Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4th gen dash swap with entire heat and ac from 4th gen
Old May 23, 2014 | 09:56 PM
Mr Pain's Avatar
Car: 91 camaro rs
Engine: 355 sbc
Transmission: muncie m22
Axle/Gears: 10 bolt limited slip 373's
Ive read lots if threads on here and gotten plenty of useful information. What I plan on doing is the 4th gen dash swap and the entire ac system. So that would be the hvac box, heater core, blower and all the ducting. ..im talking about everything. Iknow already that fire wall mods will be necessary. Such as cutting and maybe welding. If anyone has done this please let me know and I can document everything on this thread. Or if tou know who has done it let me know. Thanks!!
Old May 24, 2014 | 10:40 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 4th gen dash swap with entire heat and ac from 4th gen
There is a thread, "4th Gen Heater Ducting Done Right" I think it's called, where the guy shows how to hack the firewall up for the box. I didn't do mine that way. I cut the box for the firewall to leave the cowl unmolested (I have enough problems over there and didn't need more). You may need to do what I did and make a 1" spacer to go between the box and the firewall.
:edit: You only REALLY need the air box that contains the heater core and the door motors... Nothing else will work and you already have it in the engine compartment. You can even retain the stock HVAC wiring with a simple one-wire modification to the GREEN wire running between 2 of the switches in the control head.
Old May 25, 2014 | 01:14 PM
Mr Pain's Avatar
Car: 91 camaro rs
Engine: 355 sbc
Thanks Maverick for the replie...good to see someone whos done this and is still active on the site. So you ended up using sone of the 3rd gen ducting? And what wont work? I haven't tedt fit anything yet but I was hoping to use the whole assembly I removed from the 98 TA. Im not sure how I will do things but ill keep you posted and maybe if you have pics of what you did you can post them. I still need to learn how to post pics here lol!!
Old May 25, 2014 | 01:39 PM
Mr Pain's Avatar
Car: 91 camaro rs
Engine: 355 sbc
Well I got done with the TA. I cut out the frame of the hvac box but I need to clean up the acces metal on the sides. Ive looked at the 91 fire walk and I might have to notch out the top right pass side corner. Ive seen someone do it that just wanted to use the 4th gen heater, it didnt look hard at all. One issue im thinking of is that the water from top under the windshield flows through that tunnel that I need to notch out, but ill look more into it as I go on. Im planning on test fitting the hvac box and with self tapers ill install frame on the 91 just as it was on the TA. Ill just use a good adhesive with the self tapers instead of welding. Then ill simply cut out the middle of the frame and that should do it.... I hope. ..
Old May 25, 2014 | 01:48 PM
Mr Pain's Avatar
Car: 91 camaro rs
Engine: 355 sbc
Old Jun 7, 2015 | 02:37 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
I did this in my 86 heres the thread page 11
https://www.thirdgen.org/forums/memb...0-86-a-11.html
Old Jun 7, 2015 | 12:32 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
I'm the one that did the "4th Gen Heater Ducting Done Right" thread (https://www.thirdgen.org/forums/inte...r-ducting.html), and have yet to have any issues with water leakage or inadequate drainage from the cowl. So long as you follow my instructions and seal everything properly, the water still has it's drain path and won't enter the passenger compartment. The 3rd gen A/C fan shroud/evaporator unit will work with it on the engine side, it just has to have the upper corner notched for the new heater hose routing. Nothing about putting in the 4th gen dash is direct bolt in, you have to accept that some modification is going to be included in the process, especially to have functional vents.
Old Jun 7, 2015 | 04:55 PM
85Special's Avatar
Car: Silver 1985 IROC-Z
Transmission: 700-R4
Vintage air GenIV will fit our cars, and leave you with a clean fire wall. I have one.
Old Jun 12, 2015 | 02:06 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Not a easy task. There is a lot of cutting and welding involved. You will end up cutting a large sectioin of the fire wall and the wiper cowl. Placement of the ring for the HVAC box is critical.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
