Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
looking for ideas and help for custom parts.
Old May 14, 2015 | 11:12 AM
concorde01's Avatar
i have a 89 rs 2.8 5spd. i am buying a 3.4 for it. i dont car about v8s. i want a v6. i am looking for someone that can make me a better flowing/looking intake manifold for it. id also like to be able to use a larger throttle body. i know people have done this just need to find one that i like. and from someone that would be willing to build me one. things i want
better looks
better flow
i will be having it powder coated also
Old May 14, 2015 | 11:43 AM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
Re: looking for ideas and help for custom parts.
I am currently working on one that uses the the tpi throttle body. still waiting on some stuff to really get working on it. Check it out on the v6 board.
Old May 14, 2015 | 11:44 AM
concorde01's Avatar
can you send me a link? ty
Old May 14, 2015 | 11:51 AM
Engine: Chevy 3.1
http://60degreev6.com/forum/showthre...on-Head-Intake
It's not super set in stone yet, just an idea I had going on. I have a guy making a bottom flange for me to get started. It might not flow a whole lot better than the stock one besides getting rid of the sharp bends but other than that I think it looks decent.
Old May 14, 2015 | 11:54 AM
concorde01's Avatar
just read it. i like it. i just would like to use the stock lines and everything. your doing great though.
Old May 14, 2015 | 11:58 AM
Engine: Chevy 3.1
You would for sure have to use 3.4 fuel rails or else it wont fit under the plenum
Old May 14, 2015 | 12:01 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
The stock TB isn't the bottleneck. If you don't like the FWD 3400 intake, then look at the 3100 version. Either way, A better-flowing intake manifold on ported iron heads is less results for more $ than just swapping the FWD aluminum heads and intake.
Old May 14, 2015 | 12:05 PM
Engine: Chevy 3.1
Yeah, I know that aluminum heads are alot better. I am just making this for a better looing and getting rid of the tight turns. I know the iron heads suck but i dont want to do a full top end swap right now.
Old May 14, 2015 | 12:10 PM
concorde01's Avatar
are the 3400 heads and intake a bolt on?
Old May 14, 2015 | 12:20 PM
Engine: Chevy 3.1
Iron head ones yes. The aluminum ones no. need to swap out pistons or else you will have a crazy compression ratio.
Old May 14, 2015 | 01:27 PM
concorde01's Avatar
ya im just gonna go with 3.4/2.8
Old May 17, 2015 | 11:02 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
seems like a lot of work and cash outlay for something that will still be slower than a stock 305... it should handle pretty sweet, tho..
Old May 18, 2015 | 07:30 AM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
I would start at the bottom of the engine, tranny, suspension and axle for performance before the intake. If the engines already built up, yeah, hit the intake, but getting more air in on a stock engine will make a marginal difference if any. It will probably kill torque a little if it's too ported out.
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Sep 7, 2015 01:37 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
