billet plate. And bolting them together?
Old 05-06-2014, 06:26 PM
bvahnee's Avatar
Base plate, tabs and the two support arms are 1/4" 6061 T6, the plate that bolts to the hood is 3/8. Tabs are tig welded in the jigs. Then each piece is bolted together with the bearings.
Old 05-07-2014, 05:26 PM
so then all the parts can be polished out to a high luster. Then chrome plated..or anodized the color that you want...right?
the chrome plating is done by you...can we get them in just bare aluminum. So we can have them anodized the anodizing. Will be done by the buyer.
do they have a spot for the limiters to be installed like the factory hinges.
and you can put me down for a set let me know when you need funds
and could I get a set in just bare aluminum. I'll do the polishing and anodizing....
Old 05-07-2014, 08:03 PM
bvahnee's Avatar
I can absolutely leave them bare if you want to do your own anodizing.
And yes its all plate T6 so it's fairly easy to buff and polish yourself unlike flat bar stock.
The stock stopper bolts right in, I tap the 1/4-20 hole so all you have to do is unscrew and install on the new hinge. The struts also bolt in with some phosphor bronze bushings. Included of course.
I'll put you down for a set when I feel happy enough with the final design. I got some different bearings coming in tomorrow that are a bit stronger than the ones I use now. I will keep you posted. Thanks!
Old 05-07-2014, 09:26 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Nice work!
Old 05-08-2014, 12:21 AM
let me know when ya got a set ya like. and what ya will need $$
Old 06-16-2014, 03:35 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Sub'd for interest. The pivot holes in one of my stock hinges has gone all oval and has a ton of play. Ball bearings FTW. Would be interested in raw aluminum, will polish on my own.
Old 06-16-2014, 06:14 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I'd be down for a raw or black/gray anodized set. How did you do the bearings?
Old 06-16-2014, 07:21 PM
hoping this gets off the ground..soon
Old 06-16-2014, 07:38 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
great job
Old 07-01-2014, 02:33 AM
is there any updates?? from anybody?
Old 08-07-2014, 08:49 AM
prossi's Avatar
I too would like updates
Old 08-07-2014, 03:53 PM
Think its dead.....
Old 08-07-2014, 04:47 PM
Axle/Gears: 3.27 BW
This thread gave me blue *****.
Old 08-08-2014, 12:51 PM
A few guys bring it up...but it died on the vine
Old 09-04-2014, 05:14 PM
bvahnee's Avatar
This is not dead!! I've been going through a huge career transition lately and have not had the downtime this project deserves. This transition, however, means I am about to take over the family machine shop. As soon as things calm down a bit I will be making these using a better process than the prototype shown above. The prototype requires tig welded tabs for mounting, the new ones will be billet and milled on the 4 axis HAAS.
Hope to have something to show off once the shop move is done next week.
Old 09-04-2014, 05:55 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Hell yeah man, good to hear on both parts. Now, can we HAAS some Billet Hinges
Old 09-04-2014, 09:56 PM
Axle/Gears: 3.27 BW
Awww yisss!
Old 09-05-2014, 09:43 AM
hope ya can get them started.. they will sell
Old 09-06-2014, 01:41 AM
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
Are these lighter? or is the purpose purely aesthetic?
Old 09-29-2014, 05:06 AM
ls2 dude's Avatar
Car: 1989 iroc z
Engine: 98 ls1, prcs, btr cam
Transmission: rkt56 6 speed
Axle/Gears: midwest chassis 9 inch 4.30wavetrac
put me in for a set
Old 09-29-2014, 09:30 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I would imagine these are much sturdier than the originals. My factory hinges have gotten pretty loose over the years.
Old 09-29-2014, 11:14 PM
ls2 dude's Avatar
Car: 1989 iroc z
hell yeah, mine are loose as hell
Old 09-30-2014, 06:10 AM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
mine are all but falling apart.... I am in for a polished set
Old 10-06-2014, 01:20 AM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Polished set for me as well
Old 10-07-2014, 09:54 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'm not a fan of polished. I'd be interested in brushed or raw finish...
Old 10-08-2014, 05:57 PM
fatalicshock's Avatar
Car: 87 Trans Am
i would love an anadized set but i dont know where i could get that done at around me
Old 10-16-2014, 06:10 AM
Myorangecamaro's Avatar
Ill take a set!
Old 10-16-2014, 06:12 AM
ls2 dude's Avatar
Car: 1989 iroc z
Let's get the ball rolling on a group purchase
Old 10-16-2014, 10:54 PM
Axle/Gears: 3.27 BW
Old 10-17-2014, 12:28 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Most of that is probably bushings and such in there. The factory stuff can probably be rebuilt without much issue.
Old 10-24-2014, 07:19 PM
bvahnee's Avatar
Getting the 4 axis ready! 20" "trunnion" table. I'll be making some chips soon.
Old 10-27-2014, 05:48 PM
ls2 dude's Avatar
Car: 1989 iroc z
Let me know, I'm in
Old 10-27-2014, 06:56 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
What kind of cost are we looking at? Also, are these bearings at each pivot point?
Depending on price still I am in for a set of raw, I will blast them and Cerakote them
Old 10-27-2014, 11:56 PM
im still in for a set!!
Old 10-29-2014, 05:42 AM
a383z's Avatar
If you can get the price lower than the 450 I would be interested... 6le designs made one similar for the 4th gens.
Old 11-08-2014, 04:59 AM
anything???
Old 01-25-2015, 04:25 AM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Fingers Crossed for 2015...
Old 01-30-2015, 11:24 PM
still in for a set...2017?..keeping the Dream alive..
Old 03-04-2015, 02:11 AM
I'm in
Old 03-10-2015, 05:08 PM
  #42
Think this us dead..
Old 03-12-2015, 11:08 PM
  #43
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
I'm hoping it happens, want a set too man!
Hotrodboba400
12-10-2019 07:07 PM
mr z28
Exterior Parts for Sale
12-14-2015 05:14 PM
Stangski09
11-14-2015 01:27 PM
chuck13
Interior Parts Wanted
09-22-2015 11:19 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Billet Hood Hinges
