Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Blank Gauge Plate Template
Old Apr 9, 2021 | 08:27 PM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
For those interested, I have listed a template for the gauge plate on my website. Perfect for any one that wants to layout their own gauge setup. This has all the correct profile and mounting hole geometry.
https://www.unleaded-designs.com/pro...panel-template
Old Apr 12, 2021 | 12:34 PM
Abubaca's Avatar
Re: Blank Gauge Plate Template
Very cool.
....I'm going to be installing some Speedhut gauges once the LS swap is done. I may hit you up!
Old Apr 17, 2021 | 09:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
How thick is it? Can the windows for the warning lamps and indicator arrows be cut by hand?
Old May 24, 2021 | 09:03 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Not sure how i missed your post.
The panel is 1/4" thick. You can probably cut those in by hand if you take your time. I use a cnc to cut everything out.
Old Jul 26, 2021 | 07:44 PM
86Lucille's Avatar
Dang, I just cut a template a week or two ago was shaping it on the bench grinder for like 2-3 hours.
Old Oct 15, 2021 | 10:59 PM
Stumo's Avatar
Car: 89 GTA
Engine: Carb swap 305
Any chance you'd be willing to make one for the GTA? Or know where I could find a DPX file for one?
Old Oct 17, 2021 | 08:03 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
What year? Would just need to get one to reference.
Old Oct 17, 2021 | 08:08 PM
Stumo's Avatar
Car: 89 GTA
89 trans am analog gauges!
Old Oct 17, 2021 | 08:28 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
This piece?
Old Oct 17, 2021 | 08:48 PM
Stumo's Avatar
Car: 89 GTA
This piece?
yup! However I won't be re using the bezel for my application, the plate would need to be traced using the actual cluster housing, using the factory mount holes. ill see if I can find you a pic
Old Oct 17, 2021 | 08:57 PM
Stumo's Avatar
Car: 89 GTA
Old Oct 19, 2021 | 10:33 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
so you're looking for a blank version of the black piece that mounts to the white cluster?
Old Oct 19, 2021 | 10:49 AM
Stumo's Avatar
Car: 89 GTA
Nope the white piece (cluster housing) as that is what is mounted to the dash with factory holes
dcd2236
Jul 7, 2016 10:28 PM
90-irocdx3
Jan 5, 2014 07:56 AM
TVIROCZ
Mar 21, 2012 09:28 PM
Sitting Bull
Nov 28, 2002 10:36 PM
