Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Need help identifying metal bracket
Old Aug 18, 2023 | 08:36 AM
Danny_VXH's Avatar
So I'm almost done completely rebuilding my 1986 trans am and now I'm left with this metal bracket. No idea where it came from.
Can anybody identify this mystery bracket?
Old Aug 18, 2023 | 02:10 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Need help identifying metal bracket
Looks like a throttle or transmission cable bracket that would mount on top of intake by carb?
Old Aug 18, 2023 | 02:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Is the dash out of the car?
Old Aug 18, 2023 | 04:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks like a front crossmember brace
Old Aug 19, 2023 | 06:47 AM
Danny_VXH's Avatar
only the lower plastic panels.
I'll double check if that's all configured correctly.
I was rebuilding the entire car and repainting it then something happened causing me to pause the project a few years so my memory fails me on where to put it.
Old Aug 25, 2023 | 08:06 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Could it have something to do with being a bracket for the headlight stuff up by the brake booster?
Old Aug 25, 2023 | 08:25 PM
NoEmissions84TA's Avatar
I don't know, but I see a cable mount and those two angles at each end look like the hatch release area.
Old Nov 27, 2023 | 01:09 PM
86TA-LSA's Avatar
This is the bracket that goes up under the front fender in the front area under the battery tray area and is a support bracket. You are missing a straight piece with bent ends that "triangulates" the top and bottom for support. I know for sure there is one on the driver side as i had to remove it to remove the steering box, but there could be one on the passenger side too, I cant conform or deny that without looking.
Handy_man91
Carburetors
Jun 4, 2021 06:22 PM
BIGD54
May 31, 2021 05:04 PM
Aaron R.
Apr 25, 2020 05:53 PM
irocz2173
Fabrication
Feb 28, 2008 07:55 PM
