Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Bought some new stuff
Old Mar 28, 2018 | 01:50 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So, I added some new things to my collection of fabrication tools. I bought a plasma cutter with auto pilot, a plasma table, a fancy circle cutting holder for it, and a spool gun for one of my MIGs. (So now I can weld alum with both mig or TIG).
Anything else I need? lol
-- Joe
Old Mar 29, 2018 | 05:31 AM
83 Crossfire TA's Avatar
Re: Bought some new stuff
That's sort of a random post... like what brand/size on all of that??? What kind of plasma table?
I have a MM211MVP which came with a spoolmate 100 that I modified to use standard (larger) contact tips, I now use that for quick work on aluminum more than I use my Synchrowave (honestly I'm very comfortable with MIG, not soo much with TIG) and an Everlast 50A plasma
Old Mar 29, 2018 | 11:53 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The cutter is a colossal ? Chinese made surely, 50 amp. Table is from eastwood, the slat type.
The spool gun is chinese, and was cheap (like $75). I have a few 240v mig welders in the basement, so I figured I'd use it on one of those. Came with cable, and a quick connect plug.
I have a Miller EconoTig, but without a foot pedal it sucks. I use it mainly for stick welding. It has high frequency, but no foot control and I don't think I can add one due to the way the temp crank works.
-- Joe
Old Mar 29, 2018 | 09:43 PM
NoEmissions84TA's Avatar
Originally Posted by anesthes
I have a Miller EconoTig, but without a foot pedal it sucks. I use it mainly for stick welding. It has high frequency, but no foot control and I don't think I can add one due to the way the temp crank works.-- Joe
I also have an Econotig and just finished making a few mods to it.
How old is your model that it does not have a foot pedal?
Does it have the 14 pin connector on the front panel?
Old Mar 30, 2018 | 06:43 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My bad, it's an "Econo Twin HF" which was made in the mid 70s I guess ?
You basically have this weird dial crank for amperage, so if you are using it to do say 1/8" stainless you can set it and do it, but if you are trying to TIG like a 1/4" flange to some 16 gauge pipe without the foot control it's easy to end up with a mess.
It's a PITA to use it on aluminum.
But for Stick use, it's a fantastic machine. I can stick 1/2" without issue, it has a great stable arc.
-- Joe
Old Mar 30, 2018 | 07:10 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
How/Why would you use a spool gun on a TIG machine for aluminum?
Old Mar 30, 2018 | 07:36 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
No idea, I bought it for one of my MIGs. (See first post).
-- Joe
Old Mar 30, 2018 | 08:52 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
-- Joe
Oh, I took it that you were going to use the spool gun to TIG weld aluminum.
Old Apr 1, 2018 | 09:21 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Oh no. The transformer in a TIG/Stick machine can't do MIG/SPOOL.
I have a couple of cheap chinese harbor freight 240v welders in the basement, I think I'll take one apart, run the 24v leads to the spool gun and use that. It's a 150amp DC machine, so it should do aluminum ok.
I've done aluminum with my MIG, but the second I have an arc failure it birds nests inside the machine.
And as stated, my TIG sucks without a foot pedal.
-- Joe
HiPerf_Chevyman
Jun 6, 2007 12:26 PM
UCF1Slider
Exterior Parts for Sale
Oct 22, 2006 06:10 PM
CamaroStud1988
South West Region
Sep 16, 2006 01:00 PM
ChrisFormula355
Jul 7, 2003 02:18 PM
